Itek Atx 500W does not turn on
  • falcontech
    • Oct 2013
    • 475
    • italy
    Hello everyone
    I'm back with another ATX that doesn't want to leave, with the experience of technoware I did the same tests you recommended me, the structure is very similar, on the primary the voltage on the large capacitors is good, I tried the voltage on the transformer small and I have 5,7 volts, I have 5v standby, I have 8,5 volts on pin 12 of the integrated circuit, the mosfets on the primary and the shottky diodes on the secondary are fine, when I turn on the power supply I have about 6 volts for a few seconds on the line of 12 volts which then vanishes on 5 volts nothing and not even on 3,3
  • CapLeaker
    Leaking Member
    • 8297
    Re: Itek Atx 500W does not turn on
    First thing we need is always pictures! Power supplies aren’t always built the same. Some have PFC others don’t. The valuable info just gave is, the PSU actually tries to start, but gets shut down, because something doesn’t add up and the protection circuit clicks in.
    Again, test each individual voltage rail on the secondary output and turn the PSU on. Write down what you measured on each rail. Don’t forget the -12V!
    • falcontech
      • Oct 2013
      • 475
      • italy
      Ok
      • falcontech
        • Oct 2013
        • 475
        • italy
        here are the photos, I tried the rails, on the -12 volts I have a departure of about 14 volts which then vanishes, on the 3.3 I have 0.3 which then goes away, on the 5v I have nothing
        • falcontech
          • Oct 2013
          • 475
          • italy
          I forgot I tested the two c945 transistors between the primary and the secondary and they are good
          • CapLeaker
            Leaking Member
            • 8297
            I see bad solder joints all over the place. Fix those first. I guess the power supply is shutting down because of not having any 5V. Check the diodes for the 5V and 3.3V rail.
            • CapLeaker
              Leaking Member
              • 8297
              Doesn't surprise me, because the PSU is turning on, then shutting down. So the primary side must be working.
              • falcontech
                • Oct 2013
                • 475
                • italy
                ok, unfortunately there was something sticky about the welds that didn't allow me to make good welds, what are these diodes? you could indicate them on the photo thanks
                • falcontech
                  • Oct 2013
                  • 475
                  • italy
                  are you talking about the schottky diodes those in the heatsink?
                  • CapLeaker
                    Leaking Member
                    • 8297
                    clean the bottom of that board first with IPA or Acetone and an (old) toothbrush. That crud has to come off. Then fix what you see is broken, as I see quite a few bad solder joints that are cracked, have rings, aren't soldered properly, one looks like its touching something else, etc.
                    After cleaning, fix all the bad joints and retake the photo.
                    First photo, second heat sink from the left. Check the components mounted on it.
                    The single blue wire is -12V, the orange wire is 3.3V, the red wire is 5V, etc. Trace it back and check it for a short to the black wires (GND). Either something is a dead short or an open.
                    IPA = rubbing alcohol
                    • CapLeaker
                      Leaking Member
                      • 8297
                      yes
                      • falcontech
                        • Oct 2013
                        • 475
                        • italy
                        I had already checked the three schottky diodes and they were good, they did not give me any short, the capacitors I had replaced them all, they will make one that I will now do, the welds you see open are from the heat sink, I have not welded them in case I have to disconnect again the heatsink, now check the short on the blue, red and orange wires
                        • falcontech
                          • Oct 2013
                          • 475
                          • italy
                          I used trichlorethylene to clean but the dirt doesn't come off
                          • CapLeaker
                            Leaking Member
                            • 8297
                            Is there something open like an inductor, or transformer winding?
                            • falcontech
                              • Oct 2013
                              • 475
                              • italy
                              I checked the tracks and it gives me the short on the 5v and on the 3.3 but I noticed that the short on the 3.3 also gives it with a working power supply, I replaced the large coil on the secondary, it was all burnt out, I took one from an old atx, the original one had 8 pins, the one I replaced has 10 and I left two unconnected could it be that?
                              • CapLeaker
                                Leaking Member
                                • 8297
                                no short on the working PSU on the 5V rail?
                                • falcontech
                                  • Oct 2013
                                  • 475
                                  • italy
                                  no
                                  • CapLeaker
                                    Leaking Member
                                    • 8297
                                    investigate that. maybe a zener diode is shorted. Take the shottky diode off the heat sink and see if the short persists. If the short is still there, you have to check every part on the secondary that is on the 5V rail.
                                    • falcontech
                                      • Oct 2013
                                      • 475
                                      • italy
                                      ok, but what about the big reel? can that go, which i replaced?
                                      • CapLeaker
                                        Leaking Member
                                        • 8297
                                        That is an inductor. It could go open. maybe put the old one back in place.
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • robante15
                                          Acer Aspire 4520 won't turn on after reboot
                                          by robante15
                                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                          If I remove the...
                                          04-06-2024, 06:50 PM
                                        • masoksian
                                          Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                          by masoksian
                                          I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                          The system does not turn on, there is no post.
                                          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                          The problem continues in the same way.
                                          I tried to turn on the Fn key, nothing came to the screen....
                                          02-15-2025, 12:08 PM
                                        • dqtech
                                          lenovo x240 nm-a091 wont turn on
                                          by dqtech
                                          i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                                          board number VIUX1 NM-A091 REV:1.0...
                                          02-07-2024, 01:57 AM
