LiteOn PA-6601-1A (600w) blows its TOP
  • Toasty
    • Jul 2007
    • 4171
    #41
    Re: LiteOn PA-6601-1A (600w) blows its TOP
    @godnr - you need a capacitance meter or a DMM with a cap range.
    >>And it's doubtful that I can test them without desoldering them.<<
    You didn't read the last line of my post.
    There is a large thread in here somewhere on soldering irons and stations. I think it's "recommend me a soldering station" or like that.
    Aoyue is rebranded same as BlackJack from HKFA Co., LLC ®.
    I have the BlackJack.
    Hot air station is overkill for removing or replacing these caps. Some solder-wick and a large enough tip (size-wise not heat) will do fine. Or, you can get some Chip-Quik and go that way.
    The trick is not to move them until the solder is liquid and you've popped the glue bond. Typical problem is movement of one end while the other is still bonded resulting in peeling the plating off and making it unusable. Get it flowing on both ends, then a gentle twisting action will break the glue.
    Toast
    veritas odium parit
    • vsp900
      • Nov 2010
      • 11
      #42
      I was looking at the Blackjack BK-5000. It's pretty cheap. I was going to buy one for other projects.
      How do you like the Blackjack? I could have used the hot air gun to remove a card slot from a Nintendo DS board a while back.
      I'll try to find that thread. Thanks for all the info.
      • godonr
        • May 2009
        • 111
        #43
        Appreciate the info, Toasty. All the stuff I've been doing is with "old school" Wellers and great care. As far as meters... a fluke w/o cap range (I'm from the analog deflection days) and a Huntron tracker. Nothing that gives actual values. Sorry vsp900!
        • Fallen Wolf
          =3
          • Mar 2008
          • 7
          #44
          I've got the same PSU from a friend here, but it's not fried yet.
          Only R302 was the cause for the "dying-electronics"-smell which came from his PowermacG5 (was immediately shut down when my friend located that the smell was coming from the PSU of his PowermacG5).
          R302 looks a little burned. After removing R302 it measures 100.8OHM.
          Q302, Q301, Q2, D2 and Q1 aren't shorted (yet). Everything looks fine - except R302.
          What do you think is the cause of the failing R302? Does it start to go bad from age or may be some failing caps the cause?
          I have no clue where to start - except replacing all the caps that are around the big heatsinks and replacing R302 of course.
          I appreciate any help
          • riotpack
            • Jul 2008
            • 27
            #45
            Don't forget to check the snubber and the xformer for shorted turns if you have the equipment.
            Thats not a Fuhjyyu I used in your antec PSU its a HITACHI!! rofl lol lmao funni gui!
            • Toasty
              • Jul 2007
              • 4171
              #46
              A well lit photo from side of area East and West of R302 please. Dust it out first please.
              Check Q1 for a discolored area right up the middle of the device. May need jeweler's loupe to see. Macro photo of that area is good too.
              Check C301/302 for discoloration or shade difference from end to end. Examine with bright light and mirror for cracks or discharge. Especially the heatsink side as it can hide problems. Or desolder them and physically examine. White goop on board will likely make them difficult to remove.
              Replacement of output caps should be secondary.
              Must repair the R302 problem first. Be sure to use the in-series 100w lamp to test to avoid destroying components.
              https://www.badcaps.net/forum/showpo...2&postcount=23
              Please report back.
              Toast
              veritas odium parit
              • Toasty
                • Jul 2007
                • 4171
                #47
                <snip>R302 looks a little burned. After removing R302 it measures 100.8OHM.<snip>
                That is the correct value. A 100Ω, 3w, fusible resistor.
                veritas odium parit
                • Fallen Wolf
                  =3
                  • Mar 2008
                  • 7
                  #48
                  Thanks for your answers
                  I don't think that I can check that with my multimeter (a PeakTech 3340 DDM) - or at least I don't know how to do so ^^
                  Hope that the pictures show everything
                  My desoldering-skills aren't that great, but I got the xformer out which was blocking the view on Q1.
                  There is something like a scratch or a crack on the left side and on the right side of Q1.
                  There are clearly visible shade differences from end to end of C301+C302. How do I determine the values of these and which should I take for replacement?
                  Unfortunately the 100W lightbulbs aren't sold here anymore (because of stupid EU-laws )....
                  I thought it was a 2W resistor:
                  Originally posted by godonr
                  [...]R302 (2w/100ohm) resistor[...]
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    #49
                    If 100W lightbulbs aren't being sold anymore (here neither but i stocked up ), use two 60W in parallel. One might not be enough to start the supply.
                    A working TV? How boring!
                    • Toasty
                      • Jul 2007
                      • 4171
                      #50
                      WOW!! Excellent photos!
                      My apologies. I made a mistake in designation when I said Q1. I've been on the iMac G5 PSU's so much, I screwed up. The failure on them is Q1, which is similar to this unit. Sorry you had to pull the transformer.
                      The transistor I wanted you to look at is on the solder side, right by Q301's drain (center leg). It's designation is Q352. It's very tiny so that was why I wanted the well lit macro shot.
                      The "real" Q1 is likely fine. The crack you may be seeing is probably a molding line when it was manufactured. But, if in fact there is a crack, then something else is wrong, and we'll need to pursue that.
                      C302 looks bad. No crack in casing? Regardless, replace both C301 & C302.
                      0.1uF - 400v - Metallized Polypropylene Film (there's a mouthful)
                      104K = 100nF = 100,000pF (10 + 4 zeroes) + K = 10% tolerance
                      I'm using 80-PHE426KB6100JR06 from Mouser:
                      http://www.mouser.com/Search/Product...E426KB6100JR06
                      These are the only ones I could find in stock that match dimension. They are listed as pulse film capacitors and are intended for SMPS. You need 15mm lead spacing.
                      >>I thought it was a 2W resistor:<<
                      So did I, but the new one I received looks more like a 1 watt.
                      Toast
                      veritas odium parit
                      • Fallen Wolf
                        =3
                        • Mar 2008
                        • 7
                        #51
                        Thanks for your replies
                        It doesn't feel like a crack when I move over it with my fingernail - but I'm not 100% sure.
                        The shots of Q352 are attached to this post (the autofocus of my old Canon-EOS20D is a little buggy and I don't have a macro for it, hope the pictures are okay). Q352 isn't shorted and IMO doesn't look faulty.
                        Shipping costs to Germany from Mouser are a little overkill so I searched at reichelt.de but could only find the following WIMA-ones:
                        a) http://www.reichelt.de/?;ARTICLE=32018 [WIMA MP 3-X2 275 V 0,1 UF | 100nF, 275VAC, LowESR, 110°C]
                        b) http://www.reichelt.de/?;ARTICLE=8060 [WIMA MKP-X2 275 V 0,1 UF | 100nF, 250VAC, 85°C]
                        c) http://www.reichelt.de/?;ARTICLE=12423 [WIMA MKS 4 10% 400 V 0,1 UF RM 15 | 100nF, 200VAC]
                        Which ones would be okay to use?
                        http://www.reichelt.de/?;ARTICLE=2312 [VITROHM PO593-0 5T 100 R]
                        Would this one be okay?
                        BTW: I found a 100W lightbulb still for sale at reichelt.de - hope it's still available when I order the parts there
                        • Toasty
                          • Jul 2007
                          • 4171
                          #52
                          [WIMA MKS 4 10% 400 V 0,1 UF RM 15 | 100nF, 200VAC] is close, but its metallized polyester film, not metallized polypropylene film
                          This is the right -type-, *BUT* its a 630v device and the leg spacing is too wide. It's 22.5mm where you need 15mm.
                          http://www.reichelt.de/?ACTION=3;ART...78;PROVID=2402
                          The resistor is a -fusible- resistor. Circuit protection and resistor in one. I tried their search, but I'm sure I did not get the German words correct for fusible resistor.
                          What other suppliers do you have access to?
                          Toast
                          veritas odium parit
                          • Fallen Wolf
                            =3
                            • Mar 2008
                            • 7
                            #53
                            Thanks for your reply
                            hmm...so I assume that it's not suitable as a replacement.
                            I found one at conrad.de: KONDENS. MKP4 0,100uF 400VDC 20% (Conrad Electronic) [German Datasheet]
                            Is this one suitable as replacement?
                            That's the datasheet of the Vitrohm-resistor from reichelt.de.
                            The other 100OHM 2W resistor I found at reichelt.de is this one: http://www.reichelt.de/?;ARTICLE=2277 [VITROHM BW235-0 10T 100 R]
                            It doesn't say that it's fusible. Does "fusible" mean that it goes open-circuit when it fails or what is the difference to a "normal" non-fusible resistor?
                            The ones I know of are www.conrad.de www.pollin.de www.reichelt.de and of course Ebay.
                            • Toasty
                              • Jul 2007
                              • 4171
                              #54
                              All of the listings for those caps from Conrad have reversed voltage ratings.
                              V/DC/220 400 V / AC =is really= V/DC/400 220 V/AC
                              That cap looks fine.
                              >>Does "fusible" mean that it goes open-circuit when it fails...<<
                              Yes. Exactly.
                              Toast
                              veritas odium parit
                              • godonr
                                • May 2009
                                • 111
                                #55
                                Sorry about the confusion about the wattage on R302. The one I looked at was burned and had 2W above the 100 ohm. Pulled a good one and there's a "J" (2WJ). No value ID bands to go by either. So, I guess the value is still unknown. I've got a 3W I'm thinking of trying if I can figure out what took the original out. Anyone had any success with these supplies yet?
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  #56
                                  In the 7 years or so since these were made, the technology has gotten better. I did not care for the size of the 2W I received. I chose a 3W which turned out to be a better match in size.
                                  >>...if I can figure out what took the original out. <<
                                  See Post 50 and the pics from 48 above.
                                  Also examine C303 for damage or discoloration. It probably got charred from R302 smoking, but that is not what you're looking for. Pull it and look at it carefully. Same as C301/C302 exam where any darkening of the base color (see pic in #48 of C302 by itself) indicates a problem. Mine had a tiny black spot on the R302 side. I could not determine whether it was damage from the resistor or an arc event, so I'm replacing it also. Same replacement series as the other 2.
                                  Mouser: 80-PHE426KB6470JR06
                                  http://www.mouser.com/Search/Product...E426KB6470JR06
                                  Toast
                                  veritas odium parit
                                  • godonr
                                    • May 2009
                                    • 111
                                    #57
                                    Did you loose F1 along with C303, C302, C301, R302? I have one where the obvious damage was F1 blown and R302 burned. I was looking at Q301 and Q302 failures.
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      #58
                                      Yes. Also 'upgraded' the fuse to a snap in cartridge rather than soldered in. Bought the clips and modded the board to accept. The regular ceramic fuses are cheaper than the leaded (pigtail) variety also.
                                      Toast
                                      veritas odium parit
                                      • godonr
                                        • May 2009
                                        • 111
                                        #59
                                        Did the same with F1 on the one board (not that I'm cheap or anything, ha). Have to bail right now but will follow up soon. Don't have those caps unless I take them from another board. Would rather do it right with new. Thanks for the info.
                                        • godonr
                                          • May 2009
                                          • 111
                                          #60
                                          Need to know if Q301 (17N80C3) and Q302 (FQP7N80) can be read with a regular DVM or do you need higher voltage to gate them. Q1 and Q2 respond as you'd expect but Q301 tends to read shorted and Q302 open across all legs. Also, was able to get some 301s at Mouser but not 302. Anyone have a source for it? Thanks
