the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • c_hegge
    • Sep 2009
    • 5219
    Re: the gutless, bloated, and fried power supply hall of shame
    All of the FSPs I've seen from the last few years have had DM311 based 5vsb circuits, even the low end ones with whimpy heat sinks and out of spec ripple.
    • mockingbird
      • Dec 2008
      • 5488
      #222
      None of them have it... They all use the same pi filter for the 5vsb... I've got 20-pin 250 watt, and recent 300/350-watt 24-pin models (FSP300-60THN, FSP350-PN), Remarked FSPs from Aopen, etc... They all have an almost identical 5vsb circuit and there's always two 8mm Teapo SC caps there, and they're almost always what's stopping the thing from working. I replace them with 6.3v 1200uF KZEs because I can get them cheap and they have a better ripple rating.
        master hoarder
        • May 2008
        • 12176
        #223
        The PI filter has nothing to do with the DM311 chip. The DM311 chip would be on the primary side of the PSU. Look for an 8 pin DIP chip. If those FSPs are single-transistor forward converter designs (and they probably are), you might see two 8 pin DIP chips (one being the PWM controller).
        • c_hegge
          • Sep 2009
          • 5219
          Omni 400W
          Small primary caps, No PI filter coils, not enough caps on the secondary, and the caps which are there are all from unknown brands, and it blew up at 320W on the load tester
          • mockingbird
            • Dec 2008
            • 5488
            #225
            Why are those two Teapo caps always bloating in the pi filter where the purple +5VSB goes in?
            • Jooo
              • Oct 2011
              • 222
              • Finland
              #226
              Some nasty capacitors in a old Fortron PSU.
              Surprisingly, this PSU was pulled from a working machine, and the voltages were stable... And the only capacitor that isn't bulging is Fuhjyyu, oh well.
              • Wester547
                • Nov 2011
                • 1269
                • USA.
                #227
                I don't know how right I am on this but maybe Teapos are more prone to fail by way of heat exposure than many other capacitors.
                Ironic, considering Fuhjyyu is at the bottom of the chain pretty much when it comes to capacitor quality. At least that has Panasonic primary capacitors, though those heatsinks are not impressive but at least they're not finless. I'm not surprised that it was still stable. I think it's because FSP (at least in that timeframe of PSUs) PSUs are well designed. I had a FSP300-60BTV (it had similar heatsinks) that worked fine outside of some cold booting problems; (refusing to boot unless I let 5VSB sit for two minutes or so before turning on the computer) it was later discovered that a Fuhjyyu bloated on the 5VSB rail, and that PSU had a mingling of Jamicon, Teapo, and Fuhjyyu capacitors (Teapo LXK primaries, 680uF/200V). It still worked for many years. I also noticed that your PSU has less than 1A on the 5VSB rail... not sure how common that is, for usually I don't see 5VSB as rated below 1A in PSUs, even the older ones.
                • Heihachi_73
                  • Jun 2012
                  • 713
                  Same story with my Teapo-equipped FSP200-60ATV I scrapped a few weeks ago. It worked right up to the day when I had to power off the PC (it's on 24/7), and it never came back on afterwards. I'm now seeing how long a Fuhjyyu-equipped "420W" Thermal Master will hold up in the same system.
                  • Behemot
                    • 4845
                    • CZ
                    #229
                    Omni 400W
                    Looks like some LC to me. It even has input rectifier, thermistor and some stuff, it does not seem to be so bad, and 320 W is something you can work with, right…? Gonna repair it?
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Nah, I've got lots of spare 400W+ PSUs, so a cheap 250 Watter isn't really much good to me.
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Time to blow the rest of it up :P
                        Muh-soggy-knee
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Is that light blue cap a Lelon? The PSU looks honestly rated. Are those primary Panasonic caps still good?
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            They all look to be 'YEC' brand caps.
                            YEC = YUK
                            Muh-soggy-knee
                            • Pentium4
                              CapXon Be Gone
                              • Sep 2011
                              • 3741
                              Omni 400W
                              That thing looks pretty bad...It looks similar to one I threw away a while back. Wow, look at all those spots on the secondary for more caps...And to be honest, I'm surprised it could even do 320W! It probably wasn't in spec though. What died when it blew up, the secondary diodes? Those heatsinks don't look too good
                              YEC = YUK
                              Ohhh that's right, YEC are also light blue... YUK indeed
                                master hoarder
                                • May 2008
                                • 12176
                                #235
                                Good question, but I don't think I can answer it. Most likely they just get overexposed to heat, as Wester547 suggested. Perhaps there's a hot spot there. Or maybe the caps were not correctly specced for that circuit.
                                I just fixed the 2-transistor 5vsb circuit of an old 235-watter. The output caps were failed, and putting any load over 100 mA would make the voltage oscillate all over the place between 4V and 5V with lots of audible noise. When that happened, the second rail produced by the 5VSB transformer (normally 12V - used for powering the driving transformer for the BJTs on the main power supply) would jump to over 30V! That was all bad news for the 16V, 47uF cap that was filtering that rail. I then changed the output caps on the 5VSB with 2x very low ESR caps (one is actually motherboard grade), and the 5VSB is now solid as a rock and stable right at 5.01V, even with 800 mA of load. I have no doubts it will do fine at higher loads.
                                • Wester547
                                  • Nov 2011
                                  • 1269
                                  • USA.
                                  #236
                                  That thing looks pretty bad...It looks similar to one I threw away a while back. Wow, look at all those spots on the secondary for more caps...And to be honest, I'm surprised it could even do 320W! It probably wasn't in spec though. What died when it blew up, the secondary diodes? Those heatsinks don't look too good.
                                  Switching transistors are far more commonplace in terms of failure than diodes or rectifying bridges (because they usually get decent airflow that's why they get away with using diodes in place of rectifying bridges in some very cheap PSUs, as has been noted before).
                                  As for those Teapo capacitors, it could just be an inadequate batch as well. But Teapos may also fail around or on the 5VSB rail because the 5VSB rail (I might be wrong on this) is more often active than any other rail on a PSU (as it is still active when the system is 'soft-off' or 'soft-on"), so the capacitors on that rail are almost always working to some extent unless AC power is cut.
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    ...I'm surprised it could even do 320W! It probably wasn't in spec though. What died when it blew up, the secondary diodes? Those heatsinks don't look too good
                                    No, it wasn't in spec. The switchers exploded at 320W. They were 13007s, and that's usually where they blow up.
                                    • tleu8472
                                      • Dec 2011
                                      • 36
                                      #238
                                      I have one of those Omni 400W PSUs which I want to use to power an old P4 machine. Was the ripple bad? Can you suggest some modifications I can make to improve it? What caps should I add/replace on the output filtering? Many thanks.
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        Seeing how very few filter caps there were, I would guess that the ripple was terrible. It's also missing PI filter coils.
                                        Muh-soggy-knee
                                        • tleu8472
                                          • Dec 2011
                                          • 36
                                          #240
                                          What uF and voltage ratings should I use to add/replace the secondary filtering caps? It does have resistors instead of coils - will this suffice for what will probably be a 250W max load system?
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • serwanjaf7
                                            hp victus (la-m787p) hall sensor problem
                                            by serwanjaf7
                                            hello friends
                                            pls i need help with hp vicuts it have problem on the hall sensor i want to change it bu i dont find and i dont now what is the part no
                                            pls need help
                                            thank you...
                                            12-08-2025, 01:23 AM
                                          • x_orange90_x
                                            Samsung UN65AU8000FF fried by water
                                            by x_orange90_x
                                            I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
                                            10-16-2025, 08:40 PM
