Recapping Antec SmartPower SP350 and SP400
  • Toasty
    • Jul 2007
    • 4171
    #61
    Re: Recapping Antec SmartPower SP350 and SP400
    Picture from this thread:
    https://www.badcaps.net/forum/showthread.php?t=31149
    Picture: https://www.badcaps.net/forum/attach...chmentid=69689
    While it -has- the fan controller on it, it's not its' only function. It does the PS_ON line and voltage Supervisor too.
    One of the 2 smaller chips (IIRC...?) do the PS_ON. WT7518D
    notes, notes, notes... Ah-ha!
    Desolder just pin 8 (Vcc) of the 8-pin vertical chip and see if it will switch on. Make sure it's not touching the pad.
    In the picture it's the one adjacent to the yellow cap and pin 8 is the bottom left.
    ** No need to remove the board to do this.
    T
    veritas odium parit
    • cno
      • Oct 2017
      Yes, it does and I have pix:
      http://www.vintageelectronics.ca/gal...ty/AntecSP400/
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8676
        The SP400 uses a voltage doubler when used on 120VAC.
        I fried my SP400's switcher chip when my 5VSB blew, so I had to replace it too.
        • Toasty
          • Jul 2007
          • 4171
          #64
          Updated above post with info and datasheet.
          T
          veritas odium parit
            master hoarder
            • May 2008
            • 12164
            #65
            Originally posted by cno
            There is something I do not understand: when I put the AC voltmeter across the inner pins of the rectifier bridge, it reads 120V give or take a few. But when I switch it over to DC and put it across the outer pins, it reads 350V give or take a few. Should there not be 120*1.41=160V only there? The el caps on the high side are 820uF * 200V, so 350 would be disastrous.
            No, that's normal.
            As eccerr0r mentioned, there is a voltage doubler circuit on the primary side of the PSU: those two 820 uF, 200 V caps are in series, and the voltage doubler puts about 160V across each. So the result is 2 * 160V = 320V. Well, you get more if your line is a little higher.
            • cno
              • Oct 2017
              Thank you so much for the tips, Toasty, ecerr0r and momaka! I got the idea and as soon as the soldering station I ordered arrives, will try to disconnect pin 8. Once I pulled apart the wire harness, a few blown up caps cropped up, so will be replacing those as well. Will post back!
              • eccerr0r
                UC384x critical cap
                by eccerr0r
                Well I had repaired an old Antec SP350 that had a blown (IIRC) Fuhjyyu 47uF 25V capacitor for the critical cap with an Elna 47uF 25V 85°C general purpose capacitor. It works but I can bet this will fail someday...
                However I still do not have any 47uF 25V 105°C low ESR caps on hand.
                What I'm wondering... I have a small pile 100uF 50V 105°C PM capacitors... Tempted to swap that 47uF with the 100uF which should be a quality capacitor and won't die prematurely...
                But it's double the capacitance!
                I wonder what would happen if I do the swap,...
                04-24-2022, 09:49 PM
              • sirpsychol
                Antec Earthwatts EA-380 smd element type/value
                by sirpsychol
                While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                09-03-2023, 07:58 PM
              • ajdrenter
                Picking caps for Antec SU-380
                by ajdrenter
                In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                https://www.badcaps.net/forum/showthread.php?t=14159
                It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                05-13-2023, 10:40 AM
              • s_henya
                Antec VP-600P and NE550M dead
                by s_henya
                Got in these 2 nice PSUs, both died after power surge.
                Both seems to be suffering from the same fault.
                Blown main fuse
                Shorted N mosfet 550v
                VP-600P: 5R280CE short between GDS
                NE550M: MDF18N50 short between GDS
                In terns of board layout these seems pretty identical.
                From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                Is it worth to try and replace the mosfets? is there a chance that the...
                12-03-2024, 10:00 PM
              • Topcat
                4700uF 6.3v and 3300uF 16v in a 10mm Diameter
                by Topcat
                Where can I get them these days? My usual sources are a no go in a 10mm, 12.5mm is too big. I'm recapping an old Antec rackmount PSU for a client (SmartPower SP2-450SXR) with a bunch of spooged Fuhjyyu crap caps, and he's insisting it be repaired....which is fine by me, I make more on it that way.....but I need to find these illusive caps....it's been a long time since I've needed these values....and now I can't find them. Odds are I could get away with 3300uf in place of the 4700uF, I've done it before...but if there's a source for them in 10mm, I'll try to stay original.
                10-14-2020, 06:35 PM
