Dual output power supply 5 and 12 volts (no output)
  • falcontech
    • Oct 2013
    • 470
    • italy
    Re: Dual output power supply 5 and 12 volts (no output)
    Originally posted by eccerr0r
    Fuse would have blew if the insulation wasn't there anyway?
    Looks like there's a pull up to shut down if the resistor blew (incidentally it seems like I see two resistors in parallel there I think, this should be the 0.49Ω resistor? Which should be a fusable resistor? And it looks like a 100Ω resistor there in parallel with something else that I can't see underneath?)
    Hmm...
    the fuse in all this is not blown, see just for the resistors, because I did not find the 0.49 one and I put two 1 ohm in parallel
    • R_J
      • 9546
      Check the VCC voltage across the small electrolytic next to the ic. Post what this voltage is.
      • CapLeaker
        Leaking Member
        • 8177
        does the psu even try to start?
        • falcontech
          • Oct 2013
          • 470
          • italy
          i've 8,2 volts, the capacitor is 47uf-35 volts
          • falcontech
            • Oct 2013
            • 470
            • italy
            no no sign of life
            • falcontech
              • Oct 2013
              • 470
              • italy
              #26
              • R_J
                • 9546
                If this is a td3843 the startup threshold is min 7.8v so the ic should be starting. It could be that it is not seeing the current sense pulse as I still don't know if that @#$% resistor is good or bad.
                You also need to check the resistor between pin6 (output) of the ic and the GATE of the mosfet, it could also be open.
                however the resistors have all been replaced, except the smallest ones that look good to the eye
                • falcontech
                  • Oct 2013
                  • 470
                  • italy
                  #28
                  which resistor are you talking about? in the previous message some strange symbols appeared however the ic is now a uc3843, the original was a Td3843
                  • falcontech
                    • Oct 2013
                    • 470
                    • italy
                    #29
                    if you are talking about the resistor you were talking about, which must be connected between the cs of the ic and the source of the mosfet, help me to understand what it could be, I am available, if you want I can make a diagram, on the part of the circuit where there is are the welds to try to understand better
                    • R_J
                      • 9546
                      If you can't trace one resistor between the CS pin and the fet, I can't help you. Go back and see post #13. It is the one in the yellow square.
                      • falcontech
                        • Oct 2013
                        • 470
                        • italy
                        #31
                        ok tomorrow I will try to bring the component diagram on the part of the welds graphically so let's see if you can understand better, in the meantime thanks
                        • falcontech
                          • Oct 2013
                          • 470
                          • italy
                          #32
                          I hope I have done a decent job
                          • falcontech
                            • Oct 2013
                            • 470
                            • italy
                            #33
                            I tested the 1kohm and 22ohm resistors, the first seems dead, the second gives me a lower value about 16.9 ohm
                            • falcontech
                              • Oct 2013
                              • 470
                              • italy
                              #34
                              replace the resistances, still nothing
                              • falcontech
                                • Oct 2013
                                • 470
                                • italy
                                #35
                                tried to replace the big capacitor and the Optocoupler nothing happens
                                • falcontech
                                  • Oct 2013
                                  • 470
                                  • italy
                                  #36
                                  is there any way to test with the tester if voltage arrives at the input of the SM transformer?
                                  • R_J
                                    • 9546
                                    What are you using as a "tester"? If it is a dvm or multimeter, just check the voltage with the ground on the negative lead of the 68µf/400v capacitor and then on the DRAIN of the mosfet.
                                    Also check and post the voltage on each pin of the ic
                                    Pin1=
                                    pin2=
                                    etc.
                                    • falcontech
                                      • Oct 2013
                                      • 470
                                      • italy
                                      #38
                                      one of this?
                                      • R_J
                                        • 9546
                                        Use either one of the multimeters, the network cable tester has no use here
                                        Post the ic voltages
                                        pin1=
                                        pin2=
                                        etc.
                                        • falcontech
                                          • Oct 2013
                                          • 470
                                          • italy
                                          #40
                                          the lan cable tester also acts as a multimeter, however can I use the yellow one? what voltage should i detect between the two points?
