Recapping Antec SmartPower SP350 and SP400
  • everell
    • Jan 2009
    • 1514
    I have recently acquired two Antec SmartPower psu, SP350 and SP400. The SP350 required a lot of repairs before recapping. The critical 5vsb capacitor esr was greater than 99 on Blue esr meter, so high +5vsb voltage and other component failures. The SP400 critical 5vsb capacitor had esr of .86, still measuring 5 volts. Both had lots and lots of Fuhjyyu capacitors. I have replaced nearly all with Nichicon PW caps, but had to order some of those small diameter ones from topcat.
    What remains to be done: the SP350 has Fuhjyyu mains 680 uf/200 volts, and the SP400 has Fuhjyyu mains 820 uF/200 volts. Does Fuhjyyu main caps also give problems big enough to require replacement?
    Both psu boards had one .1 uF/50 volt cap and one .22 uF/50 volt cap. Also Fuhjyyu. Nichicon does not make low esr capacitors for these small values. I need to look at what circuits they are in to determine if a ceramic or plastic capacitor could be used, or if a general purpose aluminum capacitor would be OK. Any suggestions?
    And finally, each psu got a 5vsb modification - add on board with DM311 chip. Hate to invest time and money in a psu with a loser (2 transistor circuit) for 5vsb. Here are some photos showing the add on modification board.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • etnietering
    • Apr 2009
    • 379
    Re: Recapping Antec SmartPower SP350 and SP400
    My logisys had Fuhjyyu's on the primaries, and one of them was bulged, so I'd definitely recommend junking them for something better. I don't know about the little caps though.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      I have had small caps cause problems. On a sunpro raidmax 450W it would sometimes power up and sometimes not, and when it did power up it had wild voltage fluctuations. The small caps were mostly 50v, 1, 2.2, and 10uf GoldLink brand caps. Somehow just changing the small caps fixed it. I used some small rubycon's and taicon's I have scavenged over time though. UCC also makes the 50v, 1 and 2.2uf low esr caps.
      • Toasty
        • Jul 2007
        • 4171
        Everell,
        I can't find the schematic or parts list for this DM311 mod of yours. I find bits of it in the Bestec posts, but it includes all the Bestec PSU components, not this circuit by itself. I thought you had posted it, I just can't locate it...
        Would you point to it with a link please?
        Toast
        veritas odium parit
        • Toasty
          • Jul 2007
          • 4171
          There is a discussion on a question PCBONEZ raised from a month ago about using electrolytics instead of ceramics for the small values.
          https://www.badcaps.net/forum/showthread.php?t=8187
          Toast
          veritas odium parit
          • everell
            • Jan 2009
            • 1514
            Originally posted by Toasty
            Everell,
            Toast
            I don't remember ever posting just the DM311 circuit by itself - I always made a schematic for the entire 5vsb section for the particular board I was working on. Each psu is a little different, most are straight forward, but not all. The Powerman psu required a bleeder resistor to prevent oscillation when shutting down. The SeaSonic had loading problems and would not turn on until I reduced the filter capacitor which was loading it too much. Found out later SeaSonic doesn't work on all mobos I tested it with so will have to do some more "engineering" on it to find out why.
            If you would like, I can work up a schematic in the next few days. Are you planning to build one for a Antec psu?
            • tj2
              • Oct 2009
              • 85
              If you investigate the Seasonic and make any discoveries, I'd be happy to hear about it. It might have relevance to my SS-300FS!
              • i4004
                • Oct 2006
                • 2029
                https://www.badcaps.net/forum/showth...m311#post65142
                or l&c mod
                https://www.badcaps.net/forum/showth...m311#post76920
                and dm311 datasheet should suffice to apply it anywhere...
                offcourse it's easier if everell makes custom design..hehe...
                tried to load it with stuff on output, as opposed to changing the cap value to make it start?
                • Toasty
                  • Jul 2007
                  • 4171
                  >>Both psu boards had one .1 uF/50 volt cap and one .22 uF/50 volt cap. <<
                  0.22uF or 22uF? A .22uF is marked 0.22uF, at least by Fuhjyyu. I checked my SP-450 cap layout sheet and I see the 0.1uF over at the TPS3510 supervisor and a 22uF over by the AC input connector. No 0.22uF anywhere...?
                  TN's are GP caps. Just about any 105°C cap will do fine there.
                  Nichicon VR or VZ would be fine there or UCC KMG. KMG would also be fine for Mains caps. Mine (1000/200) are KMG's and they were in service 3+ years 24/7 on hot system.
                  I only did the 'vent' caps on mine as all the others checked fine on Blue meter.
                  Toast
                  [EDIT:
                  "If you would like, I can work up a schematic in the next few days. Are you planning to build one for a Antec psu?"
                  Okay, thanks!
                  No. I want to turn it into a circuit board drawing for etching and downsizing.]
                  veritas odium parit
                  • everell
                    • Jan 2009
                    • 1514
                    Toasty, you didn't look hard enough. Take one of your SmartPower pc boards. Look at the side of the pc board where all of the output wires come out. On the left side is the small add-on pc board where fans plug in. On the right side is two toroid coils.
                    Now ... looking from right side to left .... parts next to the heat sink ...... first is a small TO92 case transistor (actually a TL431 regulator). Next is a 10 uF/50 volt cap. Next is a .22 uF/50 volt cap. It is under the toroid coil and behind the large 3.3 volt filter cap. Talk about something hard to get to!!! WOW. And of course - Fuhjyyu
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3113
                      Try removing the heatsinks to get at the small parts better.
                      • Toasty
                        • Jul 2007
                        • 4171
                        Yeah. I have it drawn, laying on its side and just didn't look twice at the labeling on my drawing.
                        It was not replaced either.
                        The board mask also doesn't show that as polarized nor an electrolytic either. Mine was mounted with the (-) lead towards the heatsink. Yours?
                        Toast
                        veritas odium parit
                        • Toasty
                          • Jul 2007
                          • 4171
                          ...and I'm -not- going back in there ever again...!!!
                          Yes, they're -all- FM's. Shoe horn and lubricant -not- included.
                          Another correction. I -did- replace the inputs with KMQ's. The Fuhjyyu inputs were (are) fine on value, leakage, and Blue ESR meter.
                          DK: 565-2956-ND - EKMQ201VSN102MP50S - $3.93 ea.
                          veritas odium parit
                          • everell
                            • Jan 2009
                            • 1514
                            Toast
                            Both of mine were also minus side toward the heat sink. I did buy GP Nichicon VZ replacements....but am very reluctant to change them. They sure are hard to get to! I haven't traced them. Any idea what they do?
                            • Toasty
                              • Jul 2007
                              • 4171
                              It's a decoupling cap on a line going to the fan control board from the input to the 3.3v pi filter. Its negative goes to 2 SMD resistors then to the (+) of the 10/50 cap next to it.
                              2 pics attached show trace to FCB.
                              Last pic is of solder side 5vsb critical cap and associated SMD resistor. The resistor on mine was a cold joint from factory. After having the board out and recapped, it would not start. No 5vsb. I started checking voltages and when I probed across that cap, I apparently applied enough pressure to make the connection and the 5vsb came up. Consequently reflowed and its fine.
                              Toast
                              veritas odium parit
                              • everell
                                • Jan 2009
                                • 1514
                                This might be a good psu to try the DM311 circuit on! Here is a schematic showing ALL of the parts on the add-on pc board.
                                • everell
                                  • Jan 2009
                                  • 1514
                                  Here is the 5vsb modification procedure for the Antec SmartPower (SP350 and SP400)
                                  1. Remove jumpers J1 and J3. They are both by the 5vsb transformer close to the edge of the pc board - on the top side (or component side) of the pc board.
                                  2. Follow the next eleven photos showing location of all modifications on the bottom of the pc board.
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    I missed the beginning of this. - What does the mod do?
                                    [And what is pin 4 on the opto?]
                                    Mann-Made Global Warming.
                                    - Dr Seuss
                                    • everell
                                      • Jan 2009
                                      • 1514
                                      The first post in this thread showed that both Antec SmartPower psu were given my 5vsb DM311 modification. Toasty asked about what was on the board. So in the above posts I posted a schematic of the board, then added the photos showing how it was installed on these two psu. I dislike those two transistor 5vsb circuits as much as others dislike those Fuhjjyu brand capacitors. So I included the 5vsb mod as a part of the recapping process.
                                      • goodpsusearch
                                        • Oct 2009
                                        • 2850
                                        • Greece
                                        Why it is a bad thing the 2 transistor 5vsb circuit?
                                        • eccerr0r
                                          UC384x critical cap
                                          by eccerr0r
                                          Well I had repaired an old Antec SP350 that had a blown (IIRC) Fuhjyyu 47uF 25V capacitor for the critical cap with an Elna 47uF 25V 85°C general purpose capacitor. It works but I can bet this will fail someday...
                                          However I still do not have any 47uF 25V 105°C low ESR caps on hand.
                                          What I'm wondering... I have a small pile 100uF 50V 105°C PM capacitors... Tempted to swap that 47uF with the 100uF which should be a quality capacitor and won't die prematurely...
                                          But it's double the capacitance!
                                          I wonder what would happen if I do the swap,...
                                          04-24-2022, 09:49 PM
                                        • sirpsychol
                                          Antec Earthwatts EA-380 smd element type/value
                                          by sirpsychol
                                          While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                                          09-03-2023, 07:58 PM
                                        • ajdrenter
                                          Picking caps for Antec SU-380
                                          by ajdrenter
                                          In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                                          https://www.badcaps.net/forum/showthread.php?t=14159
                                          It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                                          05-13-2023, 10:40 AM
                                        • s_henya
                                          Antec VP-600P and NE550M dead
                                          by s_henya
                                          Got in these 2 nice PSUs, both died after power surge.
                                          Both seems to be suffering from the same fault.
                                          Blown main fuse
                                          Shorted N mosfet 550v
                                          VP-600P: 5R280CE short between GDS
                                          NE550M: MDF18N50 short between GDS
                                          In terns of board layout these seems pretty identical.
                                          From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                                          I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                                          Is it worth to try and replace the mosfets? is there a chance that the...
                                          12-03-2024, 10:00 PM
                                        • Topcat
                                          4700uF 6.3v and 3300uF 16v in a 10mm Diameter
                                          by Topcat
                                          Where can I get them these days? My usual sources are a no go in a 10mm, 12.5mm is too big. I'm recapping an old Antec rackmount PSU for a client (SmartPower SP2-450SXR) with a bunch of spooged Fuhjyyu crap caps, and he's insisting it be repaired....which is fine by me, I make more on it that way.....but I need to find these illusive caps....it's been a long time since I've needed these values....and now I can't find them. Odds are I could get away with 3300uf in place of the 4700uF, I've done it before...but if there's a source for them in 10mm, I'll try to stay original.
                                          10-14-2020, 06:35 PM
