Corsair GS800 fan spinning only on boot
  • DS-1
    • Jun 2015
    • 82
    • Italy
    Hi guys!
    I have this PSU that I've bought used.
    The fan spins at max when computer boots, then there's a very high frequency sound coming from PSU and the fan doesn't spin anymore, even if I try to push the computer using stress tests utility like PRIME95 or AIDA64.
    Sometimes the fan seems to try to start, but eventually it doesn't.
    I know this is a very common issue for this PSU, but I've found no fix for it (someone used a new fan controlled by mb header, but I'd like to know if it's fixable to be used as it is stock).
    Thanks in advance for the reply!
    • Jul 2011
    • 6059
    Re: Corsair GS800 fan spinning only on boot
    Post some pictures of this power supply board front and back of the board
    • DS-1
      • Jun 2015
      • 82
      • Italy
      Here are the pics:
      I've made also pics to the smaller board screwed on the panel.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        This is a fanless PSU at low loads.
        What is the power consumption on the PSU when you say it is under heavy load by Prime95?
        Remember it is an 800w PSU and most desktop machines will be hard pressed to pull 200w DC.
        If it is not getting hot to the touch I would say it is working as intended.
        • DS-1
          • Jun 2015
          • 82
          • Italy
          Thanks for the reply.
          I knew that it is fanless when the load is low. What makes me think about a fault was the fact that, after a while, the fan seems to start to spin, but it moves only a bit. Also, the PSU makes a very high pitch sound that seems to be something faulty.
          I have a i5 8500 with a h370m board and. a RX570 double fan (and double PCI e molex) and a 3.5" hdd.
          Is there any way to test how much power it consumes when under PRIME85 test?
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            The CPU has a TDP of around 65w
            Intel cheats a bit in their TDP specs so it can draw more than that.
            In general the system will draw around 100w DC during Prime95
            The GPU has a TDP of 120w, it can draw around 170w or so during gaming.
            In total around 200w DC or 25% of what the PSU can deliver.
            You can use an inline power meter, in the US they are called "Kill A Watt"
            In Europe it is more common with German brands like Voltcraft for example.
            Or you can use a multimeter in amps mode, but you need to cut the 230v cable in two to do it so not very safe...
            Download Superposition benchmark and run that instead of Prime95, should be a much tougher load.
            But still remember that it will only be max ca 25% of what the PSU can actually deliver...
            https://www.techspot.com/downloads/7...rposition.html
            • DS-1
              • Jun 2015
              • 82
              • Italy
              Yes, I was thinking about the second option (cutting the 230v cable and use the multimeter in Ampere).
              I've found that a lot of GS series users have the issue of the fan that seems to start spinning, but no one talk about a real fix for it. Maybe they didn't know about the silent mode?
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                In the EU you can cut a mains cable and use an AC ammeter.
                Can't do the same in the USA... since there's no requirement for USA computer equipment to have high power factor... BOOO...have to get a true RMS ammeter...
                • DS-1
                  • Jun 2015
                  • 82
                  • Italy
                  I will try in the next days and I'll let you know how the test goes...
                  • DS-1
                    • Jun 2015
                    • 82
                    • Italy
                    I have to say that GS800 is working fine: I've tested it on an older machine (p8h61-m le with 4 cores i5 2400 and a HD7870 with dual PCI-E connectors) and, when launching benchmarks, the GS800 fan starts to spin!
                    The only thing that is strange is that, after 2-3 minutes of benchmark, the fan wants to start, but it's buzzing. After 5 or more minutes, it starts to spin without issues. Maybe there are some problems when, after 2-3 minutes, the temperature is not that high and so it should spin at lower rpm.
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      • USA, Unsure of Planet
                      In some server PSUs, especially those rated "Platinum" or "Titanium", the fan spins at full speed for several seconds after the PSU is enabled, and then drops to low speed or stops until something inside gets hot enough to require additional cooling. I think this may be either a start-up default or to cool the auxiliary/standby regulator after having been in standby mode for an extended time period. Or both. Fans require power, and when a PSU is rated for >95% efficiency, the power to run the fan can be relevant.
                      PeteS in CA
                      • DS-1
                        • Jun 2015
                        • 82
                        • Italy
                        Corsair says that this GS series (but I believe some other PSUs, too) work in this way: fan starts to spin when there is a load of almost 250w.
                        The strange thing is that mine would like to spin I think even in "normal" use (not in game or during benchmarks), but the fan has a sort of "faulty start" with a buzzy noise. When the load increases, fan starts. That's why I'm not sure if my PSU works correctly or not!
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          This might be a silly question, but can the fan actually spin freely?
                          In other words, if you spin it by hand, does it take a while to come to a stop (and do a little "wobble" when it finally stops)? Or does it stop rather quickly? If it's the latter, the fan might need a bearing cleaning (if it's a sleeve bearing fan) or bearing replacement (if it uses a BB).
                          I also can't help but notice the PSU has green electrolytic caps on the output, which if I'm not mistaken would be either Taicon or Samxon. Whichever the case, those would be "2nd tier" caps, and I would suggest you modify the fan circuit in the PSU to have the fan run all the time. The easiest way to do that, if it's a 2-pin fan (most are) would be with two diodes on the positive (red) wire of the fan: one diode feeding the fan constant 5V when the PSU is on, and the other diode feeding power from the fan regulator circuit, so that if the PSU wants to run the fan at a higher speed for some reason, it can still do that.
                          • DS-1
                            • Jun 2015
                            • 82
                            • Italy
                            Yes, fan can easily moves if I spin it by the hand, that's why I supposed there's something "wrong" in the automatic fan spinning circuit.
                            I could do the modify you suggested. I'll write here when I'll realize it!
                            Thanks!
                            • privato89
                              Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                              by privato89
                              I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                              Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                              Let's begin:
                              Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                              03-26-2024, 06:37 AM
                            • hinisa
                              Xiaomi router freezes at boot after re-capping
                              by hinisa
                              I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                              When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                              After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                              Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                              07-08-2023, 05:58 AM
                            • Luke Anders
                              Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                              by Luke Anders
                              A few details about the laptop itself:
                              Name: Lenovo Legion 5
                              Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                              BIOS Version: GKCN60WW
                              EC Version: GKEC65WW
                              Serial Number: PF39AQ7Z
                              Board Model: NM-D562 Rev 3.0
                              RAM: 16GB Installed, DDR4 (brand new)
                              NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                              I bought this laptop recently from eBay as a faulty device....
                              10-12-2024, 05:13 AM
                            • NolesFan
                              Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                              by NolesFan
                              Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                              10-24-2024, 06:36 PM
                            • praveenramavath
                              Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                              by praveenramavath
                              Hello All,
                              I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                              https://www.hifivision.com/threads/m...-screen.98243/
                              Troubleshooting Summary: Majority Internet Radio - Flash Chip
                              04-26-2025, 09:08 AM
