ATX PSU SL-500 Short circuit can't find where? Transformer?
  • smile
    ICC ProfileGuru
    • Feb 2013
    • 120
    • Lithuania
    I got ATX PSU SL-500 PSU. Images Attached.
    It has blown VIPER22A, that I replaced.
    Connected trough light bulb the bulb glows very bright indicating a short.
    I tested every component on hot side of PCB and can't find the short circuit.
    However the problem goes away removing +5VSB transformer.
    The winding in questions of +5VSB transormer shows 0.08Ohms, is this normal?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: ATX PSU SL-500 Short circuit can't find where? Transformer?
    If you are reading 0.08Ω DC resistance on the primary winding I would say the transformer is shorted.
    A normal primary side winding resistance should be around 2Ω to 5Ω
    Secondary resistance would be normal at around 0.05Ω to 0.10Ω
    Here two examples:
    https://www.badcaps.net/forum/showpo...5&postcount=18
    https://www.badcaps.net/forum/showpo...8&postcount=60
    And here is a datasheet for a transformer that should have similar ratings, pinout may be wrong but you can see the DC resistance values:
    https://cdn.badcaps-static.com/pdfs/...5308f3be00.pdf
    From: https://www.we-online.com/catalog/en/MID-OLSTM
      • 31067
      a ring tester or component tester that has the inductance software would be handy
      • smile
        ICC ProfileGuru
        • Feb 2013
        • 120
        • Lithuania
        Thanks for suggestions, I ordered IC BH0270A, maybe it will fix it. Also looking for replacement transformer to salvage from another PSU, but so far can't find it.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          If the lamp is bright when the power supply is soft off this will not fix it.
          Because the primary power supply should be off in that case, only the Viper providing 5Vsb...
          But of course if the MOSFET inside the FSBH0270ANY PWM chip has failed shorted maybe that is what you where reading.
          But the two transformers should be completely isolated.
          And removing the 5Vsb transformer in that case would not remove the short...
          Do you have a "component tester" also called "transistor tester" or a ring tester to check the transformer with?
          • smile
            ICC ProfileGuru
            • Feb 2013
            • 120
            • Lithuania
            Well replaced the transformer for +5VSB that is for sure not 0.08ohm resistance, but the result is the same short circuit bulb shines bright. Still waiting for PWM IC.
            "Do you have a "component tester" " - Have ESR meter, miliohm meter 2 wire, inductance meter, PEAK Atlas Atlas DCA Pro.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Well since you have a inductance meter why don't you use it?
              • smile
                ICC ProfileGuru
                • Feb 2013
                • 120
                • Lithuania
                Maybe because I don't know what it should show as good/bad ?
                The resistance is very low so what is normal values?
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Here is an example from a Seasonic SS-250FS with a VEE19FRC3 5VSB Transformer:
                  Primary:
                  3.44ohm
                  1.85mH
                  444kHz
                  Q=9.2
                  Aux:
                  0.24ohm
                  0.06mH
                  736kHz
                  Q=17.8
                  Secondary:
                  0.01ohm
                  2.49µH
                  750kHz
                  Q=20.6
                  Values taken with a "component tester" so nothing fancy, but still the relative values should tell something.
                  • smile
                    ICC ProfileGuru
                    • Feb 2013
                    • 120
                    • Lithuania
                    Primary:
                    2.66ohm
                    1.89mH
                    Aux:
                    0.48ohm
                    150mH
                    Secondary:
                    0.30ohm
                    108µH
                      • Jul 2011
                      • 6040
                      Primary:
                      3.44ohm
                      1.85mH
                      444kHz
                      Q=9.2
                      Aux:
                      0.24ohm
                      0.06mH
                      736kHz
                      Q=17.8
                      Secondary:
                      0.01ohm
                      2.49µH
                      750kHz
                      Q=20.6
                      I have a question for you that is related but with a different type of tester using a blue capacitor tester and you get a 0.00 value dose this mean that this winding might be shorted because I have used it in the past with a ring tester to find possible shorted windings with this but do not know how accurate this type of testing does because I have had a switching transformer show very low or no light on the tester which is supposedly means that the winding is shorted but the device works correctly with this transformer testing this way sometimes which I have not totally understand the results of the tester
                      If a component tester does a better job telling you that a switching transformer is shorted can you please send me a link to where I can buy one that does a better job doing this type of testing
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        Primary:
                        2.66ohm
                        1.89mH
                        Aux:
                        0.48ohm
                        150mH
                        Secondary:
                        0.30ohm
                        108µH
                        Ok, in these readings you no longer are close to a dead short on the primary winding so something in your testing must have changed?
                        For another example here is a new transformer I bought by mistake related to this thread.
                        Würth Elektronik MID-OLON Offline Flyback Transformer article number: 750312279
                        Product page: https://www.we-online.com/catalog/en/MID-OLON#750312279
                        Datasheet: https://cdn.badcaps-static.com/pdfs/...dc18d6f15f.pdf
                        Note:
                        1 > 9 is Primary
                        3 > 8 is Aux
                        5 > 6 is Secondary
                        Code:
                        DC Resistance	Inductance & Q Factor				Inductance & Q Factor
                        UNI-T UT61E:	Agilent U1733C:					GM328R "Component Tester":
                        1 > 9 = 0.50Ω	730µH	100khz=Q300 10khz=Q75 1khz=Q8.0	760µH 840kHz  Q=5.0
                        3 > 8 = 0.08Ω	13.3µH	100khz=Q200 10khz=Q7.9 1khz=Q0.8	0.24µH 2424kHz Q=18.4
                        5 > 6 = 0.01Ω	2.1µH	100khz=Q100 10khz=Q2.8 1khz=Q0.3	0.22µH 2535kHz Q=5.2
                        To better understand your ring tester please watch this Youtube video linked below.
                        As you can see even one shorted ring causes a very big drop in ring oscillations, of course such a transformer still works, only a bit worse compared to when it was new.
                        It is a good way to test transformers when you don't have access to a datasheet that actually tells you what the values should be, that is its main advantage...
                        If you look at my values in the code box above here you can also see how much it differs from meter to meter: much better to have a meter that gives a more definitive result...
                        P.S: The ring tester is also available as an addon for the component tester if you use the M-firmware from madires that you can build yourself:
                        https://www.youtube.com/watch?v=QBbEYYWiBI8
                        • smile
                          ICC ProfileGuru
                          • Feb 2013
                          • 120
                          • Lithuania
                          Well I found similar transformer in another PSU, and repalced it.
                          My meter measures only uH,mH value, and resistance.
                          The readings are in post above.
                          The PSU did not start, in fact the short circuit was still there.
                          I could not find. The VIPER22A was overheating 100deg C.
                          • smile
                            ICC ProfileGuru
                            • Feb 2013
                            • 120
                            • Lithuania
                            Afterwards I decided to see what would blow if I connected direct to mains.
                            This is what blew, magic smoke came from Viper22A, diode next to it.
                            • smile
                              ICC ProfileGuru
                              • Feb 2013
                              • 120
                              • Lithuania
                              I changed the Viper22A and diode from another PSU. The Transformer was also changed (to blue colored one the resistances are not as close to the posted above) as the first one had 1ohm on primary after magic smoke came out from other parts.
                              But after connecting trough the light bulb the thermal camera shows overheating capacitor. Connecting to mains direct makes the cap explode with loud bang
                              • smile
                                ICC ProfileGuru
                                • Feb 2013
                                • 120
                                • Lithuania
                                The transistors on primary side heatsink were desoldered and tested OK.
                                The Viper22A is unknown condition.
                                Diode near viper is OK.
                                All other coponents on primary side are OK with testing using multimeter without desoldering. Any ideas?
                                • petehall347
                                  • Jan 2015
                                  • 4427
                                  • United Kingdom
                                  throw the safety light bulb away and keep blowing everything up first try .
                                  • smile
                                    ICC ProfileGuru
                                    • Feb 2013
                                    • 120
                                    • Lithuania
                                    I think you did not read whole thread, all components tested OK that is why I removed the bulb. If I had a variac I would use lower AC voltage to see what heats up. But sometimes it is more easy to let parts explode then to find the problem.
