Million volt PSU?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Million volt PSU?
    No relation to the seller: https://www.ebay.com/itm/1pc-High-vo...e/312347946629
    Can such a device actually insulate to 1MV (= 1000KV)? At 1MV it should be able to jump a 30cm gap.
    Or is it really just 1KV (which makes more sense when they say the spark will jump 1 to 2 cm.)
    Dang once again people using improper units piss me off. And a lot of people are writing ads with 1000KV... GRR.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8214
    Re: Million volt PSU?
    milli volt. lol
    • diif
      • Feb 2014
      • 6978
      • England
      Chinese numbers. https://www.youtube.com/watch?v=tvHTYOa_ulA
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8214
        sand ion or sandium rofl
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          True, think I was a bit too optimistic of 1KV jumping 1cm. Based on dielectric strength of air of 3MV/m, 1cm would require 30KV. So that thing probably is no more than 50KV or so.
          Yeah looks like overinflated numbers indeed. But either way at 1MV able to jump 30cm, it'd run across the outsides of the wires to the other terminal if it can't jump directly, very difficult to insulate against 1MV.
          And yes indeed 1MV != 1mV. And that's why capitalization matters...
            • 31086
            diode gone wild has done analysis and teardown of some of those.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              For kicks, how would you build a battery powered million volt PSU? (DC, not static electricity)
              Keep in mind: 1 mA at 1 million volts is a kilowatt...
              Tesla coils probably where to start...
                master hoarder
                • May 2008
                • 12175
                This is why you need to watch ElectroBOOM videos.
                https://www.youtube.com/watch?v=DOMs7mYm_zs
