the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: the gutless, bloated, and fried power supply hall of shame
    Got some more to share. First up is a Solytech unit that just had some Teapo's die. Going to replace them soon. Some look like they are hard to get to. After a recap this thing is going to be a pretty solid power supply. Manufactured December, 2005. Tell me what you guys think of it.
    Can't tell if some of the joints are heat damaged, does it look like it?
    Up next is this piece of garbage from an unknown brand, try not to laugh too hard at the brand name....It claims to be a 400W PSU. Maybe it wouldn't be so bad after replacing the Jpcon and Fuhjyyu caps, but those transformers look pretty wimpy, as well as the 4 diode treatment and next to nothing for transient filtering...
    Is this junk worth doing anything to, salvaging anything off it, or is it a tosser?
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      LOOOOOL!!!
      'icute'
      and I see the cheapo-teapos are bulging again!
      Muh-soggy-knee
      • c_hegge
        • Sep 2009
        • 5219
        Ohhh, now isn't that cute?
          master hoarder
          • May 2008
          • 12175
          #204
          Hmmm... Dajavu or what? This is the same exact PSU as the ones that Mockingbird posted.
          Do yourself a favor and junk them already. I have at least one unit from almost all low-end ATX platforms lying around, and the one you have is the worst.
          I disagree.
          While these PSUs are very wimpy in terms of guts, they can actually be quite decent if you put good parts in them since they are based on CWT's ISO line. And unlike other cheap PSUs, the soldering in these is actually good. See this thread:
          https://www.badcaps.net/forum/showth...hlight=CWT+ISO
          Again, the Cyberlink I had was powering a 64W TDP Pentium 4 which peaks at ~80W max under full load. The Cyberlink is only able to provide 75W on the 5V rail, yet the PC seems to have worked for at least a year. The ECS motherboard from that PC is still fine - I'm using it as my gaming computer .
          Originally posted by mockingbird
          Am I right in assuming I'm looking at the three TO-220 packages on the secondary side? Here are the markings:
          1) STPR1020CT
          2) STPS1545CT
          3) STPS1545CT
          Looking at the datasheet for the STPS1545, it's a 15A part... The datasheet for the STPR1020CT says "2 x 5A", is this my 12V rectifier!?.
          Yes.
          So it terms of "raw" DC current, your PSU is good for 10A max on the 12V rail, or 120 W.
          Tracing back the 12V circuit, yes, I see that I've got that same Fuhjyyu TM 16V 680uF cap which obviously is filtering it alone because the coil is missing for the pi filter...
          Ok, ok, you're starting to convince me... Let me ask you this... Let's say I switched the 16V 680uF cap with some nice, highly rated 10mm cap with a higher capacitance (Or should I stick to the same capacitance), would this help me any?
          If you want to have a fairly clean, stable power output it's good to have at least 2x 2200uF caps on the 3.3V rail, 2x 2200uF caps on the 5V rail, and either 2x 1000uF or 1x 2200uF cap on the 12V rail, 1x 1000uF on the -12V rail, 1x 470uF on the -5V rail, and 2x 680uF on the 5VSB - all with PI inductors between each set of caps (-5V and -12V rail excluded).
          With that, you should be able to run your Semprons fine, although the PSUs may run a bit warm.
          All in all, though, I would say just use them for parts. And reason I say that is because the primary side of these PSUs is not that great either (it's missing all of the input filtering and the bulk caps are tiny).
          These PSUs do work great for powering small electronic projects, though.
          • c_hegge
            • Sep 2009
            • 5219
            If there is no input filtering, I just junk it on sight. Re-building them is more trouble than it's worth IMO.
            • everell
              • Jan 2009
              • 1514
              Power supplies without input filtering tend to have more bulging capacitors on the output side than power supplies with input filtering. I wonder why???? There IS a direct correlation.
              Conclusion: Power supplies with good input filtering give superior long term performance.
              Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
              • Agent24
                I see dead caps
                • Oct 2007
                • 5083
                • New Zealand
                #207
                I would say that power supplies without input filtering are also more likely to have crappier capacitors, and also more likely that the capacitors would be under-rated for the application.
                -David VanHorn
                • PeteS in CA
                  • Aug 2005
                  • 3583
                  • USA, Unsure of Planet
                  #208
                  A company that would cheap out by omitting the AC I/P filter is also likely to have used crappy quality caps and used parts whose ratings are barely adequate (hypothetically adequate, of course).
                  PeteS in CA
                  • kaboom
                    "Oh, Grouchy!"
                    • Jan 2011
                    • 2507
                    ICute ,=ICrush
                    "pokemon go... to hell!"
                    EOL it...
                    All style and no substance.
                    guilty,guilty,guilty,guilty!
                    guilty of being cheap-made!
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      I was going to post a Logisys here but we needed a PSU for our phone server...
                        master hoarder
                        • May 2008
                        • 12175
                        #211
                        You should pull the schottky diodes at least. Many OEM PSUs from HiPro, Bestec, and LiteOn have extra spots for more schottky diodes. Adding them in improves the efficiency and makes the PSU able to handle more current on that rail. I'm doing that right now on a Bestec ATX-250-12Z.
                        • everell
                          • Jan 2009
                          • 1514
                          Bestec?
                          Folks talk about Bestec being so bad......throw away on site........maybe worse than Powmax!
                          • c_hegge
                            • Sep 2009
                            • 5219
                            The real cheapies don't usually have any schottky diodes. More often than not, they are just low capacity fast recovery rectifiers, which aren't worth scavenging.
                              master hoarder
                              • May 2008
                              • 12175
                              #214
                              Originally posted by everell
                              Bestec?
                              Bestec is fine by me.
                              Although, if given a choice of OEMs, I would pick HiPro, Delta, or LiteOn (in that order).
                              On the 12V rail yes. But on the 5V and 3.3V rail, they are *always* schottky diodes (at least I haven't seen one that doesn't so far). Most of the time, the 5V and 3.3V rails have 15A or 20A schottkys (sometimes 30A if you are very lucky).
                              Many OEMs are single-transistor forward-converter PSUs, so you can use those low voltage schottky diodes from the 5V and 3.3V rails of the cheap PSUs on the 12V rail of the OEMs without problem.
                              The 250W Bestec I have has a single 20A, 45V schottky on the 12V rail and an empty spot for another one. I'll be adding a second 20A schottky in there. This will boost the raw capacity to around ~25A. Not that the power supply can do that much, but I will be using it with a 105 W TDP CPU, so boosting the efficiency will matter in this case.
                              By the way, I got that 20A schottky from a cheap Meico/Q-Tec PSU. In case you are wondering, it's one of these:
                              https://www.badcaps.net/forum/showth...ighlight=m-tec
                              I've used parts from that PSU to fix many other PSUs.
                              • mockingbird
                                • Dec 2008
                                • 5486
                                #215
                                This doesn't make any sense coming from you.
                                You're re-capped many Bestec PSUs and I have a few here I was even going to ask you about when I got around to re-capping them (Relocating the cap near the diode that gets really hot, my Bestec is a slightly different revision than the one you posted this mod with).
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  Most of the time, the 5V and 3.3V rails have 15A or 20A schottkys (sometimes 30A if you are very lucky)...
                                  I don't scavenge anything below 30A. The other problem is that the rail which usually needs the extra capacity is the 12V, and you can't often use the 40v VRRM rectifiers (which most cheapies have on the 5v and 3.3v rails) on 12V Rails.
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    #217
                                    Again, you're only half-correct.
                                    For half-bridge topologies, you are right.
                                    For single-transistor forward-converts, the reverse blocking voltage of the rectifier can be quite low - just only a bit higher than the rectified DC voltage.
                                    He was joking
                                    • everell
                                      • Jan 2009
                                      • 1514
                                      He was joking
                                      Momaka is right, I was only joking. I have fixed and modified several Bestecs, and I think they are just as good as HiPro. I am running a Bestec ATX-400 on this computer because a recapped Antec Smart Power 450 watter kept giving problems.
                                      As opinions go................I think that only morons trash or gut a Bestec while trying to modify and improve a Deer/L&C/Solytec or Powmax power supply!
                                      The biggest problem with the mobo killer Bestec ATX-250 12E was a flawed 5vsb circuit. The problem was KNOWN long before I made the DM311 mod and showed that it is then a useful reliable power supply. Too many were bad mouthing Bestec instead of working the problem. For quite a while I took a lot of heat because I said the Bestec 12E was a good psu after my fix.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        #219
                                        Perhaps the current Bestecs are, but the older ones (250W and 300W) aren't IMO. HiPro have always used massive heat sinks and very over-specced rectifiers. Bestec - not so much. Usually just enough to cover what's on the label, but not much more than that.
                                        I just finished recapping that Bestec ATX-250-12Z today. Don't get me wrong, overall it's a good PSU, but it still has some minor issues/quirks that make me feel uneasy about it.
                                        #1 - it cross-loads very easily.
                                        I just tested it in a old Duron 750 MHz PC (which pulls power from the 5V rail). It's a 35W TDP CPU. Despite that, the 12V rail was quite high: 12.56V (just 0.04V shy of out-of-spec). The 5V rail was only mildly high: 5.10 V. <---- This shouldn't happen. Instead the 5V rail should dip below 5V in order to keep the 12V rail from getting close to being out-of-spec.
                                        I then tested the Bestec on a 12V-based system (socket 939 Sempron 64 3400+). That one, the CPU is 59 W TDP, IIRC. 12V rail was still a bit high at 12.22 V while the 5V rail was also high (5.15V). <--- again, this should NOT happen.
                                        Now compare that to my 250W HiPro, which regardless of whether I try it in a 5V PC or 12V PC, both rails are always close to their true value. FYI, both that Bestec and the HiPro are group-regulated PSUs so there's no excuse for Bestec's performance.
                                        This is not unique just for my ATX-250-12Z either - it happens on my Bestec ATX-1956D as well (except for that one, the 12V rail is too low).
                                        All in all, though, I do trust that Bestec, so likely after some more testing, I will be using it in one of my computers.
                                        #2 - the active load circuit on the -12V rail
                                        I simply dislike it. It can easily overheat and get out of control. I really don't understand why Bestec put such a complex (for its task) circuit in there instead of just increasing the voltage magnitude of the -12v rail and using a linear reg like the HiPro does.
                                        • mockingbird
                                          • Dec 2008
                                          • 5486
                                          #220
                                          Really? I'm still using the SP-450 I re-capped in this thread.... What sort of problems were you having with it? I noticed you tried to mod the 5vsb with this one and you had to use a different IC for the mod.
                                          I have several of them here waiting to be re-capped as soon as I get around to it.
                                          Do you think you could do your fix on a Fortron one of these days and document and photograph it for the amateurs?
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • x_orange90_x
                                            Samsung UN65AU8000FF fried by water
                                            by x_orange90_x
                                            I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
                                            10-16-2025, 08:40 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
