Here we have the Solid Gear (MicroCenter House Brand) Basix SDGR-500BX "500W" PSU, one of their cheapest ATX power supplies selling for a whopping $19.99,
lets take a look at how good/bad it is:
Box, pretty basic packaging:
It claims 26A on the 12V rail and 22A ea. on the 3.3V and 5V rail.
The unit itself is a pretty basic grey box as expected at this price point:
No APFC (not surprising at this price point):
Label claims the same as the box (at least the lies are consistent).
Lets take a look inside. Oh boy, this isn't good:
Primary has 2X "Rubycon" PX 220uf 250v caps (these caps look really old and dirty so they may be "recycled"), a pair of 13007 (8A 400V) transistors for the primary and a C3150 (50W 800V) on the standby. The input "filtering" (if you could call it that) consists of 1 x-cap and 2 y-caps directly on the mains connector. It is also using the 4 diodes treatment for the bridge rectifier.
On the secondary side we have a Mospec F16C20C (16A 200V) ultra-fast diode on the 12V rail (hmm didn't the label claim 26A??), and MCC MBR2045CT (20A 45V) Schottky diodes for the 5V and 3.3V rails (and the label claimed 22A for these).
Secondary Caps as follows:
3x Jayi 1000uf 16v
2x ZTLCon 1000uf 10v
2x Jwco 470uf 16v
Bottom of the board, not terrible for a cheap unit:
Lets see how it handles some load:
Starting with the 137.6W load from my Seasonic power supply tester
Note: the oscilloscope is set to the 100mV per division scale
12V:
Voltage at 12.586V which is in spec, but the 250mV ripple isn't, so this thing fails even with a fairly light load.
5V:
5.0335V, but 225 mV ripple again out of spec.
3.3V
3.1099V and 200 mV ripple out of spec on both counts here.
Power draw:
178W for a 77% efficiency.
Now lets add an additional 10A on the 12V rail to bump it up to 257.6W:
12V:
12.363V and over 300 mV ripple (and look at how ugly the ripple in the +/-100mV range is
5V:
5.082V with around 275 mV ripple
3.3V
3.1206V with around 225 mV ripple
Power draw:
338W for a 76% efficiency.
Well, it didn't blow up, though it did start to smell "bad" (like hot melt glue) in the second test so I doubt it would last very long under that load. The ripple is downright ugly though even under the lighter load so I wouldn't use this thing on any PC I cared about (or any PC for that matter).
3x Jayi 1000uf 16v
2x Jwco 470uf 16v
12V:
5V:
3.3V
Power draw:
12V:
). 5V:
3.3V
Power draw:
and hope it doesnt launch and release the magic smoke from those non-pc parts too...!
) would be ever since I saw them hit the shelves of MicroCenter. When I was working there as a tech a few years back, we had store discount savings. But for some reason, we didn't get much or any at all for the store-brand or very cheap items. Either way, I've been thinking about buying one of these cheapo SolidGear PSUs to open and post here for a long time, but just never did. Most of this was because I didn't want to waste $20, and I kind of knew what to expect would be inside.
, though something tells me the SG is not based on a PowMax or Sun Pro platform.
to momaka for catching that really small output inductor core! An additional worrisome thing about it is that if enough power is drawn for the core temperature to get much above 90C or 100C, it's going to cause deterioration of the core's magnetic properties, leading to ever worsening ripple.
