the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • cheapie
    null
    • Jul 2010
    • 849
    Re: the gutless, bloated, and fried power supply hall of shame
    If you have a cap checker, you should see how big those primaries really are. I'd bet either 330 or 470 uF.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      I can check them tomorrow. You may be right, I would want to see how heavy they are before I guess
      • LDSisHere
        • May 2012
        • 727
        • U.S.A.
        #603
        Would you mind seeing what kind of chip U2 is? I could not make it out in the pictures.
        Thanks!
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Thanks!
          Yeah no problem it says JD3310D with 12M02 date code
          • Wester547
            • Nov 2011
            • 1268
            • USA.
            #605
            Originally posted by Pentium4
            I refuse to put any Leadman unit in the build quality pictoral so I'm putting it here Although it isn't as bad as some...It has what I think are fake 1000uF NCC KMG input caps. It only has one part on the primary heatsink and it is an ST W12NK90Z MOSFET rated at 11A 900V, how many watts would this thing be good for? The secondary has a 40A schottky for 12V and 30A for 3.3V and 5V. On the 12V filtering it only has a 1500uF 25V cap
            Is this a two transistor forward design? Would this thing have ridiculous ripple?
            STW12NK90Z is a decent MOSFET that I've seen used in Delta 350W and Hipro 400W power supplies, and that means it's single switch forward... I don't know if it would do such a rating in spec with such poor output filtering, though.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Oh nice, that's good it has a decent enough heatsink too. I don't think the 12V ripple would be in spec either. I could increase it to 3300uF but it'd still be pretty high I'm sure....Wish there was a spot for an inductor, looks like there's only one on the 5V
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                This is a leadman copy of a design from an extremely obscure chinese brand, KKpower. KKpower surprisingly made a decent power supply and leadman copied it, completely screwing it up. Unsurprisingly of course.
                http://www.clubedohardware.com.br/ar...50-RSTD/1951/2
                There is the review of the 550W version of the KKpower unit (a KK9966D) and it does it quite well, except for a few hiccups at the full load test. KKpower also made a 680W version that did a full 680W no problem.
                https://www.badcaps.net/forum/showth...ol+power+gamer
                That is the leadman version of it.
                http://www.hardocp.com/article/2011/...3#.UZI327XrwTY
                And here is an actual review of it. As you can see leadman's unit fell on it's face.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Of course they screwed it up Thank you for those links. It actually did a decent amount of power but I can only imagine how high the ripple was. The original looks much better
                  • LDSisHere
                    • May 2012
                    • 727
                    • U.S.A.
                    #609
                    This chip looks like it is for the 5vsb, but I could not find much information on it.
                    http://www.jdsemi.cn/en/search.asp?k...imageField.y=0
                    Thanks for replying with the information.
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      Good find, I couldn't find practically anything on it! It must be a fairly new part
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Ahh, 820's...you're almost there Leadman! The picture doesn't do it justice but the sleeve and paint look extremely cheap
                        • Behemot
                          • 4845
                          • CZ
                          #612
                          Well, still in +-20 % tolerance And don't forget these ESR meters are not really precise in measuring these big caps. It uses only small voltage (as being powered by CR2032 cells, usually), fraction od the caps nominal.
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            But being almost brand new and so close to 820uF I figured it's probably fake And this one uses a single 12V Alkaline battery
                            • Khron
                              • Sep 2006
                              • 1350
                              • Finland
                              #614
                              They could've at least picked a series name that actually *IS* in a snap-in can...
                              Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
                                Big electrolytic capacitor is not affected by test voltage.
                                Only ceramic capacitors and some tantalum capacitors are.
                                I have found many in-spec 200V & 400V caps (from Rubycon, Nichicon, Panasonic, CapXon, Samxon etc.) But in almost all power supplies I see, at least cheap models, the primaries are fake and mislabelled.
                                • Behemot
                                  • 4845
                                  • CZ
                                  #616
                                  Yeah but sometiems even quality ones are out of spec (or on the bottom of tolerance). Also it may be that many of the biggies do not quite really like over 10 kHz frequency. Don't the meters use higher freq?
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    I know I guess they figure no one will notice
                                    Oh good to know! I wonder what brand these caps actually are, might be worth dissecting. Should I attempt at making this PSU usable or scrap it for parts?
                                      The capacitance is measured by integrating charge into it and takes several seconds to do so, the test frequency is under 1Hz for all but single-digit uF caps.
                                      The ESR is measured at 100kHz but that is not the important factor here.
                                      Yes whilst capacitors are rated +/-20% it is rare to see a quality brand depart from +/-10%. These are definitely remarked 820s in my opinion, perhaps to fool PSU review websites? The manufacturers are learning...
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        Another one of these "SH" PSU's. I find it strange that I've seen 3 of these and all 3 were from different OEM's. I'm not 100% sure who this is...It looks like an old beefed up Deer unit, but it seems unlikely they would use Teapo and Jamicon. It has some nice Fuji Electric 2SC2625 10A switchers. This thing died powering an old P4 server...Surprised it lasted 8 years. It has a ball bearing ADDA fan
                                        • PeteS in CA
                                          • Aug 2005
                                          • 3578
                                          • USA, Unsure of Planet
                                          #620
                                          Late 2003 built. TI TL494 PWM. Several lytics that are "preggers". I'd credit it as good for 250W-300W continuous, depending on the fan airflow. In P/Ss, heavy metal is goodness!
                                          PeteS in CA
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
