General Possibly dumb question....
  • DixiePenguin
    • Mar 2008
    • 77
    • Philippines
    Hey, I have just been testing some power supplies given to me and noticed something odd. I am using an older Power Judge as a basic first check. I am getting overvoltage on reading on all three newer power supplies that are missing the old -5v wire. Is the lack of this line triggering a false reading? The others are older supplies with the -5V line and all test fine. I took an older one with -5V which I knew was bad. I got the expected overvoltage. I dug out and looked at two others I had tested earlier and had given overvoltage warnings, you guessed it, both are minus -5V.
    It just doesn't seem I could have five bad supplies that all happen to be minus the -5V line. You guys know more on the inner workings and theories, I'm just a solder monkey. What do you think?
    Bill
    Supplies w/o -5V, giving overvoltage warning:
    Dell L280P-01 24pin
    Ultra ULT-XF700s (CyberPower OEM) 20/24pin
    Bestec ATX1956D 24pin
    Hercules 450W 20pin
    Hercules 480W 20/24pin
    Bad WITH -5V showing overvoltage:
    Antec SL300S 20pin
  • DixiePenguin
    • Mar 2008
    • 77
    • Philippines
    Re: General Possibly dumb question....
    Solved it myself. Answer is YES. Older Power Judge testers misread if there is no -5V wire present. I tested with a couple of junk supplies. Green across the board on the Power Judge I was using. I then clipped the wire to simulate the missing pin in newer supplies. Presto...overvoltage warning. Reconnect the wire, everything green again. Same results on second test supply.
      master hoarder
      • May 2008
      • 12175
      PSU testers are not precise instruments so only use them to see if a PSU works (i.e. turns on). Always best to check the voltages with a multimeter if you want an accurate reading (the only better thing than that is an oscilloscope).
      Well, not much more to say. You did solve the problem yourself after all
      • iMic
        Vintage AT Power Supplies - Selecting Capacitors
        by iMic
        Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
        The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
        02-19-2023, 06:45 PM
      • SolomonMan
        HP Docking Stations Power Supplies...?
        by SolomonMan
        All,
        I recently purchased for a colleague and myself two used HP Docking Stations. They are for home use and are exact model as the ones we use at work for our laptops. We are both Software Developers.
        Anyways these docks are HP Model 5TW10UT#ABA.
        Unfortunately they did not come with there Power supplies (PSU) and I got them reasonable from eBay.
        I purchased 2 new from Amazon After Market Power Supplies(PSU). Same Voltage and Same Amperage and in fact it mentions on the Amazon page they are supported for these docks as well.
        h...
        05-09-2023, 08:04 AM
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
      • dicky96
        Air Con PCB repair : some general question
        by dicky96
        Hi guys
        I've been getting more air con controller boards of various brands for repair - mainly the ones from the outdoor compressor unit and I realise I have a lot of gaps in my specific knowledge, while being pretty good at electronic repair in general.
        Does anyone know of any good resources for information on this sort of repair? I'm hoping here there will be some guys who are experienced in this. I'd specifically like more info on how the controller PCB works, because I expect they are all pretty much the same, and especially how it communicates with the indoor unit (protocols,...
        11-22-2024, 04:40 AM
      • kingiii
        A very general question...
        by kingiii
        A very general question, when inject voltage and board draw over 4a and pull down 5v to 1v, but nothing is hot under thermal camera. Can I assume it is layer short? or it could be something very typical that I just have no idea of being a noob.
        11-16-2024, 03:58 PM
