CQ62 Drains Battery Dead Overnight
  • Jesse James
    • Sep 2018
    • 95
    Hey guys need help with this one. I have a cq62-225NR that runs and works well on windows 7 or 10. The problem i am having is it kills good known battery overnight dead. It charges well and runs off battery fine and is shutting down when powered off. I don't have the board # as i have not opened unit yet. This is the AMD model
    Any help would be great
  • petehall347
    • Jan 2015
    • 4440
    Re: CQ62 Drains Battery Dead Overnight
    is it set to fully shutdown at power off ?
    • Jesse James
      • Sep 2018
      • 95
      Yes fully shutdown. It will even do this with no operating system. Hard drive removed
      • petehall347
        • Jan 2015
        • 4440
        have you ruled out the battery pack yet by removing it ?
        • Jesse James
          • Sep 2018
          • 95
          Yes. I can put battery in another laptop can sit there for days and no issue always fully charged
          • Jesse James
            • Sep 2018
            • 95
            So i pulled mb out and installed it into another laptop that had bad mb and now unit can sit for days on end and does not kill the battery. I am not sure what was the issue but is working now
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • mkdj
              by mkdj
              Mark and model: ASUS X571
              Tests already made:
              - I have removed...
              07-14-2025, 09:16 AM
              NVDC charger configuration...
              11-05-2024, 03:28 PM
            • huzo
              HP ELITE X2 1013 G3 weird battery issue
              by huzo
              Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
              01-31-2025, 12:09 AM
            • trepachka
              iPad Air A1475 Boot loops after replacing battery
              by trepachka
              This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
              The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
              I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
              11-08-2024, 03:17 PM
