Fish Tank LED Power Supply Gets Hot then shuts down
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8146
    Re: Fish Tank LED Power Supply Gets Hot then shuts down
    Originally posted by EasyGoing1
    Only identifying markings on the PCB are these
    SPI = Sparkle Power Inc.
    As for the caps, you really need to check the ESR, not the fluke capacitance test. I even caught my Fluke 289 telling me bull. More interesting look at the main filter cap. See what you get there.
    Hopefully we find a SPI schematic with a KA7500.
      • 31015
      http://www.danyk.cz/s_atx_en.html
        • 31015
        btw, it's not ATX, it's the older AT type supply.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8146
          Looks like it only has 2 power rails. Probably 5V and 12V. That’s it.
          Anyway suspects #1 have been pointed out. Basically all caps in the primary.
          • diif
            • Feb 2014
            • 6978
            • England
            Yes, 5v and 12v.
            A single ATX supply being used here.
            https://www.youtube.com/watch?v=KRB4PllKak4
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              The ESR says that they are good if they are under 200uF ... which they are not. But it seems to say that a lot... its a new meter just got it the other day ... cost me about $55 and came recommended by this guy, who seems to be highly respected and very knowledgable.
              sigpic
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                Originally posted by diif
                Yes, 5v and 12v.
                Looks like he adapted a "single rail" - whatever that is - ATX power supply to make it power the lights ... would have been nice if he posted a schematic or even the link to the fix that he found ... 8 years ago ...
                sigpic
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #28
                  His fix was to ditch the two supplies and switch to an ATX power supply. He uses the 12v, 5v and ground wires and the green wire to ground turn it on.
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    OK that's easy enough and might be a lot cheaper than buying the parts to repair this one ... and might even last longer. He mentioned a white wire in that video do you know what he was talking about? nvm he said green to black and white to black ... easy peasy ... now to find a single rail 500W power supply on a budget...
                    Just looked up single rail vs multi-rail and as long as I'm tying all of the 12-volt lines together it shouldn't matter which type I get, right?
                    sigpic
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      #30
                      The white wire is coming from the light, he has cut out the connector.
                      I think he is still using one of the other power supplies.
                      • EasyGoing1
                        Shock Therapist
                        • Sep 2016
                        • 977
                        You're correct he only replaced one of the power supplies with the 500W atx ... But in all reality ... you would think 500 watts could power the whole unit without needing the second power supply...
                        I'd probably have to go up to a 750 or 1000 watt PS if I wanted to replace both with one.
                        sigpic
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8146
                          what were the actual values? ESR rating is in ohms.
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            Heres how I did these readings:
                            1 - Powered on, Zero'd the meter, took the reading
                            2 - Switched modes, Zero, Read
                            3 - Switched modes, Zero, Read
                            4 - Switched modes, Zero, Read
                            5 - Zero'd, Read
                            6 - Zero'd, Read
                            sigpic
                            • EasyGoing1
                              Shock Therapist
                              • Sep 2016
                              • 977
                              I realized that I have this old Dell workstation that I was just gonna throw away ... circa 2002 model that has a 375 watt power supply in it ... figured it couldn't hurt to try it. But look at how god awful it was inside the power supply when i first took the cover off.
                              sigpic
                                • 31015
                                i would open the controller and see what the 5v is used for.
                                if it's just a few hundred mA for the controler and the leds are just 12v then just use a 12v psu and a buck convertor module
                                • EasyGoing1
                                  Shock Therapist
                                  • Sep 2016
                                  • 977
                                  That's a good idea ... cheaper for a high wattage 12V PS than an ATX.
                                  I tried it with the working PS and the Dell 375W PS but it only came on for a fraction of a second and that Dell went into shutdown mode. Too much for that wattage.
                                  Its just crazy to me that these lights could actually need 1000 watts of power to operate.
                                  sigpic
                                  • EasyGoing1
                                    Shock Therapist
                                    • Sep 2016
                                    • 977
                                    Ive got a 120 to 40 volt transformer that was removed from a 5U Rack mount APC Ups unit ... I might have some high amp 12V buck converters and I know I have some 5 volt buck converters that might be good up to 5 amps ...
                                    Just thinking of options to test that theory other than ripping that thing apart cause its a beast and I don't generally like taking things apart unless they're already broken as a general rule cause sometimes taking something apart is the beginning of the end.
                                    I COULD test the 5 volt buck converter theory using a car battery ... that should handle the power requirements without any issue
                                    sigpic
                                      • 31015
                                      you could just fire up the original working psu with a dc clamp-meter on the 5v and then 12v rails to see what it draws
                                      • EasyGoing1
                                        Shock Therapist
                                        • Sep 2016
                                        • 977
                                        You mean just connect it by itself with the ammeter on the 5 volt line?
                                        sigpic
                                          • 31015
                                          yes, run it a see how much current is flowing
                                          and recap that psu starting with the output caps and the small stuff
                                          • flibidy
                                            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                            by flibidy
                                            I have here a Magnum IA.100 which belongs to my parents.
                                            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                            What Ive done........
                                            01-01-2025, 01:26 PM
                                          • bouny56
                                            Lenovo E15 Nm-c421 usb-c work only in one side
                                            by bouny56
                                            ​Hello
                                            Laptop E15 I5 10gen
                                            Mb nm-c421
                                            I have a problem with the usb-c power dc.
                                            The motherboard start only in one side of the usb-c
                                            Replace the usb-c port 2 times same problem
                                            With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
                                            Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
                                            Can the pd controler be the fault ? Or something else maybe ?
                                            Thx
                                            02-11-2025, 03:15 AM
                                          • huzo
                                            HP Omen shuts down when loading OS
                                            by huzo
                                            The model is 15ec-1061nm
                                            Board number is DAG3EDMB8D0​
                                            SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                                            10-29-2024, 12:05 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • Stephen
                                            A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
                                            by Stephen
                                            Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
                                            05-29-2025, 10:35 AM
