Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
OCZ Powerstream PSU (Fuhjyyu 3300uF 10V)
  • Kleist
    • 15
    I have an old OCZ Powerstream 520W PSU I would like to keep using. It works currently, but I opened it up and found some bulging caps which have me worried, I would like to replace these. There are:
    4x Fuhjyyu 3300uF 10V
    What could I replace these with? Where could I buy replacements that ship to Germany?
    Thanks!
    • 31498
    Re: OCZ Powerstream PSU (Fuhjyyu 3300uF 10V)
    what diameter are they?
    • Kleist
      • 15
      What are my options? It's hard to measure with all the wires in the way, but it seems to be 10mm.
        • 31498
        panasonic FK or FS series 2700uf 10v 10mm will work
        https://www.reichelt.com/gb/en/e-cap...ct=pol_0&nbc=1
        • Kleist
          • 15
          It won't matter that they have difference capacitance values?
            • 31498
            no - not when replacing the worst caps known.
            • Kleist
              • 15
              Your comment leaves me slightly concerned about the quality of the rest of the components in here, perhaps the PSU is not worth salvaging?
              The large first stage caps are Teapo LXK 1200uf 200V 85C, are these any good?
              • dragos2009
                • Mar 2013
                • 110
                the psu is worth salvaging for the price of some caps you cannot find a psu capable of doing 520watts reliable and built this well most manufacturers skip on the quality of caps on cheaper products which is a shame seeing that the product is really well built aside from the caps
                  • 31498
                  teapo are fine on the input,
                  some of the best psu's used what i call "fukyou" caps - it does not reflect on the quality of the psu itself
                  • Kleist
                    • 15
                    Ok good to know, then I will press on with the project and replace the "fukyou"s with the Panasonic caps you linked.
                    • redwire
                      • Dec 2010
                      • 3912
                      3,300uF 10V is 12.5mm dia but common is the smaller 10mm dia parts. There are also super skinny 8mm parts but really tall.
                      I have managed to stuff in 12.5mm dia. parts in a few power supplies but it was tight.
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        While you are at it you should also replace other junk caps even if they have no signs of going bad yet.
                        I think I see a GL cap in the photo you uploaded. These are quite terrible too and should be replaced.
                          master hoarder
                          • May 2008
                          • 12182
                          See if you can find Rubycon ZLQ series @ 6.3V and 3900 uF.
                          Part number for these is usually 6.3ZLQ3900MEFC10X20
                          Although the original cap is 10V, it is probably used either on the 3.3V or 5V rail - both of which are less than 6.3V, so that's why 6.3V should be fine. As for the slight increase in capacitance from 3300 uF to 3900 uF - that should actually provide even better filtering on the output, so it's also OK to do.
                          Another option is United Chemicon KYB @ 6.3V, 3300 uF.
                          Part number for these is usually EKYB6R3ELL332MJ30S
                          Both of these options are 10 mm diameter, but the KYB is quite a bit higher (~32 mm vs. 20 mm for the ZLQ.) Just worth mentioning this, in case height is a problem.
                          Agreed.
                          Really except for the two big 200V Teapo LXK caps on the input, all other caps should be replaced. When it comes to the really really small ones... depending on where they are, you may want to replace some of those too (though certainly not necessary to replace all the tiny electrolytic caps.)
                          • golfather
                            Fuhjyyu 3300uF 35V TNR Replacement
                            by golfather
                            Hi all
                            Currently have a slight hum coming from my PC speakers when power is connected. Not audible when music is high volume but only on low volumes you can hear it in the background. Have a ferrite core on power lead but no difference.
                            System is a TEAC Powermax 1300 - same as Hercules XPS2.100 system
                            Checked the caps visually but none are bulging
                            Have been advised to change the main rectifier cap which is currently a Fuhjyyu 3300uF 35V 18x32mm (not sure what pitch, probably 7.5mm)
                            Is there a decent replacement anyone can...
                            04-16-2020, 09:40 AM
                          • Oldschool297
                            RELAND SUN 6.3v 3300uf Low or High ESR?
                            by Oldschool297
                            I found these, i would only like to try them on a board to see if it post. It don't post at the moment, i guess there are 9 6.3v 3300uf that can be broken. Is these low or high esr? I did not find info on the web.
                            https://www.amazon.de/-/en/10-Capaci...s%2C469&sr=8-1
                            08-14-2023, 04:32 AM
                          • staze
                            3300uf 16v, 10x30mm cap options
                            by staze
                            Got a Dell powersupply that has blown output caps. They're Samxon brand, and they're stupid 10mm diameter which is annoyingly difficult to find. I think they're GK series (they're labeled GK(M)).
                            I'm trying to find some type of replacement, but I can't find anywhere to buy Samxon caps, and the only caps that seem to be available in that size are only rated at 1000hrs (EKMG160ELL332MJ40S).
                            I tried dry fitting some 12.5mm diameter caps, but they won't fit.
                            Any input on options for this, or just suck it up and buy the 1000hrs Chemi-con ones.
                            02-10-2026, 10:06 PM
                          • Satdude
                            2700uF instead of 3300uF
                            by Satdude
                            Hey guys, I have a question. I need to replace the caps on my og Xbox motherboard, but I can't buy quality capacitors in my country with this specification (everything is either out of stock, with a minimum order of 1000 or just plain too big to fit in the Xbox). Can I replace the 5 3300uF caps with 5 Panasonic 2700uF caps? Thanks
                            02-12-2023, 06:23 PM
                          • EFritz20
                            Available replacements Rubycon MBZ 3300uf 6.3v low ESR?
                            by EFritz20
                            I have a few busted Rubycons MBZ 3300uf 6.3v that are used for VRM purposes on a socket A motherboard. According to spec 12 mOhm with 2800 ripple.
                            I have used the search engine and it appears the Panasonics are the ones to get, but those are topics already years old and these electronic ultra low ESR caps aren't availably anymore .
                            I can't seem to find any available caps on the known sites that are in spec of these Rubycons. Also i can't find Polymers with 3300uf or even close to that. Closest ones i found where 2000/2200uf ones but...
                            05-20-2021, 10:22 AM
