Corsair GS800 Power Supply Problem
Re: Corsair GS800 Power Supply Problem
I also see Q7 has an insulating kit and Q11 does not, has it been changed to an insulated mosfet? I hope it's drain is not connected to the heatsink. or is Q11 an original and Q7 been replaced with something else?Last edited by R_J; 04-04-2020, 07:58 PM.Comment
I just checked the pictures again and you are correct on the resistor, I also did notice that Q7 and Q11 are different, one is a full pack the other isn’t. There is insulating hardware on Q7, but either it is bad, or Q7 is bad. Do Q7 and Q11 have the same part number?Comment
Removed Q7 and it is not shorted. Yes Q7 does have insulating mounting hardware. I will run an independent bench test on this and see if it is good.
It does appear .19 volts is making it through the transformer to the secondary side for the 12v rail.
Q7:
Q11:
Feedback winding continuity.
Primary open.
Neg side of primary winding to feedback is 11 megaohm.Last edited by ShortCircuited; 04-04-2020, 09:00 PM.Comment
Solder joints look good. Primary winding is actually two wires whereas the feedback is only one wire.
Curious. If I am getting .19 on the secondary side that suggests the primary winding broke early in the wind?
Is it possible to fix this transformer? If i could find the opening a small bead of solder would be an acceptable fix? It appears the outside is glued together:
Check the primary winding to those pins that are cut off, I suspect there might be a thermal fuse in the primary. I marked where it might be, but it could also be between the other cutoff pin. check the resistance between those pins, the transformer might be fixable.
You posted a picture of the secondary side, But post a similar picture of the PRIMARY side. I might be able to tell if there is an imbeded fuseLast edited by R_J; 04-05-2020, 10:19 AM.Comment
Primary Green: 1
Thermal Fuse Red: open
Might be here Blue: 1
Primary Side:
BINGO! Pin 5 (per post 33) has two wires and one is cracked/split. Looks like QC issue. The wire was not long enough during the manufacturing process and came up short it appears...so just add a glob of solder? Friday Build.I never would have found that without you guys. OH CANADA...!
Preliminarily it works!!!!!!!
Tremendous ty
12.2v
5.0v
3.3Last edited by ShortCircuited; 04-05-2020, 01:15 PM.Comment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
- Loading...
