UC384x critical cap
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    UC384x critical cap
    Well I had repaired an old Antec SP350 that had a blown (IIRC) Fuhjyyu 47uF 25V capacitor for the critical cap with an Elna 47uF 25V 85°C general purpose capacitor. It works but I can bet this will fail someday...
    However I still do not have any 47uF 25V 105°C low ESR caps on hand.
    What I'm wondering... I have a small pile 100uF 50V 105°C PM capacitors... Tempted to swap that 47uF with the 100uF which should be a quality capacitor and won't die prematurely...
    But it's double the capacitance!
    I wonder what would happen if I do the swap, the PSU probably would take longer to start up, but would it do anything ... and whether I should use two 100uF capacitors in series to more closely match the original? This unfortunately is tricky as each 100uF is already like double the size of the original 47uF.
    • 31029
    Re: UC384x critical cap
    100uf will work, but the startup will be delayed a bit while the cap charges
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      wondering if the slowdown would affect power good and other powerup sequencing... anyone tried?
      oh it's a Nichicon PM cap... 5000 hour, probably due to its larger than average size for a 100μF cap...
        • 31029
        unlikely, i suspect this is the standby supply,
        PG is related to the main supply
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Actually I think this PSU uses the UC384x as the main supply much like the SP300 (the SP400 seems to use a TL494).
            • Jul 2011
            • 6039
            I once did some testing on a switching power supply that had issues with supplying enough current so tried to changed the capacitor by the switching power supply regulator and either it would not power on or it did a lot wining noise so you might be able to go up a little bit higher in UF value but it might not be to double it like you are thinking about
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              FSCK. Nope, was wrong, the 47uF capacitor was not the critical cap for the UC384x, it's for the 2T standby PSU... So agreed I don't think I can much with the value that much, ugh.... need to locate specific values...
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8167
                I did that before in one case, because of the same reason not caving the right cap on hand. So instead of 25V 47uF I put 50V 100uF. All that happened was the power supply took now a quarter to a half of a second more to turn on. Funny thing is I did forget this until I read this thread. Guess what: That thingy I fixed still works like that. 8 years no issues.
                • iMuhtaseb
                  A1706 2017 critical update
                  by iMuhtaseb
                  this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
                  we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
                  One weird symptom is it takes too long to power on and show the Apple logo for some reason..
                  I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
                  08-13-2024, 08:41 AM
                • Alfieh
                  NAD C320BEE repair possibly bad capacitors
                  by Alfieh
                  hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
                  recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
                  11-19-2024, 04:55 PM
                • alltvrepairs
                  Hisense 55AS6G screen double sided tape required
                  by alltvrepairs
                  I need to replace the LEDs of this TV. The screen is glued with double sided tape. This video shows the proceudre required.
                  I need a source for this type of double sided tape adhesive please.
                  https://www.youtube.com/watch?v=bN6g...nel=QUADRA-NET
                  Tks!
                  07-17-2025, 09:32 AM
                • howardc64
                  TCL 49S405 double image
                  by howardc64
                  LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                  This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                  06-23-2025, 03:20 PM
                  Meanwell Switching power supplies intermittent every capacitor under 100uf
                  Here is the eBay website link where I bought them from
                  https://www.ebay.com/itm/276135936202
                  I have been waiting for these switching power supplies to come well they came in today so I took one apart and found that it Capcon and EIite and another brand that is on my list of capacitors to replace on site it has several 0.47uf @ 50 volts ESR value twice the reading of a new one 10 UF @ 50 volts almost twice the ESR value of a new one 47 UF @ 59 volts with double the ESR value 100 UF almost the same as a new one it got replaced for good measure Iit was a brand if I see them...
                  11-25-2023, 06:05 PM
