Re: the gutless, bloated, and fried power supply hall of shame
Ok, you definitely went further than I did. I not only scrapped the PCB - I crushed it up so it'd fit in the recycling basket easier
 Same with the transformers and toroids. I kept some at home when I was still a kid as "souvenirs", since they looked neat and shiny
I also did the same exact thing as you did, judging by the picture: didn't bother with the supervisor IC - most likely useless. If a PSU DOES exhibit supervisor IC issues indeed, it's likely not worth bothering with and those that are expensive enough to justify such effort will very likely not use such an IC altogether
EDIT: I see something went pretty wrong on that PCB at one point. The area where the +5Vsb transistor is usually located (if I know my ATXs
) is charred, as is the area around those 3 resistors on the left. The cause of the heat wasn't likely the transistor itself, since it's mounted high up away from the board, but rather something around it like a smaller transistor or pull-down resistor...just a hunch...
 ). First thing I grabbed from it was the fan and some wires. A few years later when I started soldering, I completely desoldered every component just for practice.
 I think the second "+5V" column is for the -5V output.
