A1706 2017 critical update
  • iMuhtaseb
    • Jan 2017
    • 125
    • Palesine
    this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
    we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
    One weird symptom is it takes too long to power on and show the Apple logo for some reason..
    I've taken a look into the MLB and noticed tiny liquid around Q3100.. its the USB-C gate and all ports are OK..
    Found liquid on one side of R4201 which is a buck feedback for PMU SoC for Sleep1 SW1.. the resistor itself reads 0 ohms and the side with corrosion is ground and it is also connecting to ground normally..
    I have changed the resistor anyway and taken the PMU out and reballed just in case it got liquid under it.. and also because I read on repair wiki that the symptom of critical update AND long post time is most likely liquid under the PMU..
    Sadly it did not resolve the issue.. I hate critical update on 2016/2017 models so much..
  • mon2
    • 14740
    Check the voltage to ground of the SSD rails.
    • iMuhtaseb
      • Jan 2017
      • 125
      • Palesine
      I have taken the measurements with diode mode;
      PP1V8_SSD_COLD 0.313
      PP1V2_SSD_HOT 0.343
      PP1V2_SSD_COLD 0.309
      PP1V8_SSD_HOT 0.384
      PP0V9_SSD_FIXED 0.307
      PP0V9_SSD_REG 0.254
      • mon2
        • 14740
        The diode mode readings look ok. Not shorted. Apply power and check the voltage to ground of these SSD rails. This will confirm if the rails are being powered.
        • iMuhtaseb
          • Jan 2017
          • 125
          • Palesine
          All are present and stable
          PP1V8_SSD_COLD 1.8v
          PP1V2_SSD_HOT 1.2v
          PP1V2_SSD_COLD 1.2v
          PP1V8_SSD_HOT 1.8v
          PP0V9_SSD_FIXED 0.9v
          PP0V9_SSD_REG​ 0.9v
          • mon2
            • 14740
            Looks good. Apple is anything but logical on their engineering and error messages.
            Be sure your internet connection is stable.
            Review this thread:
            https://forums.developer.apple.com/f...8022#328618022
            • piernov
              • Jan 2016
              • 4439
              • France
              https://logi.wiki/index.php/Critical...roubleshooting
              • iMuhtaseb
                • Jan 2017
                • 125
                • Palesine
                I took measurements from the display and touch connectors for Touch Bar J4402 and J4401 and found on the touch connector J4402 few lines that read high on diode mode and one OL.
                DFR_CLKIN_RESET_L was higher that expected
                DFR_TOUCH_INT_L also were higher that expected
                DFR_TOUCH_CLK_SPI_R was OL
                * I compared the numbers from another board and OBD
                All returned to the T1 chip.. I've replaced the T1 chip, reformatted the disk and reinstalled latest macOS from the internet to have all the necessary updates bundled with it.. sadly it's still experiencing from the same symptoms.
                Unable to install update and long POST times.
                • mon2
                  • 14740
                  Long post time usually means bad bios or speed is throttled due to sensor faults or missing a working sensor.
                  • iMuhtaseb
                    • Jan 2017
                    • 125
                    • Palesine
                    One thing i forgot to mention in my previous post that all lines readings returned to normal as excepted.
                    i really dont think its a sensor issue since self diagnostic does not show any errors and fan spin on normal speed.
                    i’ll try getting the bios cleaned up tomorrow.
                    • iMuhtaseb
                      • Jan 2017
                      • 125
                      • Palesine
                      Have not done the bios cleanup cause i found out when i reread the lines again that they were scrambled up again and even worse!
                      i’ve put another T1 and readings returned to normal.
                      i put powered the board bare and update is still coming and unable to proceed.. i rechecked the readings they were OK.
                      i suspect something went wrong with the lines when my colleague replaced the keyboard and its screwing things up.
                      im not putting the board back to original case and will try to find another top case.
                      What could ruin the T1 so bad and so direct? I have taken a look at the touch bar cables they were ok.
                      • iMuhtaseb
                        • Jan 2017
                        • 125
                        • Palesine
                        After putting the second T1 chip, I've put the board on a known-good top case and everything went smoothly. 👍
                        • iMuhtaseb
                          • Jan 2017
                          • 125
                          • Palesine
                          One missing feature I found out later was the touch function on the Touch Bar is missing.. display is shown normally, Touch ID is working normally with the paired Touch ID, camera is also working..
                          I thought the top case is bad but I tried another top case; same symptoms..
                          I put even a fourth T1 chip and still same issue.. what am I missing here?
                          Diode mode readings on the touch connector on the board is giving me good numbers as of OBV..
                          I compared the board around the T1 area for any missing components maybe I have knocked out but no everything is there as it should..
                          One note that I had two missing (that I fixed from first time) pads under the T1, I also looked for anything missing pads and alright.. missing unconnected pads just that..
                          • iZakre
                            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                            by iZakre
                            Hello everybody!
                            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                            The thing is that I had installed TeamViewer and could log into the computer...
                            02-19-2023, 02:27 PM
                          • Stephen
                            A1706 Critical Software update. Not Touchbar etc.
                            by Stephen
                            Computer boots and gets the software update. No visible water damage. All connections tested on another logic board and they all work. The logic board only gives this error when booting normally. Boots fine in safe mode. None the less still looking for visual damage and nothing shows damaged on the board. Board has everything disconnected except the USB C and battery so it can boot normally. Plugged up to external monitor. Boot into safe mode and I'm now trying to install Combo update and see if that works, if not any suggestions? I also checked the Wiki Critical Software update page and followed...
                            06-15-2021, 12:06 PM
                          • rilley
                            MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                            by rilley
                            I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                            I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                            My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                            And the resistor L4004 is literally burned.
                            From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                            07-10-2024, 01:57 AM
                          • PITERPENY
                            Macbook A1707 820-00281 critical update
                            by PITERPENY
                            Hello! Does anyone know what the problem might be? I've already tried everything and can't get past this window!
                            02-14-2025, 05:03 PM
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
