The ultimate protection against Bestec PSUs
  • Agent24
    I see dead caps
    • Oct 2007
    • 5069
    • New Zealand
    Got a Bestec with high 5vSB rail? This will fix it magically...
    http://cgi.ebay.com/20-pin-PC-ATX-Po...mZ280460686489
    Ever wonder what can be a quick way to make your system more stable and in the mean time extend the length of your 20pin main connector ?
    Instability of the +5VSB voltage on the motherboard can cause the system to freeze or become unstable. A simple solution is to add a large stabilizing capacitor at the connection point where the +5VSB voltage is supplied to the motherboard.
    The JDResearch MSC has this large stablizing capacitor soldered on its 20-pin male ATX power connector which is to be connected to your motherboard. The other side of the MSC is simply connected to the power supply's 20-pin connector. Installing the MSC to your system is extremely easy !
    -David VanHorn
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: The ultimate protection against Bestec PSUs
    How exactly would this do anything?
    Lets hope your 5vsb isn't over 6.3v, I have seen some bestec atx-250-12E's at almost 12v.
    It's a teapo btw.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5069
      • New Zealand
      It wouldn't, that's why it's funny
      (well, I'm sure it would do something, though nothing useful I imagine...)
      -David VanHorn
      • etnietering
        • Apr 2009
        • 379
        Well, if the instability was due to excessive ripple on the +5vsb, then it might help, but not with the problem of overvolting. And wow! 9 bucks for a 3 dollar adapter and a 30 cent capacitor!
        Good deal? ehh....not so much...
        • acstech
          GrumpyModerator
          • Jul 2007
          • 1432
          Here's my protection against Bestec PSUs...
          http://www.behrensmfg.com/hd3_1270.htm
          A man convinced against his will is of the same opinion still.
          • weirdlookinguy
            • Sep 2007
            • 1638
            and then replace with a nice Delta.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              unless it is a 12z, the 12e is the bad one.
              sigpic
              (Insert witty quote here)
              • mockingbird
                • Dec 2008
                • 5484
                I've got a Bestec ATX300-12E Revision D powering this computer and it's works great.
                  • 31247
                  sometimes that's not enough, you just have to go 20mm on the bitches!!!
                  let's hope this guy never buy's an Antec!
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3112
                    Now come on guys, you can go too overboard. Something like this will do just fine:
                    • Toasty
                      • Jul 2007
                      • 4171
                      veritas odium parit
                      • everell
                        • Jan 2009
                        • 1514
                        I don't think so!!! This gadget will not prevent 5vsb from going high....it will only filter whatever voltage is there.
                        The other solutions.....a hammer......an a-bomb......all seem rather childish. They are not solutions to the problem, only a way to vent anger and destroy any further value of the power supply.
                        This forum is power supply "design" and "troubleshooting". I think we ought to have a contest to see who can come up with the best solution to the Bestec problem. Think of it this way......if the Appolo 13 crew had a Bestec power supply powering their computer....and if it was needed to make a safe return back home to earth......what would you suggest. The NASA folks did a very spectacular job under very adverse conditions. Lets see what kind of ideas WE can come up with.
                        Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3112
                          You win. I think your dm311 mod and you hopefully upcoming next one are probably the best solution for not just a bestec but any other psu with a 2 transistor 5vsb circuit.
                          • everell
                            • Jan 2009
                            • 1514
                            NO - I have not won. There is always someone who can build a better mousetrap!
                            I appreciate the compliment, and believe that my solution was a good one - but not necessarily the best. I am open for competition - and there may be a better way. Just think....if you were to come up with a better solution......a really fantastic idea.....it could lead to a good job, maybe even a patent. You younger guys ought to pay attention, and realize that there are always dreamers who come up with better ideas.
                            I have begun the new project with the ICE3BR4765J instead of the DM311 for my Bestec project #3. I am already bogged down with some problems (challenges). The 5vsb dropped from 5.10 volts with two transistor circuit to 4.75 volts with the new chip. Playing with the two resistor values on the 431 regulator didn't produce as much change as was expected. Reducing series isolator resistance from 270 ohms to 100 ohms didn't help either. So more tinkering.............
                            The real value of a contest like this would be to realize that you only have to deal with one circuit. Everything else stays as is......so no big surprises. The 5vsb either works or doesn't work, and its voltage value is either 5 volts, too low, or too high.
                              • 31247
                              CAPRICORN-1
                              • everell
                                • Jan 2009
                                • 1514
                                Originally posted by stj
                                CAPRICORN-1
                                Capricorn 1 didn't make it back to earth, but the crew did! This is a Catch 22 situation!!
                                So I interpret this as a "political" solution - and in some respects....I think you are so right. The US government inspectors should NOT allow China to fill up our land fills with Chinese made garbage. If a high quality level is expected AND enforced, the Bestec problem would either not exist, or not have been as severe.
                                On the other hand, prevention will not make the existing problem go away. So there are solutions to be found.
                                  • 31247
                                  the solution is actually real simple,
                                  you remove the 5v standby wire from the atx cable, and bridge the 5v standbt & 5v pins on the mobo.
                                  then you bridge the 5v-standby & power-on pins in the psu and use a real powerswitch like the old days!
                                  you save electricity and have full reliability then.
                                  the only downside is that windows cant turn the pwer off - who gives a shit!
                                  if people are that lazy they shouldnt be allowed to use electricity!!
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3112
                                    Problem with that is a lot of USB ports get power from the 5vsb for whatever reason.
                                    • shadow
                                      • Feb 2007
                                      • 732
                                      Sometimes it is adjustable.
                                      I remember some of my older boards had a jumper setting to set whether the usb ports would be powered from the +5V circuit or the +5VSB circuit.
                                      Dunno if this is something that could be adjusted with a BIOS setting? Probably not is my guess.
                                      The reason why one would have the USB powered from the +5VSB circuit is to ensure that wake up from USB works (USB mice and keyboards for example)...or some people have rechargeable USB gadgets. You know thing like MP3 players, iPods etc. They can be recharged while the PC is turned off if the USB is powered from the +5VSB power circuit.
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        it was a joke, fyi
                                        sigpic
                                          ASUS ROG GX501VI-Ultimate-01 Notebook Zephyrus Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GX501VI-Ultimate-01 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GX501VI-Ultimate-01 boardview and GX501VI-Ultimate-01 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 05:46 AM
                                        • Supradin
                                          TEAC AG 980 going protection mode
                                          by Supradin
                                          Hi everyone. I'm new on this things, this is my first amplifier after I start offering repair service almost for free, just for learning purpouse
                                          So I have a amp that is going to protection mode. I saw that if I remove the ribbon cable which sends from main board B+,B- and signal for amplifiers card, is not going to protection mode.
                                          So, from that ribbon cable y disconnect everything but b+ b-, and amp goes again to protection mode. So my guess was something is wrong in the amp board.
                                          I disconnect all transistors and amp is ok.
                                          After, I connect the...
                                          Electronics forum for electronics experts to repair defective appliance.
                                          05-01-2024, 08:34 AM
                                        • waspie
                                          Aiwa GX-770 Amplifier Protection Circuit
                                          by waspie
                                          I am by no means an expert on this type of troubleshooting but I can follow direction real well.
                                          I'm no stranger to using a meter and soldering iron so I'm looking for some help in fixing an old amplifier/system I got. This is part of a system "V-1200" by Aiwa where there are several components. My first problem seems to be the amplifier.
                                          It seems to be in protection. When first turned on I hear the inital relay coming on but never the second relay which is connected to the protection IC. I don't see any obvious bad components on the board. If I ground the...
                                          11-29-2022, 09:58 AM
                                        • acedogblast
                                          [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                                          by acedogblast
                                          First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                                          Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                                          03-01-2023, 08:24 PM
                                        • AJ847.63e
                                          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                          by AJ847.63e
                                          Hi Folks,
                                          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                          05-06-2025, 10:37 PM
