the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: the gutless, bloated, and fried power supply hall of shame
    Yeah nice chunks of metal on there! I might throw it in my "recap later" pile, it's pretty well built for its time period. I find it interesting that all the Jamicon's are fine (even the 12V filtering one) and ALL of the Teapo caps are bulging
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      The metal thickness barely contributes to continuous running power. The thick heatsink is nice for quick bursts of high load, but not for long term. Also depends on how efficient the thing runs.
      Muh-soggy-knee
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        True...And it has a thermal fan controller so it would probably run warm, guessing low 70's for efficiency
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          #624
          So a heatsink this thick and huge (courtesy of larrymoencurly) doesn't contribute much to running power at all (though it does result in less room for airflow)?
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            LOL
            Muh-soggy-knee
              master hoarder
              • May 2008
              • 12164
              #626
              A thick heat sink by itself without any fins won't do much, yes. But a thick heat sink with lots of fins like the one you showed above will. The number of fins and their size/area dictates how much heat the heat sink will dissipate. Of course, if the heat sink is not thick enough in the middle, then not all of the heat from the silicon will be able to get to the fins. So the heat sink also needs to be thick in the middle in order for all of the heat from the silicon to quickly reach the fins.
              So a thin heat sink with many fins = not optimal
              A thick heat sink with very few fins = no optimal as well
              A thick heat sink with lots of fins = most optimal design
              And a thin heat sink with very little fins = cooling disaster (cheap Sun Pro PSUs come to mind here )
              • Wester547
                • Nov 2011
                • 1268
                • USA.
                #627
                Oh, I know that finless heatsinks get too hot to touch (80+ efficient PSUs IMO are the only excuse to use them, as it were). Base thickness definitely matters too... but what I did notice is that the primary heatsink in the image of larry's Hipro PSU is less impressive. It still looks thick and like it has decent surface area but it only has 3 (large and thick) fins and doesn't seem very close to the fan at all (to top it off a lot of those Hipros have a large Passive PFC mounted on the primary side which means less airflow to that section...)... I think every Hipro of that design (or remotely similar) used the same primary heatsink (even the 200W models), though in varying sizes. Maybe that's why it's rated at 250W but it could probably do 300-350W fine given how brutally overbuilt it is. Most Hipros of that time have a very nice main switcher (being a single forward design), even the 280W models, known as STW9NB90. Its on resistance isn't as low as the parts you find in 80+ PSUs but it is very overspec'd for 250W...
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Solid Gear "480W" (more like 200W) power supply, came out of an iBUYPOWER PC (now running a 650W Antec happily)...
                  http://www.psudatabase.com/solid-gea...-power-supply/
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Leadman. That would be a 0W PSU, as I doubt it would do anything at all in spec
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      That look as like a perfect candidate for modding, it has places for more capacitors, and some pi filter coils. The transformer is of a decent size too. The primary capacitors have the stripe from rubycon, but the text is wrong - not sure if they are fakes or just a different brand, I can't see their brand on them.
                      Muh-soggy-knee
                      • PeteS in CA
                        • Aug 2005
                        • 3578
                        • USA, Unsure of Planet
                        #631
                        Unless you could find a more substantial pair of heatsinks with exactly the right mounting hole placement and footprint - not necessarily impossible - and change to higher current I/P rectifiers, recapping and adding ferrite rod inductors (to reduce spike noise, IIRC) would probably just result in a fairly good 230W-250W P/S.
                        Judging from the material used for the O/P inductors, my guess is that it's a TL494 type PWM, ~30KHz, transistor switched half bridge design. So to do much better you'd have to change to I/P 'lytics (currently 470uF), change the switch transistors (currently probably MJE13007 type) to MJE13009 type (or similar current capability), and possibly the O/P rectifiers. If you have a really great boneyard of non-repairable P/Ss for the parts and lots of time on your hand, it might be an interesting/fun exercise.
                        PeteS in CA
                        • PeteS in CA
                          • Aug 2005
                          • 3578
                          #632
                          The thickness of the metal affects the thermal resistance from the heatsinked device to the rest of the heatsink. Thin metal = high thermal resistance; heat can't get out of rectifiers and switch devices, causing them to run hotter. There is a point of diminishing returns beyond which increased thickness just adds weight and cost, however.
                          Fins increase surface area, reducing thermal resistance from the heatsink to air. So more fins means better heat dissipation until the fins start significantly impeding airflow and actually hurt the heat dissipation. You can, however, also have fins that are skinny enough and long enough that the increased surface area toward the ends of the fins are meaningless for heat dissipation and only impede airflow.
                          So, "Heavy metal is goodness," is an oversimplification, looked at hypothetically. But with real-world P/Ss you are much more likely, IMO, to find wimpy and inadequate heatsinks than to find overweight heatsinks or heatsinks so over-finned as to screw up airflow. Over-sized heatsinks equals extra weight; extra weight equals higher price for the heatsink and higher shipping cost for the finished product. Wimpy is cheaper for getting product built and shipped. So I think my oversimplification is pretty much true for the real world.
                          PeteS in CA
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            I have an entire bin of case-less old PSUs - but not gonna wast e any time on this thing
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              Next gutless wonder is this iMicro "450W"
                              http://www.psudatabase.com/imicro-hp...-power-supply/
                              • jamesbo
                                • Aug 2011
                                • 36
                                The UL E Code says its made by Sirfa. But it looks like a Leadman.
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  Didn't notice that... but it does look a bit different from the Solid Gear which was a Leadman.
                                  • PeteS in CA
                                    • Aug 2005
                                    • 3578
                                    #637
                                    "I Micro" ... how appropriate. 250W I might believe. At 450W it might glow ... briefly.
                                    PeteS in CA
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      It was actually able to power an overclocked LGA775 with a 9800GX2 for a few minutes then I got distracted
                                      • PeteS in CA
                                        • Aug 2005
                                        • 3578
                                        #639
                                        You'll have to translate that into Analog, sn.
                                        PeteS in CA
                                        • shovenose
                                          Send Doge Memes
                                          • Aug 2010
                                          • 6575
                                          What do you mean??
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
