is it ok to soak a populated pcb in petrol overnight ?
  • petehall347
    • Jan 2015
    • 4440
    i will have the answer later . i normally pick at that white crap after a 30 minute soak but cant be bothered so left it to soak overnight .
    • 31246
    Re: is it ok to soak a populated pcb in petrol overnight ?
    are you intending to burn it?
    • petehall347
      • Jan 2015
      • 4440
      no i am getting the white potting compound off .
        • 31246
        lol
        • petehall347
          • Jan 2015
          • 4440
          well it softened it enough to find 3 through hole resistors loose and somehow the ntc has lost its bead .maybe i knocked it off but i was careful scraping .
          • Aussie Max
            • Apr 2020
            • 8
            Good job, another way to remove the potting mixture is to BOIL it in a saucepan for at least 20 min. I've done this a number of times, best to put in some marbles...to keep the board off the bottom of the pan. It may take a few times, but be assured it works. The problem with solvents can be losing part types.
            Graeme
            • foshland
              MSI R9 380 4GB 12V resistors or fuses not populated???
              by foshland
              Hi, I have this card with the fuses, resistors or whatever they should be not populated from factory, maybe the seller scammed me or im comming crazy, but as I can see, there never where something there, have a look, what do you think?
              More fun comes when I saw a Dicky96 video with same card and he meassured the 6pin fuses (the ones im talking about) and he finds that they are open (but as far as I can see there is nothing there, just pads)
              Does anyone has same card??? schematics says they should be there.
              Link to LER video (very thanks for all your videos...
              02-02-2022, 08:25 PM
            • beetle1303
              Panasonic Inverter Refrigerator model NR-BY602XS - suddenly not cold overnight
              by beetle1303
              I have a 7-year old Panasonic inverter refrigerator model NR-BY602XS that went from working normally to completely not cold air overnight (both freezer and refrigerator compartments...
              The service manual instruction on Self Diagnostic Test seems to indicated Compressor faulty or locked. But the compressor seems to be working with humming sound and vibrating at variable speed and noise level..
              Everything else seems to be working normally - power cycled a few times has no effect. All the interior lights, and fan are working. I dismantled the interior panel to expose...
              04-18-2020, 08:12 AM
            • Jesse James
              CQ62 Drains Battery Dead Overnight
              by Jesse James
              Hey guys need help with this one. I have a cq62-225NR that runs and works well on windows 7 or 10. The problem i am having is it kills good known battery overnight dead. It charges well and runs off battery fine and is shutting down when powered off. I don't have the board # as i have not opened unit yet. This is the AMD model
              Any help would be great
              12-14-2018, 03:58 PM
            • rutgerv
              Acer Swift 3 SF314-42 not powering up
              by rutgerv
              Dear all,
              For a friend I'm trying to repair an Acer Swift 3 laptop (SF314-42). I'm not a professional, but have some experience (both as amateur and professional) in working with electronic design and repair of musical instruments.
              The issue with the Acer laptop is the following:
              It was bought new and used (not heavily) at home for about three years. After normal use, it was put to sleep, connected to charger and left over night (just like any other day). The next morning, the laptop would not wake up from sleep. Instead, when pressing the power button, the power...
              08-02-2024, 06:59 AM
            • Novgorod
              Asus Strix Z270i Gaming dead DIMM troubleshoot
              by Novgorod
              Hi!
              I have an Asus Z270i mini-ITX board with a dead DIMM slot (the one further from the CPU). The board POSTs with only the other DIMM populated but gets stuck with the DRAM error LED when the bad slot is populated. The test RAM and CPU are known working (confirmed in a different board, both memory channels are fine). The board was working for many years in a watercooled system and had a tiny bit of corrosion in different places (which came off without issues) and no visible component or trace damage.
              What are the steps for DIMM (DDR4) socket troubleshooting? Since the...
              07-13-2024, 02:35 PM
