Asus PTGD-LA with 3 dead NCC KZG capacitors
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Hello, i was given a old HP PC which has a Asus PTGD-LA motherboard with 3 dead KZG capacitors on it (all three are 1000uf 16v) I'm looking at using polycaps for this recap, the capacitors i'm looking at right now are the NCC PSG series polycaps but i have not decided if i will go with polycaps yet. This is also the first motherboard i'm trying to recap (i would not care too much if i accidentally kill it) but if anyone has any tips on how to do it without killing the motherboard then i would highly appreciate if you could tell me.
    Here is the best photo i could get of the motherboard as of yet.
    I'm not a expert, I'm just doing my best.
  • Stefan Payne
    • 1267
    Re: Asus PTGD-LA with 3 dead NCC KZG capacitors
    Just go with Kemet A750, they are cheap and close enough to the original KZG.
    Those PSG don't really make sense because they are darn expensive...
    A750 are around half the price. And frankly, with a Board without an x16 PCIe I'd rather not invest much at all...
    Is that really an i915 thing with a Pentium 4??
    Anyway:
    What you really need to do is kinda preheat the board because those PCBs can really suck up heat and is also designed as a heatsink in that area...
    Do you have hot air station??
    Or something similar??
    That's rather important in this case...
    Without it, you have a big problem...
    Because its very hard to desolder them, even with a good iron...
    So preheating it is the most important thing in all of this...
    • RukyCon
      A Fake Rubycon
      • Jan 2017
      • 816
      I was going to go with Kemet A750 but the earliest i can get them (from digikey) is 2 months.
      • Stefan Payne
        • 1267
        Mouser has a couple of them:
        https://www.mouser.de/KEMET/Passive-...3&Ns=Pricing|0
        And if you don't want to order @ mouser, you can still go with Pana FM.
        They are a bit bigger than KZG - 10mm instead of 8mm but are a great replacement because about the same ESR...
        • RukyCon
          A Fake Rubycon
          • Jan 2017
          • 816
          Originally posted by Stefan Payne
          Anyway:
          I have a few hot air guns (one of witch can get hot enough to melt solder) but no real hot air station.
          Also, i don't like to buy from mouser anymore because they tend to screw up my orders somehow.
          I think the power supply may also be dead.
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3266
            • Singapore
            here's a better pic of the board off the net. from the OP's pic, it looked like the board only has 2 power phases for the cpu vrm which is misleading. it actually has 4 phases which makes it a suitable candidate for polymodding.
            so i almost ended up trolling the topic because i thought the board only had 2 phases and shouldnt be polymodded...
            • Stefan Payne
              • 1267
              That should be enough to "warm up" the board...
              The Problem with those things is that they are unregulated and you have to be pretty careful to not heat the board up too much...
              hm??
              Explain pls.
              I want to know =)
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Was that bulging and leaking just from sitting? The KZGs on my 2004 Asus A7N8X-X, looked like that, when just sitting!
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • RukyCon
                  A Fake Rubycon
                  • Jan 2017
                  • 816
                  I don't think so as there's one other KZG capacitor that is not bulging.
                  • Stefan Payne
                    • 1267
                    Maybe, but it seems that this board only has three caps between +12V CPU and CPU VRM.
                    But another thing:
                    Why are both memory sticks on one channel and don't use both??
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      One day, I was in my bedroom, IIRC, (maybe another part of 105 Main St.) and decided to check my 2004 Asus A7N8X-X motherboard, which was just sitting in a room, and discovered that the caps were doing something that I never saw them do before, at least a fair amount of the caps, suddenly looked like a volcano!
                      Arc A770 16 GB
                      • RukyCon
                        A Fake Rubycon
                        • Jan 2017
                        • 816
                        But another thing:
                        I have no idea why. :|
                        • RukyCon
                          A Fake Rubycon
                          • Jan 2017
                          • 816
                          So i said the power supply might also be broken broken so i took it apart and it was a really bad quality power supply.
                          But i think i may still have the OEM power supply somewhere.(i think it was a hipro)
                          You can see the garbage PSU here.
                          One last thing, this PC was given to me by my parents.
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            You might want to remove that CPU heatsink and check what's under it (in terms of caps). Some ASUS boards come with Chemicon TMV, which are also prone to failure and should be replaced.
                            You could also go with Wurth Electronics polymer caps if you want to keep costs low. Series doesn't really matter that much with polymers - they would be pretty low ESR already. So pick whatever is available.
                            Couldn't have said it any better.
                            It really bothers me when I see otherwise okay-ish motherboards with no PCI-E x16 (or back in the P4 days - AGP) slot. Heck, even a PCI-E x1 slot would have been nice (could open it on the back and insert a full-size PCI-E 16x GPU then).
                            Nah, it's really REALLY hard to overheat a board with a heat gun - you'd have to have your heat gun on its high setting and heat for at least 5 minutes. If you're holding the board, you'd notice way before then, as it will start burning your fingers once things heat up to 55-60C. And if you have the board resting on something, you would start to smell the hot PCB once you go past 120-130C - which is still a fairly modest temperature that most components will withstand for a few minutes just fine.
                            • RukyCon
                              A Fake Rubycon
                              • Jan 2017
                              • 816
                              Finally got around to removing the heatsink and..... all of the caps under it are NCC TMV 680uf 4v...
                              though i do have some salvaged 560uf 4v polycaps and i wonder if i could get away with using them to replace the NCC TMV caps.
                              Here is a photo of one of the 560uf polycaps i was talking about.
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                Would likely be fine. How many TMV caps are there on the board? If 6 or more, I would say it's definitely safe to replace them with the PSA poly's.
                                • RukyCon
                                  A Fake Rubycon
                                  • Jan 2017
                                  • 816
                                  about 10 of them, 5 of them appear to have failed based off the way they look (the rubber bung on the 5 of them appear to be pushed out).
                                  Note: I just spotted another KZG cap on the motherboard that appears to have not failed yet, it's a 1500uf 6.3v cap.
