Corsair GS800 Power Supply Problem
  • ShortCircuited
    • Jan 2020
    • 100
    Had this thing laying around for a bit so I thought I would drag it out under the current global circumstances and see if I can repair it. I have recorded my readings on the image below indicating basic layout and some voltage readings. I am not an EE but I know NOT to mess with the large cap.
    EDIT: Cathode is top terminal of Main Cap.
    All votlages taken on secondary side were to ground or "neg" in the image.
    Essentially the primary side is charging to 370ish. I do have 5v on pin 11.
    Grounding pin 4 (green) while small fan and two SATA drives are connected for a load while probing.
    Visually I cant see anything that looks out of the ordinary. The empty holes on the primary side were sucked out inspecting they are n/c by design.
    Anyone have any ideas where I might look given this information? I have not looked at the small vertical board (image below).
  • ShortCircuited
    • Jan 2020
    • 100
    Re: Corsair GS800 Power Supply Problem
    Here are the results of what I am getting on the 24 pin connector.
    1. .0001 | 13. .0001
    2. .0001 | 14. -.0776
    3. - | 15. -
    4. .0027 | 16. ps/on
    5. - | 17. -
    6. .0027 | 18. - (probe)
    7. - | 19. -
    8. .00057 | 20 n/p
    9. 5.069 | 21. .0027
    10 .11~.14* | 22. .0026
    11. .13 | 23. .0022
    12. .0001 | 24. -
    * Pin 10 is fluctuating between .11xx and .14xx.
    It seems as if something is holding the 12v low and not allowing it to power on.
    EDIT: Found a P/S Supervisor WT7502 that "provides protection circuits, power good output (PGO), fault protection latch (FPOB), and a protection detector function (PSONB) control. It can minimize external components of switching power supply systems in personal computer.
    Probing this chip (U7) while in on state it is not getting the proper signals. PGI-power good input signal should be 1.16-1.24 volts and it is only .0153, so the problem w/ the power supply is likely before this "supervisor."
    • ShortCircuited
      • Jan 2020
      • 100
      This diagram suggests the secondary side is not sending a signal to the primary to provide power to the transformer for 12 volts?
      Anode-Cathode drop is 1.08v according to DMM.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8203
        To start off, I’d check if any of them secondary voltage rails is shorted. Also check the main filter capacitor for 380VDC.
        • ShortCircuited
          • Jan 2020
          • 100
          Thanks for the suggestion...
          Main cap is charging to 375.
          Readings to ground (secondary side):
          12v (yellow) - Meter goes OL after a second or two.
          5v (red) - 140 ohm
          3v (orange) - 126 ohm
          5v and 3 v seem kinda low...?
          • ShortCircuited
            • Jan 2020
            • 100
            Seems OK, I supplied 12v to secondary side and current was normal with the two HDs and a small cooling fan fora test load, about 1 amp. Heated the thermistor for the fan control and the cooling fan kicked on and off.
            Voltage regulators seem fine too. When 12v is applied to the secondary via separate PS the 5v and 3.3 are present and fine.
            WT7502 (U7) is getting 4.4v for startup signal according to spec sheet 3.6v is typical. This supervisor is looking suspect. "OL" from Vcc to GND. Anyone have a value for this supervisor between pins 2 and 7?
            • R_J
              • Jun 2012
              • 9552
              The VOLTAGE between pins 2 and 7 should be around 12 volts. what do you mean by OL? are you measuring the resistance between vcc & ground? Is that what your meter displays when the probes are shorted together?
              • ShortCircuited
                • Jan 2020
                • 100
                Retest and resistance is 1.7kohm between vcc and gnd (2/7).
                FPOB-Fault Protection is .38v to ground and 39 megaohms to ground.
                • R_J
                  • Jun 2012
                  • 9552
                  That resistance is ok, the ic gets it vcc when the power supply is working, If there is no +12v then U7 is not the problem. Check the primary switching transistors. It looks like the pfc circuit is working as you have 380vdc, but the main primary switcher is not.
                  It looks like there are two fets in the primary, have you checked them?
                  • ShortCircuited
                    • Jan 2020
                    • 100
                    Thanks for the suggestion. These two FETs you mentioned are Q10 and Q15 and are 6R190E6s (TO247 package) for which I cannot find the datasheet so I am consulting a C6 datasheet.
                    The drains are jumping around erratically between 138 and 172ish according to my DMM (UT61E) on both FETs.
                    The glass diodes (D37 and D40)s (circled yellow) are both 5.6ohm. Why are D37 and D40 (circled yellow) in parallel with a 4.7ohm resistor? What good are the diodes if they are essentially shorted?
                    I believe I have the pinout correctly labeled on he two FETs-
                    • R_J
                      • Jun 2012
                      • 9552
                      Those are likely in the gate drive circuit, they are used to modify the turn on and turn off of the fets during operation. that is normal. Those might be the pfc mosfets, The one (or two) I refered to are (Q11?) the ones that drive the transformer.
                      Those type of meters (UT61E) being lower cost, will be confused by the 20~40khz high frequency signal that is on the pfc mosfets.
                      Remember the pfc boost circuit is working. The raw dc voltage on the main capacitor would be 160vdc, but the pfc is boosting it to 380vdc.
                      • ShortCircuited
                        • Jan 2020
                        • 100
                        There are a pair of 20N60S1s (TO220) physically closer to the main transformer and are labeled Q11 and Q7. You have schematic?
                        380V
                        I do have a DSO138, but I can't find it useful for anything. I dont think it can handle the voltage to be of any use here. EDIT: 50v 200khz max.
                        • R_J
                          • Jun 2012
                          • 9552
                          I don't have a schematic, I am using your picture of the board. When checkiing voltage on the primary side, use the main filter cap (-) for meter ground, then check the voltage on D13 cathode (white mark) and D13 anode and D19 cathode and anode. D19 anode should be close to 0 or ground, if it is not, check R116 it could be open
                          • ShortCircuited
                            • Jan 2020
                            • 100
                            I have had the entire heatsink (HS3) out and replaced Q7 it appears. Had this PS for a while now. Did a test with a small fan and these FETs worked it seems or I would not have reinstalled it. The CM6800 (not showing short) is very near on the adjacent vertical board.
                            LOL I was about to start begging for a copy.
                            • ShortCircuited
                              • Jan 2020
                              • 100
                              ...check the voltage on D13 cathode (white mark) and D13 anode and D19 cathode and anode. D19 anode should be close to 0 or ground, if it is not, check R116 it could be open
                              D13*:cathode 377v and anode -.19. *Traced to transformer.
                              R116: 1ohm (in and out of circuit).
                              So it looks like you are correct no grounding /switching of main transformer on primary side.
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8203
                                I think there is either a short on the secondary somewhere or there is a problem with the feedback. If R116 is open there wouldn’t be anything at all on the secondary.
                                • R_J
                                  • Jun 2012
                                  • 9552
                                  I don't understand. "D13*:cathode 377v and anode -.19."
                                  So the voltage on:
                                  the cathode of D13 = 377v
                                  the anode of D13 = -.19?
                                  the cathode of D19 =
                                  the anode of D19 =
                                  If R116 is good then I suspect the fets are ok, but I don't think they are getting any drive.
                                  I was going to ask for the voltages on Q7 & Q11 to see if the gates had any voltage
                                  • R_J
                                    • Jun 2012
                                    • 9552
                                    I think there is either a short on the secondary somewhere or there is a problem with the feedback. If R116 is open there wouldn't be anything at all on the secondary.
                                    where do you see voltages on the secondary?
                                    • ShortCircuited
                                      • Jan 2020
                                      • 100
                                      So the voltage on:
                                      the anode of D19 =
                                      Confirmed with retest. D13 is as originally tested.
                                      D19: Cathode 377v Anode .000
                                      Q7 377 on all pins-this is not a mistake triple check. I believe I already changed this one when I was working on this PS before.
                                      Q11:G 5.6v - D -.19 - S .0018
                                      If there was a problem on the secondary side when I applied 12v directly current would have over loaded my testing power supply. All voltages were regulated properly on secondary side. Current during this test was less than 1amp and it was not regulated with one 3.5 , one 2.5 and one 12v fan running. 12v, 5v and 3.3v rails were all present.
                                      • R_J
                                        • Jun 2012
                                        • 9552
                                        Confirmed D13 is as originally tested
                                        If D13 cathode is 377v and D19 cathode is 377v then Q7 is either turned on or shorted.
                                        D13 cathode connects to Q7 Drain
                                        D19 cathode connects to Q7 Source
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          03-31-2024, 02:12 PM
                                          07-01-2024, 06:34 AM
                                        • shamsudeen
                                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                          by shamsudeen
                                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                          07-19-2025, 07:14 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
