Corsair GS800 Power Supply Problem
  • ShortCircuited
    • Jan 2020
    • 101
    Re: Corsair GS800 Power Supply Problem
    very good find! keep my fingers crossed that it works after you reassembled it.
    You read my mind....will install and see and of course let you know what happens.
    • ShortCircuited
      • Jan 2020
      • 101
      Odd...Hooked to a 125watt desktop. Computer powers on instantly does not load windows and does not respond to the power button. PS acts as if it is in constant power on state. Voltages are all normal. Odd.
      • ShortCircuited
        • Jan 2020
        • 101
        PG is only .0873v
        • ShortCircuited
          • Jan 2020
          • 101
          Probed the IC (WT7502) that provides PG signal. Does the problem look like an IC issue or a problem elsewhere? These values are from power on state-the only state I can get from the power supply (constant on) and green to ground no connection:
          • R_J
            • Jun 2012
            • 9588
            The power supply should not come on when there is nothing connected to it, if it does then something is telling one of the optocouplers to turn on the main primary supply I don't know which one it is but I suspect it is the one (U3?) just below the J22 letters. The other opto next to it is likely for feedback for the main supply, and the other optocoupler by itself, is feedback for the standby circuit.
            If the power supply is in standby there should be no +12v,+5v,+3.3v going to the WT7502
            The PSONB seems high, I would think it should be around +5v or less (the datasheet says max 7v)
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8325
              I think a valid PGI is more than 1.5V. I guess you have to trace that pin back.
              • R_J
                • Jun 2012
                • 9588
                Check that the power supply is in standby when not connected to any pc. If the main power supply comes on before the ic sees a PS/ON signal the ic might not detect the voltage properly and give a false error
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  #48
                  Great fix so far!
                  But please attach photos to your posts.
                  I have attached the previous ones.
                  It is a great shame when a thread like this comes up empty without photos because the image-host has closed doors!
                  • ShortCircuited
                    • Jan 2020
                    • 101
                    My motherboard went out on my main PC the same day I got to this point.* RMA mode on that. Yeah Photobucket ruined a lot of these repair threads. Thanks for fixing the photos.
                    WT8502: https://cdn.badcaps-static.com/pdfs/...b7fe85fcd7.pdf
                    Tracing PGI circuit back-not far-I think I found another issue here...:
                    15.6v seems high going into the the resistor and cap that are in parallel, which then drops drastically at the cap (c75) and resistor (R67)? Measures 8100ohms across the the cap and resistor. If normal my PGI signal would be 15.6v. Believe spec sheets indicates max voltage of 7v. Bad cap or resistor? Pin under PGI is gnd on Wt7502.
                    *Next day was a Booster Coil in a Samsung monitor.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8325
                      the smd resistor marking is 9101? So it should measure 9.1 kOhms. A bad cap would read a short or some low Ohms and that is not the case.
                      • ShortCircuited
                        • Jan 2020
                        • 101
                        The resistance is 9093ohm appears as I would expect-yes 9101, so why a 15v drop across the two? Leads back to the transformer (secondary side of course) that we originally discovered had a broken solder joint. When trying to check capacitance the meter just can't lock..keeps going back to OL then like .8uf and kinda bouncing back and forth. If the cap, how to speculate the value-size and 15v+ minimum?
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8325
                          Put your finger on that resistor. Is it getting hot?
                          • ShortCircuited
                            • Jan 2020
                            • 101
                            Didn't feel warm...checked the resistor and the cap.
                            • R_J
                              • Jun 2012
                              • 9588
                              Where is the 16 volts coming from?
                              • ShortCircuited
                                • Jan 2020
                                • 101
                                Main transformer that we fixed earlier in this thread...through a diode a resistor/cap (parallel).....long trace another resistor/cap (ones in image-parallel) then into the PGI pin.
                                One side of the transformer is 12.3 and the other is 15.6-both of which are on the secondary side of the main transformer.
                                Neg probe is the ground/blk wires on secondary side.
                                Red line (roughly):
                                • R_J
                                  • Jun 2012
                                  • 9588
                                  So what voltage do you have on pin #1 ? While you are checking, what are the voltages on all 7 pins? I believe pgi voltage is quite low but needs to be above 1.2v.
                                  • ShortCircuited
                                    • Jan 2020
                                    • 101
                                    Pin 1 of Wt7502 is PGI and it is 1.6
                                    What is more problematic is that if the cap just before pin 1 is bad then Pin 1 would receive 15.6 volts if corrected and the max voltage is 7 according to the spec sheet for PGI for WT7502.
                                    Correction to post 51: 14v drop not 15v drop.
                                    • R_J
                                      • Jun 2012
                                      • 9588
                                      pgi of 1.6v should be ok, it is above 1.2v (I did'nt see the <.> in the post# 49 picture)
                                      • ShortCircuited
                                        • Jan 2020
                                        • 101
                                        .08v good for PGO?
                                        Connected to PC and it would not boot to windows...black screen despite voltages 3.3v, 5 and 12 all present.
                                        • R_J
                                          • Jun 2012
                                          • 9588
                                          NO, The ic does'nt just rely on the pgI input pin to give a pgO, high
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
