Have several 600w power supplies which have taken out a TOP249yn upon power up. Just blew the face right off each one with no other signs of heat or damage. This supply is used in PMG5. Anyone had a similar experience? It's marked U801.
LiteOn PA-6601-1A (600w) blows its TOP
Re: LiteOn PA-6601-1A (600w) blows its TOP
topswitch often usees a small electrolytic to start running.
often 22 or 47uf.
always replace it, and use a good 105' type.
if the cap drops in value the top will pulse and you will hear a tick sound.
if you leave it long enough it will explode.
i'v had to fix dozens of these in satellite boxes. -
Sorry, it's a PowerMac, Toasty. The Apple part # is 661-2904. I know someone posted on one before but didn't follow through.
Question for stj -- the topswitch does have a TAICON 47uf/25v cap as you describe. Are chances good just replacing it and the TOP249YN will fix it? Also, I have some which have blown the R302 (100ohm/2w) resistor by the L301 transformer. No signs of heat or burning. Any ideas would be appreciated. Thanks.Comment
always replace a startup cap when you work on something.
if the top blew you need to check any diodes & resistros too.
in the stuff i was fixing, when the top went it took the fuse, a fuseable resistor and sometimes other stuff with it.Comment
Do components, like the SMDs, need to be unsoldered to get a good read? I have access to a Hunter Tracker which is pretty good but also from before SMDs. It bothers me that I have the same failure on a number of supplies but nothing other than an obvious blown component to show for it. Where do you start looking? The TOP obviously took a shot of current from somewhere, right?Comment
Attaching some pixs from supplies I've been working. Two basic problems- on some the F1 and R302 (2w/100ohm) resistor fail; the other U801 a TOP249YN blows the face off and no other apparent damage. I've been looking at HS2 which has two MOSFETs (Q301 & Q302). Q301 is a 17N80C3 and Q302 is a FQP7N80. Q1 and Q2 are 20N60C3s and D2 is a STTH8R06D rectifier. I have to pull from a parts board for replacements so I'm wondering if there's any way to test them on the board. My desoldering equipment leaves something to be desired. Anyway, with a DVM Q301 doesn't appear to turn on/off on boards that blow F1 and 302. Is that the kind of dead short that would take them out? I'm hoping the attached pixs might provide some ideas and direction to look. Any testing techniques also would be appreciated. Biggest issue so far is desoldering stuff without damage.Comment
Any update on your fixing this power supply? I have the same problem of F1 and R302 failing. My TOP looks fine and the caps are not swollen.
What could cause R302 to fail?
Hos did you remove the transformers when the solder is on both sides of the board. The pins are buried under the transformers making them difficult to remove the solder.
Thanks,
MichaelComment
No real way to test it except to see if it's shorted. Better to follow the path R302 is in and see where it leads to. I suspect it is connected to Q301 somehow. That may be the problem device.
Take a pic of the back of the board at R302 so we can see what or where it connects to. Something like the 3rd pic from godonr did above, only on the back. Are there any devices mounted on the bottom of this board?Comment
I'm working on 3 of these LiteOn power supplies. Two have F1 blown, R302 burnt and Q301 is bad. Both had a significant amount of dust inside. The third has blown F1 and Q301 and Q302 are bad. The bad MOSFETs show short between the drain and source (pins 2 and 3). I am attempting to locate a suitable substitute for Q301, as the 17N80C3 part seems to be obsolete and is not stocked at mouser or digikey.Comment
I've just had one of these in to repair as well. U801 (TOP249) blown it's top, I checked C852 (47uF/25V); it tested OK, but I replaced it to be on the safe side. Powered up, and nothing!
I removed the board, and then did some more investigation. I have located transistor Q856 (MMBT2907A) which had gone open circuit between base/emitter, and short circuit between base/collector. I have ordered a replacement, no other components seem faulty. I'll update this once the new transistor has been received and fitted.Comment
I'm in the process of fixing my Liteon PA-6601-1A as well. On my power supply, Q301 was shorted, which caused R302 to burn and F1 to blow. I also found that C301 and C302 were both burned. I was able to find replacements for Q301, C301, and C302 at Digikey, but I'm not quite sure what to replace R302 with. It is marked 100 ohm - 2WJ - 534. I located some 2 Watt 100 ohm resistors with +-5% tolerance. I think the "J" marking reflects 5% tolerance. It appears to be a wire wound resistor, but I'm not certain. Does anyone know if this is a wire wound resistor and if not, what type is it. Furthermore, would it really matter which type I replace it with?
I also found that the processor cooler is leaking and the coolant is crystallizing around the processors. This could be the cause of the blown power supply. I'm going to attempt a fix for this, including new o-rings and some sort of high temp silicone sealant on the outside of the o-rings. Hopefully, it didn't take the logic board with it when it blew.
Also, in case I find other problems in the supply, does anyone have a schematic and/or component list for this power supply? I haven't been able to find one online and haven't attempted to contact Liteon (probably a futile effort).Comment
It's a fusible resistor.
http://search.digikey.com/scripts/Dk...e=PPC100DCT-ND
>>This could be the cause of the blown power supply.<<
It -could- be the cause, but I've had them with no leaks fail the same way.
>>does anyone have a schematic and/or component list for this power supply<<
No schematics unless you want to draw one....
Components should be easy as most are readable. Any questions on a specific component, just ask here.
LiteOn will not release schematics. It's all proprietary.
Where did you find Q301?
ToastLast edited by Toasty; 11-29-2010, 12:26 AM.veritas odium paritComment
by cheeky2I suspect the issue is with the power supply Liteon PS-3261-9DA as apparently they are notorious for issues with them. Has anyone else had similar issues where the PC tries to boot up a few times before finally booting up. Now I have opened up the PSU which shows no signs of any capacitors failing. I did remove one capacitor that looked to have an issue however with my peak meter it showed it was within the limits with good very low esr values which was somewhat disappointing!
I am going to put a Meter leads across the outputs to see how stable they are when it occurs to see what they are... -
Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
I had no problems connecting mosfets and capacitors,...-
08-27-2024, 12:46 PM -
by SatdudeHi, I have a FSP Epsilon 600W computer PSU which had a bunch of bad caps, so I replaced them thinking they were the problem but the PSU still doesn't work. i don't have 5V standby and shorting the PS_ON to GND also doesn't turn it on. Fuse is ok and I get some inrush when plugging in. Does anyone know about any known faults in this series of PSUs?
by jm1234Hi,
I'm troubleshooting a power supply board and one opto coupler seems shorted. It's a through-hole, marked with 3 lines:
1223
816A4
W
I'm not sure what replacement to buy for it. It resembles LTV-816 (https://www.tme.eu/sk/en/details/ltv...output/liteon/), but I'm not sure it's 100% that. The data sheet shows multiple sub-types like 816M, 816S, but 816A is not there.
I do have other functional pieces on the same board, so I could do some measurements on those, but I'm not sure what to check.
Any idea appreciated. -
by MikeCebulaRequest schematic and possibly boardview for Apple 24" iMac A1225 Liteon PA-3241-02A1
Thank you,
Mike - Loading...
