This ATX PSU is off a customers computer. Originally it had a faulty motherboard GA-X58-USB3 that had a VRM fault. I fixed that and returned it working, but when he plugged it in something went 'pop' and it went dead.
I have the PC working again using my test ATX PSU so I decided to look at his PSU
Its a Xigmatek 500W ATX
When I opened it up the whole thing was full of dust, dirt and fluff.
The in-circuit fuse on the 220V input has blown
I cleaned it all out, then removed the heatsink with the Output MOSFETS that drive the main SMPS transformer. They test OK, but I noticed a small wire (looks like a component lead) down between the heatsink and the SMPS transformer and it is just sticking up in the air and doesn't do anything (see pics) I can't figure out what this is supposed to do.
The Output MOSFETS tested OK so I then removed the other large heatsink with the PFC MOSFET(s) and the main PFC circuit Diode - at least that is what I think it most likely is.
Now here is the interesting thing, one of the PFC MOSFETs looks like it has blown, in so much as the Drain and Source legs look partially melted where they enter the body, and there is some evidence of blast 'deposit' on the heatsink behind it - but the odd thing is it tests OK as an N-Ch MosFET same as it's comrade in arms next it. They are both 18N50.... But it definitely looks like it's blown even though it test just fine.
See pics.
And any suggestions? My guess is the dust/dirt/fluff went conductive around the device legs and that is what went pop, not the divice itself - and if I put it all back together it might even work - but if that is the case I have to say I've never seen that before in over 40 years messing with electronics.
Then there is that wire sticking up doing nothing useful that I can think of
Suggestions?
See pics.
Suggestions?
