Giant ebike li-ion charger
  • Cobblers
    • Jan 2016
    • 90
    • Uk
    29.2 volt li-ion charger
    Has mains input but no dc output
    2.5 glass fuse on primary side was blown
    I had to solder on a removable fuse holder
    Then installed a 2.a fuse to test but in instantly blew again.
    I've removed the heat sink so I could take a better picture.
    Any ideas what I should test?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Giant ebike li-ion charger
    The bridge rectifier and the mosfet.
    • Cobblers
      • Jan 2016
      • 90
      • Uk
      Yes found the mosfet is shorted across all 3 terminals out of circuit. With it removed the fuse doesn't blow and I get 330v dx accros the big capacitor. I've ordered the mosfet and will give it a try.
        • 31054
        if all 3 pins are shorted then it may have damaged the circuit connected to the gate pin
          SMPS IC101 in the Hot side probably is damaged too, you also need to check the low Ohm Source pin resistor (Brown/Black/Silver/Gold???) to gnd and also any parts connected between Gate and Drive output of the SMPS IC for damages.
          • Cobblers
            • Jan 2016
            • 90
            • Uk
            I'm not sure how to test the ic101.
            I've tested
            R108 ok
            R106 ok
            R105 ok
            R103 and 104 ok
            D102 ok
            Not sure how to test the ferrite bead
            But measuring no resistance across the 2 pins
            Checking r112 it measures 0.5 ohms
            The calculator says it should either be 0.1 ohm or 0.2 ohm depending whether or not the first band is red or brown I think it is red personally but not 100% sure. Tolerance is stated as 5% so it should be between 0.19 and 0.21 do you think this is failed?
            • petehall347
              • Jan 2015
              • 4427
              • United Kingdom
              ic101 is showing signs of being hot
                • 31054
                touch your probes together, your probably seeing the resistor + losses in your probes/cables
                most meters have a .2-.4 ohm loss in the cables
                  I would replace the IC unless you want to take a chance of blowing up the new MOSFET. you cannot fully test the IC with the meter.
                  • Cobblers
                    • Jan 2016
                    • 90
                    • Uk
                    Minimum order for the new mosfet was 5 from rs so I have spares. The meter I'm using is a hantec 2c72 in dmm mode. It is also a occiloscope work bought them for us however I've never used it as a scope I I'm worried about doing more damage to the board by probing the wrong parts
                    I will have to do some more learning I think
                    • Cobblers
                      • Jan 2016
                      • 90
                      • Uk
                      OK so new mosfet arrived.
                      It lasted approx 5 seconds and now I have a hole where ic 101 used to be.
                      I've been Trying to find one online but without success luckily I have a half decent photo of the part number but have been unable to find the exact part number so at the moment I'm stuck.
                      Does anyone have any ideas?
                        FUJI FA5518.
                        You must check all the component between the Gate of the MOSFET and this IC and other components connected to the IC.
                        • Cobblers
                          • Jan 2016
                          • 90
                          • Uk
                          I damaged the board while removing the chip so thanks for all the help I've ordered a new charger
                          • corrize
                            Replacing resistor fuse in Sony DV charger
                            by corrize
                            Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                            So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                            It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                            06-30-2025, 06:59 PM
                          • Austin Siebert
                            Acer Nitro 5 met my ebike charger...
                            by Austin Siebert
                            Acer Nitro 5 AN515-5779TD
                            Board GH51G LA-L181P Rev: 1B
                            Well I was rushing to finish homework and just plugged my 54.6v 3 amp DC ebike charger into it. So thats just miserable. I just spent 2 days troubleshooting a parasitic drain on my A6 that killed my alternator. This literally happened right after I got that all diagnosed and fixed.
                            So visually it looks to be localized to the TI BQ24781 charge controller. Pins 2, and 27 look burnt aswell as the top of it got so hot as to melt the plastic it was touching even after I realized what was going on and disconnected...
                            01-22-2025, 01:52 AM
                          • corrize
                            A funny fuse story – Lumix LX100 II
                            by corrize
                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                            10-19-2023, 09:58 AM
                            NVDC charger configuration...
                            11-05-2024, 03:28 PM
                          • flat-earther
                            how to prevent a connected charger from draining battery when not charging?
                            by flat-earther
                            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                            So the battery is backfeeding the charger and being drained.
                            How can I prevent...
                            08-07-2025, 01:04 PM
