the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5022
    • New Zealand
    #281
    Re: the gutless, bloated, and fried power supply hall of shame
    Originally posted by c_hegge
    I bet no one thought a Delta would ever end up on here, but today I have just that - a destroyed delta. THe fan was branded T&T (Thieves & Thugs ?) and it quit. ..... The cool part is, it still runs
    Well, to be fair, it's a Delta, it still runs, it probably isn't gutless, and it was all the fault of the fan anyway.
    Certainly bloated and fried though!
    -David VanHorn
      CapXon and Ltec would fail anyway... note the unbulged Taicon, those actually seem like OK caps, haven't seen any fail YET. It's less ambient temperature and more ripple current that kills crap caps.
      • c_hegge
        • Sep 2009
        • 5219
        I removed the caps today, and I got a photo with some better light. Now you can really see how bad the heat discolouration is
        EDIT: I also took the failed fan apart, and I think there was more to this than just bad sleeve bearings. It looks like there was lots of rust around the magnet on the blade housing and on the motor
        • Behemot
          • 4845
          • CZ
          #284
          Not nice, really. In some worse fans when sometimes the magnet tends to rub against motor I lubricate it with vaseline. Maybe if you will clean it you can as well use itfor conserving again corosion.
          • c_hegge
            • Sep 2009
            • 5219
            I probably won't worry. I have a few spare Yate Loon fans which are in much better condition, so I'll probably just replace it with one of them
            EDIT: I probably should also add that the plastic washer which holds the blade housing to the motor crumbled when I took the fan apart.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5022
              • New Zealand
              #286
              I wonder if the rust is what jammed it?
              Looks like you forgot to desolder the leads of C103?
              -David VanHorn
              • Behemot
                • 4845
                • CZ
                #287
                Oh bloody hell
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  R.I.P. to that Delta. That thing is SCORCHED!!!
                  • Wester547
                    • Nov 2011
                    • 1268
                    • USA.
                    #289
                    If that power supply lacks protection circuitry of any sort, that may be why it still works with bloated capacitors.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      That one really didn't want to come out (maybe due to the generous use of glue on that leg). The other leg broke was I was trying to bend and twist the cap out of there.
                      • Behemot
                        • 4845
                        • CZ
                        #291
                        Pliers?
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Yes
                          • itwentboom
                            • Sep 2012
                            • 6
                            • England
                            #293
                            fried Apple power supply
                            There's me happily using my old Apple PowerBook 1400, then the next time I come to use it, nothing. So I open up the little brown brick (the official power supply) and was amazed to discover the destruction shown in the pik. I have no idea what caused it.
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Re: fried Apple power supply
                              Looks like a diode and two resistors burned.
                              Muh-soggy-knee
                                master hoarder
                                • May 2008
                                • 12175
                                #295
                                Wow! That really is the most toasty, well-done PSU PCB I've seen. I'm surprised the output choke didn't burn.
                                Not good.
                                Although likely salvageable if you cared enough to fix it. I would - extra spare junk fans for the random project never hurt. Sandpaper and a bit of oil is really all you need. When I find a fan that has started to get rust on the stator, I just lube it with machine oil.
                                • Behemot
                                  • 4845
                                  • CZ
                                  #296
                                  As I stated, I use vaseline, it is better I think. Oil just vaporizes or dries out due to absorption in dust. Vaseline is more durable I think and lubricates even full of dust.
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    I have a large box full of spare fans. I only ever keep really good fans nowadays.
                                    • kuzyatech
                                      • Sep 2012
                                      • 13
                                      Here is an 8 years old Antec that was still running, though a bit unstable. Nice collection of toasted caps awaits:
                                      www.kuzyatech.com My blog about things I make, break and fix
                                      • Behemot
                                        • 4845
                                        • CZ
                                        #299
                                        What model is that?? Looks like some very old topology.
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 5022
                                          • New Zealand
                                          #300
                                          Looks pretty good apart from the Fuhjyyu crap
                                          -David VanHorn
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
