Itek Atx 500W does not turn on
  • CapLeaker
    Leaking Member
    • 8168
    Re: Itek Atx 500W does not turn on
    looks like the board has burn marks where the inductor was on the second picture? i think you checked those diodes that were hiding under that inductor. So i am at a loss to see where the short is coming from, unless the filter caps on the output is shorted?
    • falcontech
      • Oct 2013
      • 470
      • italy
      #82
      Yes, I have checked all the diodes and they are all ok, the output capacitors are all new
      • falcontech
        • Oct 2013
        • 470
        • italy
        #83
        has become an enigma, this psu, are waiting to receive the identical working one
        • falcontech
          • Oct 2013
          • 470
          • italy
          #84
          I checked everything I can't understand what it is
          • CapLeaker
            Leaking Member
            • 8168
            me neither for the moment.
            • falcontech
              • Oct 2013
              • 470
              • italy
              #86
              wait for the twin power supply to arrive and we'll update
              • falcontech
                • Oct 2013
                • 470
                • italy
                #87
                unfortunately the power supply that came to me is not the same, it is of the same brand, it is accurate on the outside but inside no, I'm thinking of disconnecting all the components on the secondary on one side to see if the short goes away
                • falcontech
                  • Oct 2013
                  • 470
                  • italy
                  #88
                  Hi caps
                  I solved with the power supply, it was the inductance, I got an equal power supply and I understood that it was that, on having more than the original I bought a tester for inductances and looking at the values I had to modify one by removing the windings and I managed to get him started.
                  PS we concentrated on the short that is on the 5 volts but that short was also on the second power supply, so it was normal and then I thought it could be the inductance, since the original was burnt I had put one haphazardly and that's all, I learned a new thing
                  • pajdek
                    Lenovo Y700-17ISK turn on and off
                    by pajdek
                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                    09-20-2023, 02:49 AM
                  • RdeveLabs
                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                    by RdeveLabs
                    To all the members here...
                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                    05-05-2025, 04:59 AM
                  • robante15
                    Acer Aspire 4520 won't turn on after reboot
                    by robante15
                    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                    If I remove the...
                    04-06-2024, 06:50 PM
                  • masoksian
                    Dell latitude e7470 not turn on .power buton on off and Run Power problem
                    by masoksian
                    I am dealing with the problem of turning on and off my Dell e7470 notebook.
                    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                    The system does not turn on, there is no post.
                    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                    The problem continues in the same way.
                    I tried to turn on the Fn key, nothing came to the screen....
                    02-15-2025, 12:08 PM
                  • dqtech
                    lenovo x240 nm-a091 wont turn on
                    by dqtech
                    i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                    board number VIUX1 NM-A091 REV:1.0...
                    02-07-2024, 01:57 AM
