Itek Atx 500W does not turn on
    Re: Itek Atx 500W does not turn on
    mmmmmm I don't know, do I try to detach them? which one should I take out of the three?
      or is there a way to test them?
        now I try to remove the TL494 let's see what happens
          I removed the bigger transformer but it is not that, I have removed the TL494 and it is not that, there is crazy going out
            it's not even the central one that causes the short, I'm removing them one at a time
              all you can do to test a transformer is check every winding for continuity and that other windings aren't shorted to one that shouldn't be. Other than that, to properly test a transformer you need a ring tester.
              Is a ceramic disc capacitor shorted maybe?
              The TL494 is on the primary winding, so it wouldn't cause a short on the secondary as they are isolated from each other.
                what would this ceramic disc capacitor be? I do not know
                  ok I understand what are, tomorrow check, multimeter in diode test position?
                    either diode or ohms. diode check gives you a continuous beep if something is shorted.
                      three of these capacitors I had tried to pull them out of the circuit to test if the short was gone but I have not tested them individually
                        well... that is a plus for a change!
                          but when I unplugged them the short was not eliminated, tomorrow I will try them all individually
                            Arrrgh! I am ready for feeding a lot of power backwards and see what’s gonna blow up!
                                I found a ceramic capacitor roasted on the primary, unfortunately the number is no longer visible, I removed it but the short remains
                                  Even if the last transformer is removed, the short persists
                                    send a picture as the PSU is at the present time, top and bottom.
                                      ok
                                        here they are, I showed you where the broken ceramic capacitor was
                                          so what do you do?
