I am in need of a 21 volt switching power supply with at least 5 amp capacity
    • Jul 2011
    • 6070
    I would be open to a 24 volt @ 5 amp switching power supply that can be adjusted down to 21 volts permanently and the over load protection is still functional and low voltage cutoff 15 volt or higher if necessary
    I would rather not have to use a buck converter to get the voltage that I need
    So is anyone else that has successfully modify one for a slight lower voltage had good results willing to share with me the safest way to accomplish this task
    I googled for a 21 volt switching power supply and did not find very much information for switching power supply for above 4 amps I want something more like 6 to 8 amps for the battery pack for my battery operated air compressor
    I would prefer a meanwell switching power supply if possible but would consider other brands if necessary if you have had good results
    • 31250
    Re: I am in need of a 21 volt switching power supply with at least 5 amp capacity
    i think your going to have to try the 24v route
    • redwire
      • Dec 2010
      • 3912
      Use a 24V power supply and trim it down to 21V. Like Meanwell SPV-150-24 24V 6.25A output "adjustable 20-26.4V" $80 but not much stock.
      Otherwise I would just mod the feedback loop by adding a resistor to get the low adjustment lower. Most are 21.6V or around +/-10%.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        Maybe a used El Cheapo variable bench PSU you find at a flea market would do the trick? No mods required on getting the right voltage. Here are some 24V linear PSU’s, these should be easy to mod with an LM723. I’ve got 2 of those at work. Another solution is 2 linear PSU’s in series.
          • Jul 2011
          • 6070
          Thanks for the information
          I have decided to go with this model instead
          https://www.jameco.com/z/LRS-350-24-...y_2219823.html
          I will also try modeling to get a voltage closer to 21.0 volts if I have to
          • redwire
            • Dec 2010
            • 3912
            It looks like your standard TL431/opto circuit for regulating the voltage. The main complaint about LRS-350 is the noisy fan.
            If you post a clear pic of the underside of the board corner where the trimmer pot is, and the pot's value, can figure out which resistor to modify to get it down to 21V.
              • Jul 2011
              • 6070
              The switching power supply came in the mail today and I am a little disappointed with how they mounted the ic chips to the metal enclosure no wonder they had to use a higher speed fan to keep it cool I have another switching power supply that has better heat sinks in it and use a temperature controlled fan that I relocated the temperature sensor and mounted to the heat sink
              I going to use another enclosure for this switching power supply and use some ATX heat sinks that are much better because I have a meter that I also want to use on it as well
              On thing that did right was to have the rectifier assembly to the metal enclosure as well interesting that they thought of this
              I will post some pictures of this switching power supply when I get finished modifying it
                • Jul 2011
                • 6070
                I will post some pictures of later on today
                • kaboom
                  "Oh, Grouchy!"
                  • Jan 2011
                  • 2507
                  Diodegonewild showed the internals of some of these.
                  You don't need another enclosure, just use shims to take up the gaps.
                  Best to keep the original enclosure- we don't need to make the RFI noise floor worse than it already is.
                  To lower the output voltage more than the trimpot allows, reduce the high side divider resistor. Or parallel another across it.
                  Use one between 10x and 20x higher than the value currently installed.
                  "pokemon go... to hell!"
                  EOL it...
                  All style and no substance.
                  guilty,guilty,guilty,guilty!
                  guilty of being cheap-made!
                  • maxfolder
                    • Nov 2022
                    • 11
                    • Poland
                    Firstly, it is possible to adjust the output voltage of a switching power supply within certain limits, but this should only be done if you have the necessary skills and knowledge to ensure that it is done safely and correctly. Any modifications you make to a power supply can affect its performance, stability, and safety.
                    If you are not experienced in electronics, it is recommended that you consult with a professional or seek advice from an online community that specializes in power supply modifications. You should also be aware that any modifications you make to a power supply may void its warranty.
                    Regarding your specific requirements, you mentioned that you are looking for a 24V, 5-8A switching power supply that can be adjusted down to 21V and has overload protection and low voltage cutoff. Meanwell is a reputable brand that produces a wide range of switching power supplies, and they have several models that meet your requirements.
                    For example, the Meanwell RSP-150-24 model is a 24V, 6.5A power supply that has an adjustable output voltage range of 21.6V to 28.8V. It also has built-in overload protection and overvoltage protection, but it does not have a low voltage cutoff feature. You may need to add an external circuit to provide low voltage cutoff.
                    Another option is the Meanwell HRP-600-24 model, which is a 24V, 25A power supply that has an adjustable output voltage range of 21.6V to 28.8V. It has built-in overload protection, overvoltage protection, and overcurrent protection. However, this model may be overkill for your application.
                    In summary, modifying a power supply requires technical expertise and caution. You may want to seek advice from a professional or an online community. Meanwell is a reputable brand that produces quality power supplies, and there are models that meet your requirements, such as the RSP-150-24 and HRP-600-24.
                      • Jul 2011
                      • 6070
                      The one I bought can be brought down to 20.5 so it has no trouble adjusting to 21.5 which is what I was looking for
                      The issue have now is that when hooking up the BMS protection cable it was wired backwards from what it has on the charging circuit board and on the and on the board for the battery as well so I have to buy a couple more of them and redo it the correct way
                      I did not realize that the b1-b4 on the charger board was not the pin outs c1-c4
                      The mistake I made was that I did not check the pin connector first before I removed it from the battery pack
                      What it really is b1 is to c4 b2 is to c3 b3 is to c2 b4 is c1 really weird that it is completely backwards
                        • Jul 2011
                        • 6070
                        Well there is a very small surface mount resistor that is from the negative side of the battery pack to either the thermistor or the ID terminal I have not completely figured this out yet but I have the charger working on the modified battery packs that I bought from Battery Hookup that I posted earlier I also bought a couple of new chargers this version is a little different from the first ones that I bought it still runs very warm and this is with the cover off the top of the circuit board the switching transformer is running at about 175’F the diode double pack mounted on a heat sink running around 170*F switching transistor mounted on a heat sink running around 180*F the output capacitor running around 140*F
                        I have to mount these two battery chargers in an enclosure with a temperature controlled fans to keep running cooler than it running now
                        I post some pictures of this setup when I have it neater than what I have it right now I am just in the testing phase of it right now
                        I have not decided weather or not to cut out the primary side of the switching power supply and use the switching power that I bought for this project to begin with but I probably will do it anyway
                          • Jul 2011
                          • 6070
                          Well this battery charger has a timer and it just tripped so my plan is not going to work the way I had hoped so now I going to hook up some 30 amp BMS protection boards that I had bought for this project to begin with
                          The reason I going to use the ones I bought from Harbor Freight is because I would know when battery packs were finished charging but I will have come up with something else for that part
                            • Jul 2011
                            • 6070
                            Well I found a current meter/volt meter module that I an going to use on this project
                            https://www.ebay.com/itm/133727606583
                              • Jul 2011
                              • 6070
                              Well after 3 times resetting the charger it finally completely changed the very big battery pack
