UC384x critical cap
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8716
    UC384x critical cap
    Well I had repaired an old Antec SP350 that had a blown (IIRC) Fuhjyyu 47uF 25V capacitor for the critical cap with an Elna 47uF 25V 85°C general purpose capacitor. It works but I can bet this will fail someday...
    However I still do not have any 47uF 25V 105°C low ESR caps on hand.
    What I'm wondering... I have a small pile 100uF 50V 105°C PM capacitors... Tempted to swap that 47uF with the 100uF which should be a quality capacitor and won't die prematurely...
    But it's double the capacitance!
    I wonder what would happen if I do the swap, the PSU probably would take longer to start up, but would it do anything ... and whether I should use two 100uF capacitors in series to more closely match the original? This unfortunately is tricky as each 100uF is already like double the size of the original 47uF.
    • 31304
    Re: UC384x critical cap
    100uf will work, but the startup will be delayed a bit while the cap charges
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8716
      wondering if the slowdown would affect power good and other powerup sequencing... anyone tried?
      oh it's a Nichicon PM cap... 5000 hour, probably due to its larger than average size for a 100μF cap...
        • 31304
        unlikely, i suspect this is the standby supply,
        PG is related to the main supply
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8716
          Actually I think this PSU uses the UC384x as the main supply much like the SP300 (the SP400 seems to use a TL494).
            • Jul 2011
            • 6070
            I once did some testing on a switching power supply that had issues with supplying enough current so tried to changed the capacitor by the switching power supply regulator and either it would not power on or it did a lot wining noise so you might be able to go up a little bit higher in UF value but it might not be to double it like you are thinking about
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8716
              FSCK. Nope, was wrong, the 47uF capacitor was not the critical cap for the UC384x, it's for the 2T standby PSU... So agreed I don't think I can much with the value that much, ugh.... need to locate specific values...
              • CapLeaker
                Leaking Member
                • 8352
                I did that before in one case, because of the same reason not caving the right cap on hand. So instead of 25V 47uF I put 50V 100uF. All that happened was the power supply took now a quarter to a half of a second more to turn on. Funny thing is I did forget this until I read this thread. Guess what: That thingy I fixed still works like that. 8 years no issues.
                • iMuhtaseb
                  A1706 2017 critical update
                  by iMuhtaseb
                  this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
                  we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
                  One weird symptom is it takes too long to power on and show the Apple logo for some reason..
                  I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
                  08-13-2024, 08:41 AM
                • Alfieh
                  NAD C320BEE repair possibly bad capacitors
                  by Alfieh
                  hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
                  recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
                  11-19-2024, 04:55 PM
                • rimwall
                  Sony KD-65x7500D - double image - Tcon or Panel?
                  by rimwall
                  This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                  I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                  11-18-2025, 02:09 AM
                • netgearnetgear
                  TOSHIBA 32C100U1 - Faulty display (double images and lines)
                  by netgearnetgear
                  Good day all,
                  I have a Toshiba TV, model 32C100U1 that turns on, displays fine for 5 min, sometimes 10 min and even 25 min then it starts to show double image, wrong colours together with lines as seen in the attached. I have measured and documented the tcon voltages both when the Television works fine and when the problems described occurs. It is important to note that the voltages are the same on the tcon board. The LVDS cable, tge panel ribbon all test good. I resoldred all the main ic's connections pins, connectors and even reflowed gamma chip. I tried to block some of the...
                  10-27-2025, 08:07 PM
                • alltvrepairs
                  Hisense 55AS6G screen double sided tape required
                  by alltvrepairs
                  I need to replace the LEDs of this TV. The screen is glued with double sided tape. This video shows the proceudre required.
                  I need a source for this type of double sided tape adhesive please.
                  https://www.youtube.com/watch?v=bN6g...nel=QUADRA-NET
                  Tks!
                  07-17-2025, 09:32 AM
