the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • dmill89
    • Dec 2011
    • 2534
    Re: the gutless, bloated, and fried power supply hall of shame
    Originally posted by momaka
    I guess my guess of "65%" wasn't that far off. That's truly terrible, though.
    A big part of that comes from the fact that this PSU uses a linear 3.3V rail that is derived from the 5V rail. So with your 12 Amp load on the 3.3V rail, the loses are (4.8383V - 3.3366V) * 12 Amps = 1.5V * 12 Amps = 18.02 Watts of loss just from the 5V-->3.3V rail linear regulator circuit.
    So I guess we can give this PSU the benefit of the doubt that with a more realistic PC load (either 5V or 12V heavy instead of 3.3V-heavy), the efficiency should be somewhat better - probably in the low 70% range. That's still laughable, of course.
    in order to be a little more realistic I dug an old crappy motherboard (ECS L4VCA2 socket 478 board with a 2.5 ghz Celeron) I didn't care about (since the likelihood of this POS PSU blowing up and killing the board was decent) out of the shed, fired up memtest86 and added an additional 55W 12V load in the form of an automotive headlight to simulate drives and a load on the GPU (the CPU is 61W TDP).
    The results are interesting...., while all rails are now in ATX spec, the 12V rail is on the low side and dancing all over the place (note: the 12V pics were taken with my Nikon D7000's 6fps burst mode to give you an idea of how rapidly it is fluctuating, it went from 11.784 to 11.888 to 11.783, to 11.778, 11.781 in the space of about a second, I don't own an oscilloscope but I imagine it would look pretty bad on one):
    5V @5.1834V:
    3.3V @ 3.3618V:
    Its is drawing 167W to power what should be a 110-120W load, so efficiency is still in the 65-70% range:
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Besides, anything is better than bulged CS
      Eww, I saw those kind in a PSU, likely a Coolmax, when at the former WinCycle recycling room, back in 2009 or 2008... (maybe 2010)
      They were bulging and leaking...
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        #1443
        dmill89: Just a tip, if your meter can handle somewhat high AC frequencies you can try putting it in AC mode and see what it shows on the 12v rail. (Cheap mans scope )
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          #1444
          Originally posted by goodpsusearch
          My source informed me yesterday evening that he has made another psu package for me. The packet will include:
          1) Power Innovator, Model LC-B250ATX
          2) FORCE, Model SL-800EPS (MAX 500W)
          3) FSP GROUP INC., Model FSP250-60HEN
          4) AQPPROX!, Model app550PS
          5) PANSTAR, Model PSA-235
          6) HANTOL, 550W
          7) POWERTECH, ATX-450W
          8) THERMALTAKE TR2-420 PP
          And it is for free! I am going to post pics and info about them as soon as I get them
          They're here!
          Force SL-8600EPS (MAX 600W)
          The only notable difference it has from this unit..
          ..is the fan, that is different. Here, we have a sleeve bearing Globe fan that seized and cooked the output inductor toroid coil.
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            #1445
            Powertech ATX-450W
            This was dead right out of the box. 5vsb is there, but when shorting green to ground the fan moves for a second and stops.
            Main features:
            -Fewer and fewer components used
            -Smaller and smaller parts. Just look at that cute main transformer
            -Light as a feather.
            -Super group regulation with 1 toroid coil for all voltages
            -Thin and short input caps with terribly printed sleeves
            -Funny scissors drawings appear on PCB. They tell you what to do with this pos.
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              #1446
              Hantol HPSU550
              Same model as this, but different platform.
              Fan stopped working and toroid coil started burning, as usual.
              Look at the fuse! It got so hot and then exploded violently. The metal holders started melting. Really terrible stuff.
              12A rectifier for 12V and 16A for 3.3V and 5V. This thing is still being sold and people are buying it.
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                #1447
                At best those three could do 175W-200W continuous. At least only one of them has unsafe generic Y-caps (the other two have none at all, ).
                PeteS in CA
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  #1448
                  And I doubt that the ripple will be in specs at any power draw!
                  PAN STAR PSA-235
                  This is an ATX power supply made back at 1998.
                  It has been cleaned a bit, but still has tons of dust on it. Obviously, it has seen many hours of use. It's still in working condition Well, that was before I removed 6 Teapo caps from it. Sorry, I forgot to take pictures before that.
                  The label claims it's a 235W unit, but I don't think this is possible with that tiny main transformer and 220uF primary capacitors.
                  The main transistors are 2x C4161, I couldn't find a datasheet online, but it seems they are rated for 7A, lower than 13007.
                  5vsb uses a MIP160 IC! This is something I would never expect in such an old and cheap power supply. Unfortunately, it is not rated for more than 0.6A!
                  For 12V, we get 2 diodes on a bracket and the other 2 main rails use 10A rectifiers. The label rating of 25A for 5V is a blatant lie.
                  Any comments?
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    #1449
                    And I would like to post a link to the "200W" version:
                    https://www.badcaps.net/forum/showpo...&postcount=105
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      #1450
                      Ask and ye shall receive!
                      Those heatsinks actually look credible for 235W, likewise the output inductors. But for decent hold-up time it would need 470uF input caps. If you intend to use the thing, replace those 4700pF non-agency approve line-to-ground caps! The main transformer is also too wimpy. And those output rectifiers? 8A from dual axial lead rectifiers? 14A and 25A from what appear to be two 10A dual rectifiers? For how many milliseconds?
                      PeteS in CA
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        I noticed that POS PSUs 99 or near close to 99 percent enough, have a primary failure...
                        Arc A770 16 GB
                        • RukyCon
                          A Fake Rubycon
                          • Jan 2017
                          • 816
                          A dead Athena Power "Hercules" Model: AP-MPS3ATX35
                          This power supply came out of a PC i'm fixing up.
                          From what i've been told this PSU was purchased from Fry's Electronics less than 10 years ago.
                          So this is going to be the first PC power supply i'm putting here so apologies if i make any mistakes.
                          Anyways, on to the power supply.
                          Label...
                          Does not look bad but it will be in a moment.
                          Top Side....
                          Heatsinks don't look too bad but you may notice some stuff off about this supply.
                          Bottom side.....
                          Soldering does not look very good.
                          Primary.........
                          This does not look very good.
                          The switching transistors are 2 13007's (how suprising) while the one for 5VSB is a BU3150.
                          The wires on the common mode choke look a bit thin.
                          There's no varistor and the glue appears to be hot glue.
                          The capacitors are Cheng LS 470uf 200v
                          Time for the best (or worst) part, the secondary....................
                          The s20c45c diodes are for the 3.3v and 5v rails.
                          The f16c20ct diodes are for the 12v rail.
                          All of the capacitors are EJICON KF.
                          The 12v rail has one (badly soldered) 1000uf 16v capacitor with no PI coil.
                          The 5V rail has one 1000uf 10v capacitor with no PI coil.
                          The 3.3V rail has one 1000uf 10v and one 220uf 16v capacitors with no PI coil.
                          Both the -12v and -5v rails have one 220uf 16v after a small coil.
                          The 5VSB rail has one 470uf 16v cap before a coil and a 1000uf 16v capacitor after a small coil.
                          This does have a fan speed controller but the temperature probe had a 1cm gap between it and the heatsink.
                          Speaking of the fan, here is the fan.......................................................
                          Just your typical cheap fan.
                          Not much else i can say about this unit other then it's trash.
                          I'm not a expert, I'm just doing my best.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            #1453
                            Excellent pictures! Nice quality and focus.
                            Looks like the engineer that designed this thing was high! I really hate the way parts are placed on PCB.
                            • PeteS in CA
                              • Aug 2005
                              • 3581
                              #1454
                              Well, if you put real agency approved Y-caps in place of those GP parts (and replace the fan if it's non-op) it could be a noisy but otherwise decent 225W-250W PSU. The output caps look like some less than excellent brand, though they haven't launched. Replacing them with something along the lines of PW or LXZ might be good, just because they're 10 years old. Giving the 5VSB circuit a look-over would be good, replace any small lytics. If there's room you might even consider kludging an OVP crowbar into the 5VSB output circuit.
                              PeteS in CA
                              • RukyCon
                                A Fake Rubycon
                                • Jan 2017
                                • 816
                                The fan still works but the bearing might be getting a bit dry.
                                The "Y Caps" definitely need to be replaced.
                                And if i do try to fix this power supply i most likely will use parts i have on hand.
                                • dmill89
                                  • Dec 2011
                                  • 2534
                                  I was able to get an oscilloscope (hurray for < $30 analogue scopes on e-bay) on this thing with the same load and the results are pretty bad. The scale is set to 50mv per division, looks like we're looking at 200mv+ (ATX spec is 120mv on the 12v rail and even that is pretty bad) spikes and a very solid 100mv+ ripple with a 110-120w 12V heavy load:
                                  And here's the 5V rail on the Seasonic tester with the 137W 5V heavy load, scale set to 20mv per division so we're looking at around 40mv ripple (50mv is the ATX spec on this rail):
                                  and about 50-60mv on the 12v (same 20mv per division setting):
                                  The 3.3V rail is surprisingly stable though, scale set to 10mv per division so right at 10mv ripple on this rail:
                                  While bad in general it does look like this PSU does handle a 5V/3.3V heavy load better than a 12V heavy one.
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    #1457
                                    Nice score, $30 well spent!
                                    Yea the 3.3v on these supplies are usually really silent because they are usually derived by linear regulators from 5v.
                                    So in effect they get filtered twice...
                                    This was the PSU you recapped partially with used caps right?
                                    Still looks decent for what it is, I would not expect any miracles to happen even if you recapped it fully
                                    • dmill89
                                      • Dec 2011
                                      • 2534
                                      Correct
                                      • dmill89
                                        • Dec 2011
                                        • 2534
                                        Yah I guess acceptable for what it is (a piece of crap) but still definitely not all that good overall (I realize it isn't completely "fair" to test a partially re-capped PSU either since there may be other caps that are failed but didn't bloat). I definitely won't waste time fully re-capping this though, I've got too many much better units.
                                        Here are a few comparisons (all on the 5V/3.3V heavy Seasonic tester 12V@4A, 5V@10A, 3.3V@12A with the oscilloscope in the 20mv per division setting):
                                        Rosewill branded L&C LC-8400BTX:
                                        12V:
                                        5V:
                                        3.3V:
                                        Antec Basiq BP350 (FSP):
                                        12V:
                                        5V:
                                        3.3V:
                                        PC Power & Cooling PPCMK3S600 (rebranded Seasonic M12II):
                                        12V:
                                        5V:
                                        3.3V:
                                        • RukyCon
                                          A Fake Rubycon
                                          • Jan 2017
                                          • 816
                                          I feel like something is missing from this power supply.
                                          It claims it's maximum output is 4.5-9.5v 800mA.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
