Whirlpool washing machine L2158 control board
  • Alexbp
    • Aug 2021
    • 42
    Whirlpool washing machine help determine the resistance r085
    I will be very grateful
  • petehall347
    • Jan 2015
    • 4445
    • United Kingdom
    Re: Whirlpool washing machine
    looks like brown black green gold
    1M Ohms 5%
    • Alexbp
      • Aug 2021
      • 42
      The board shows 9 MOm
      thank you so much
        • 31260
        how many times did it blow up?
        i'm sure the factory didnt socket the psu chip!
        • Alexbp
          • Aug 2021
          • 42
          I don't know how much, and I soldered a socket to make it easier to change later.
          • CapLeaker
            Leaking Member
            • 8342
            Looks like something blew inside the socket?
              • 31260
              Re: Whirlpool washing machine L2158 control board
              blew in the socket and incinerated an inductor so hard it burned the electrolytc next to it!
              • CapLeaker
                Leaking Member
                • 8342
                What’s the part number on the IC?
                • CapLeaker
                  Leaking Member
                  • 8342
                  Sorry, but I just had to
                  • R_J
                    • 9607
                    The part number is LNK304PN. The socket pin (pin6) that is burnt should not have a connection.
                    The repair kits have other parts that are likely also bad.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8703
                      Heh. Frying a ¼W 1MΩ resistor by itself tends to need to exceed voltage rating for dielectric strength as well as thermal limits at the same time...
                      Then again, if it fails dielectric strength along the outside, then it'd dissipate less power internally...
                      • CapLeaker
                        Leaking Member
                        • 8342
                        Maybe the IC was inserted the wrong way around or a solder blob... bent pin etc.
                          • 31260
                          maybe the chip has the same weakness as TOPswitch's and oscillates itself to death if the startup cap is poor.
                          • SeSeBe
                            • Apr 2020
                            • 4
                            • Romania
                            The pin gap from the package MUST be removed from the socket to.
                            Is removed because of high voltage isolation necessary there and more, with pin removed is easy to not insert the IC wrong.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              It's not a good idea to socket PWM-FET ICs, because they use the Source/return and Drain leads for keeping the IC cool. In a socket, this won't work and the IC will overheat.
                              • Soulzink
                                Samsug washing machine. Power supply DC41-00189a board issue
                                by Soulzink
                                I am trying to fix a samsung washinmachine power supply main board.
                                I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                The power supply board reference is the following: DC41-00189a
                                I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                04-19-2025, 06:26 AM
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • Yanleb
                                LG 60PK550 Logic Control Board EBR63450301
                                by Yanleb
                                Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                C57: 3.30V
                                C61:...
                                07-20-2023, 12:38 AM
                              • Joe24
                                Maytag Whirlpool Kenmore clothes dryer data bus
                                by Joe24
                                Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                                Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                                I've been over the board looking for...
                                01-13-2025, 06:50 PM
