the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Re: the gutless, bloated, and fried power supply hall of shame
    Here we have a USB power supply that i got for free.
    Here is the label...
    Looking good [in a bad way.]
    Seems to have the classic 100v to 240v input rating.
    Note that the output voltage is 4.5V to 9.5V! That seems to be a bit high for a USB power supply.
    Next up, the board itself.
    Note that the ceramic capacitor is not a Y-class capacitor.
    And by the way it looks. The output is is unregulated. [Explains the 4.5v to 9.5v output rating.]
    The big transistor is a 13003D and the smaller one is a C945.
    Bottom of the power supply.
    What else do you expect from a piece of crap.
    Last but not lest.
    Input: 4.7uf 400v
    Bootstrap: 0.33uf 50v
    Output: 470uf 16v
    Brands: all Y.U.B
    Overall this thing is a piece of crap and should be burned.
    I'm not a expert, I'm just doing my best.
    • PeteS in CA
      • Aug 2005
      • 3578
      • USA, Unsure of Planet
      #1342
      Originally posted by ruky con
      ... Overall this thing is a piece of crap and should be burned.
      Well, plug it in and see if it self-immolates, .
      PeteS in CA
      • RukyCon
        A Fake Rubycon
        • Jan 2017
        • 816
        I really hope that happens.
        I'm thinking of doing a stress test on this unit and see how much power it can really handle before burning up. [That's if the voltage doesn't drop out under load.]
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8677
          I've gotten one of those types of PSUs before, it's the el-cheaped out design that's missing the feedback loop to reduce costs.
          Even worse, the one I have has a half wave rectifier primary... talk about bad PF.
          • jazzie366
            • May 2016
            • 304
            What? That has full wave bridge rectification? There are 4 diodes right outside the AC input.
            Popcorn.
            • RukyCon
              A Fake Rubycon
              • Jan 2017
              • 816
              Here we go again with another cheap 5v supply.
              Label.
              At lest it has a brand this time. [Brand: Just Wireless.]
              Note that the input voltage is 12VDC.
              Top side.
              Yet again the ceramic caps are not Y-class capacitors.
              The big transistor is a 13003D and the smaller one is a C945. [This is just a copy and paste of from the last one because they're literally the same.]
              Bottom side.
              Isolation? We don't need none of that bull. Look, it works fine without it.
              Capacitor shot.
              Input: 4.7uf 400v
              Output: 470uf 16v
              Brands: Y.U.B [The same Y.U.B from last time.] JAKEC, And whatever that last one is.
              I think this thing deserves to be burned more than the last one i took a look at.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                #1347
                I've got my "test" rig built. Ill post the designs after I give mine an "extreme overtemp cutout" test.
                Follow the white rabbit.
                • lti
                  • May 2011
                  • 2547
                  That Just Wireless thing looks familiar. It appears to be isolated (poorly), unlike the one I posted a long time ago. I wonder if it would really run on 12V.
                  • lti
                    • May 2011
                    • 2547
                    The Just Wireless charger I posted a long time ago actually runs on 12V, but its output drops below 4.5V at about 2.5mA. It had the same input and output voltage rating.
                    Pictures (from 2014) for reference:
                    https://www.badcaps.net/forum/attach...5&d=1401588349
                    https://www.badcaps.net/forum/attach...6&d=1401588349
                    I missed the isolation gap for all these years. There is no copper under that white line on the bottom. I turn stupid every time I go near this thing.
                    Those two ceramic caps are not in a position where they need to be safety rated. C6 (on both power supplies) would need to be safety rated if it was populated.
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      #1350
                      I noticed this as well but was too occupied to respond.
                      I find it really strange how some PSU manufacturers put in these non-safety rated caps.
                      Why not just do the right thing (like here) and put nothing there?
                      A hell of allot safer than having something that can put mains voltage on the USB connector!!!
                      And for everything the companies making these care about: cheaper too!
                      • RukyCon
                        A Fake Rubycon
                        • Jan 2017
                        • 816
                        I'm thinking of doing a 'Running while it's on fire' test on the just wireless power supply and a 'High voltage' test on the generic one by putting a MOT across the input and output.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Coworker brought to me a Chicago Electric 2kW inverter (model 92464) that he picked up for $30. He wanted my opinion as to how well built it is ...
                          First off, note that it is a two-board design. The big board is the 12V to HV (probably around 170V or so) booster. The smaller board is the main controller, which also has 8 IGBTs on it for the DC to AC conversion. It's probably modified sine wave output because there is no output filtering inductor/capacitor (in fact not even EMI filtering!). The capacitors are the cheapo "GL" brand - the DC input caps are 2200uF 35V and the HV rail caps are 470uF 200V.
                          Oh, and, notice the two red arrows? Those point to the cables that control the booster switching FETs. Yikes! Those long, thin wires mustn't be good for high frequency switching (and at high currents too, because there are a total of 16 FETs! I checked the bottom of the booster board and there are no drivers on that board... crazy design!).
                          Next up ... um, woah!!!
                          LOL, this is why he picked it up for only $30 ...
                          Yes, all eight (8!) 30 amp fuses are blown!
                          Interestingly I can't see any scorch marks around the FETs, but I bet they are blown. I didn't even bother testing them because this thing is going to go back for a refund, LOL.
                          -Ben
                          Muh-soggy-knee
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            #1353
                            Not liking the way the live and neutral wires are botched onto the PCB on the left either...should be properly crimped spade connectors IMO.
                            Wattevah...
                              master hoarder
                              • May 2008
                              • 12164
                              #1354
                              GL caps are awesome!........................................... at failing
                              Even if this thing was designed properly, those caps would have brought it down.
                              There's a reason why some stuff from Harbor Freight are so cheap.
                              Hopefully your friend should know better now.
                              I myself shop there only for certain items that I know the quality doesn't matter to much, like cheap garden work gloves and paint brushes. Occasionally, they do have a few decent things - got a decent breaker bar for my car from there and also the "3-ton" jack stands (which probably won't hold up to 3 tons for sure, but I have a small light car, so those are okay for that).
                              • RukyCon
                                A Fake Rubycon
                                • Jan 2017
                                • 816
                                I can tell you from my personal experience that GL caps are crap.
                                I bet that thing can't output the full 2KW that it says it can do, maybe 500Watts or less.
                                • jazzie366
                                  • May 2016
                                  • 304
                                  Originally posted by goontron
                                  Your shitting me? Undersized and knockoffs of a Crapacitor brand? Vhat the fuck?
                                  Well actually, ChengX and Chang caps may or may not be bad caps. Chang caps made large appearances in older CRT tvs, and monitors. They're really common in certain older Samsung TVs. Forgot the exact model, but there was one by Samsung that was entirely Chang branded, 3 were known to fail and cause the TV to act up, but this was well after it's lifespan.
                                  As for ChengX, fakes of these are extremely common. Real ChengX caps can be found in power supplies made by Honglin, a common OEM for USB chargers. I have one that is for an old android tablet I got when I was first starting college in 2014. It's still going today, no bloating or loss of capacitance or bad ESR.
                                  I'm really unsure of the caps nature, but from what I've seen there is some small proof they might just have tarnished names.
                                  I uploaded datasheets to the depot, if you have a look at them, you can see pics in them of the real caps. Real ones should have a lot/size code (can't tell) such as "16D", model (such as GR) and the word "VENT" correctly spelled. Fakes commonly have the word, "VEHT" written on them.
                                  The ChengX should also look like this:
                                  OR
                                  Popcorn.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8677
                                    That inverter probably could support 2KW, it's big enough.
                                    However the fuse thing is kind of bothersome. Just like transistors, you can't really parallel fuses together either and that's why things like this happen. However people still do it.
                                    I have a 400W inverter that uses three 30A fuses in parallel. That's way overkill, but due to the paralleling problem, it's not really that much overkill. And just like that 2000W inverter, my inverter will also blow all (three) fuses if there's an overload. Fortunately the switching transistors were saved by the fuses.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8677
                                      (And btw Chongx or Chqngx is a bad cap...)
                                      • Dan81
                                        SNES-powered
                                        • Oct 2013
                                        • 1865
                                        #1359
                                        I don't have pics (my phone battery's dead and for some reason the two USB cables I have won't work with the genuine Samsung charger I have) but I just got a PSU today.
                                        It's some noname "400W-PIV" PSU that came with a PC I gutted. I initally thought this was a random crappy Leadman with ultra-thin heatsinks, then a Kaisen because of the thin heatsinks.
                                        It turned out to be a pretty beefy Sun Pro. D209L primary transistors, true ERL-35 transformer (I easily recognize a ERL35 transformer so I can confirm it's a true ERL35) and a VERY thick output coil.
                                        Other than that, of course, it had bulging SC caps, including on the 5vSB rail too. I'll definitely recap this though. This, and the output filtering is missing, but at least it has VERY thick diodes. (I don't really care if it uses diodes or a bridge rectifier - it's all about them being powerful).
                                        Main rig:
                                        Gigabyte B75M-D3H
                                        Core i5-3470 3.60GHz
                                        16GB DDR3-1600
                                        Samsung SH-224AB DVD-RW
                                        Delux MG760 case
                                        • Wester547
                                          • Nov 2011
                                          • 1268
                                          • USA.
                                          #1360
                                          CRT TVs / monitors aren't nearly as hard on their caps as LCD TVs / monitors are.
                                          Heh, it's only 3 years old. The real test of any bad cap is time.
                                          One could also chalk that up to the inconsistency that is characteristic of many bad crap brands.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
