Corsair GS800 Power Supply Problem
  • R_J
    • Jun 2012
    • 9552
    Re: Corsair GS800 Power Supply Problem
    They must control that baord, because the pfc and the main supply need to be turned off in standby.
    After looking at the CM6800 datasheet, I wonder if they controll the VCC line to the CM6800?
    Did you take any pictures of the riser board with the ic? It would be nice to know which pins of the ic connect to which pins on the riser board.
    • ShortCircuited
      • Jan 2020
      • 100
      OK I desoldered that 5th pin (runs to U3/PC1 top-right pin) on the riser card on primary side and it did power off. I feel like that is progress. So that riser card/CM6800 is sending power on signal in err. It did not boost primary side (160ish volts) and secondary side did not power on.....I did not check stand-by voltage though. Id dint want to leave it on and mess it up.
      Now with that off can I safely test the secondary power on signal to U3 pin 1?
      I will look through photos and see.
      • R_J
        • Jun 2012
        • 9552
        Ok, so that 5th pin could be the vcc supply? On Q2 it seems the base connects to the U3 opto, does Q2's emitter pin connect to hot ground?
        • ShortCircuited
          • Jan 2020
          • 100
          It looks like Pin 13 on the CM6800, which is Vcc that runs to pin 5 on the riser card and off to U3(top-right) primary side of course. Only thing on the riser board between IC 6800 and pin 5 is a 0 ohm SMD.
          Q2.... you mean Q12....about an inch above U3 (on/off OC) primary side? Q2 is just above the fan header I annotated before. I will look into specs on Q12 and see what is going on with it.
          • R_J
            • Jun 2012
            • 9552
            It must be Q12, again its hard to make out the numbers sometimes, So it's collector connects to pin5 (pin 3 is not connected, correct? so I am counting from the same direction)
            So does Q12 emitter connect to the VCC supply? if it does, check that it is not shorted, if it is shorted it would never turn off the vcc to the cm6800.
            Got a number on Q12?
            • ShortCircuited
              • Jan 2020
              • 100
              Yes, pin 3 on riser board is NC and the 5th pin is the one next to (left) the one that is circled on the silkscreen. Top-Pin to Q12 (emitter?) (ZDW 19) connects to Vcc on cm6800.
              Top/middle pin of Q12 and the bottom-right pin is 2 ohm. Short? The bottom-left pin does not seem to be connected to the other two pins on Q12 in the off state-simple continuity check. I do not have a valid spec sheet on Q12/ZDW 19 so I cannot speak specifics on it.
              • R_J
                • Jun 2012
                • 9552
                The ZD is a PBSs5350t, here is the pinout. I suspect the transistor is shorted emitter to collector, that would explain why the ps won't turn off.
                W = made in China
                19 = date code
                • ShortCircuited
                  • Jan 2020
                  • 100
                  W = made in China
                  19 = date code
                  Will these or these work as replacements?
                  I knew I remembered the "ZDW": https://www.badcaps.net/forum/showthread.php?t=83465
                  • R_J
                    • Jun 2012
                    • 9552
                    I knew I remembered the ZDW: https://www.badcaps.net/forum/showthread.php?t=83465
                    They won't work, "these" are N channel mosfets, you need a PNP transistor
                    • ShortCircuited
                      • Jan 2020
                      • 100
                      Do you need to order them or do you have "these" if you need to order them, order the originals
                      I have "these" and "these" Dang...cant wait a month from china....Will dig through my bin and see...maybe I will find something on a scrap PCB. Will update the thread as soon as I find something.
                      old roomba board is loaded with W2T W2Xs and A7Ws....?
                      Will re solder pin 5 to riser card and remove that transistor and see if it stays off. Safe test?
                      • R_J
                        • Jun 2012
                        • 9552
                        I have "these" and "these".
                        "these" won't work. you need "this"...PBSS5350t PNP transistor
                        • ShortCircuited
                          • Jan 2020
                          • 100
                          "these" won't work. you need "this"...PBSs5350t PNP transistor
                          Thanks...will source this'es.
                          Would these work? I can get these within a reasonable time frame and if that fixed this PS I could acquire an original for a final solution. Can't seem to find the 5350ts in USA.
                          Specs:Collector-Base Voltage: 40V
                          Collector-Emitter Voltage: 40V
                          Emitter-Base Voltage: 5V
                          Collector Current: 200mA
                          Mfr: ON Semiconductor
                          Package: SOT-23
                          DC Current gain: 30-300
                          • R_J
                            • Jun 2012
                            • 9552
                            Package: SOT-23
                            Not going to work, only 200ma, you need 2amp
                            Digikey has the originals
                            • ShortCircuited
                              • Jan 2020
                              • 100
                              Found another ZD SOT 23
                              Testing the replacement out-of-circuit:
                              1. collector-emitter: no drop both directions (diode test)
                              2. collector-base: .6v and 0 drop (diode test)
                              3 base-emitter: .6v to 0 drop
                              Seemingly functional? If so, I will install. The original is definitely shorted from collector to emitter.
                              • ShortCircuited
                                • Jan 2020
                                • 100
                                Catching up (almost a year)...Power supply was constant power-on state. We found Q12 (primary side PNP transistor shorted collector to emitter out-of-circuit and possible (actual) cause for constant on state. Replaced w/ PBSs5350t as R_J stated to me repeatedly-THANK YOU! No longer constant on when replaced. PSU now only gives +5vsb. Main cap is 160vdc.
                                • ShortCircuited
                                  • Jan 2020
                                  • 100
                                  When I plug in this power supply tester I have 15ohm on +5v rail. If I simply jump green-ground at 24-pin for power on signal this short is not present. Verified PS tester works on another known good PS.
                                  Pulled the only +5v signal from this daughter board to the main PCB which runs from this daughter board and the 15 ohm short remains. Will dig around on the daughter board.
                                  • ShortCircuited
                                    • Jan 2020
                                    • 100
                                    Applied 12v to daughter board and it drew 300mah (PS set to 800mah). U1/uP3861P did get warm. Any ideas on testing this 20-pin to confirm? Thanks for any help. PS tester makes a very interesting high frequency noise/squeal not made when connected to other power supplies.
                                    Anyone know where would I find these uP3861P? OrderNo. uP3861PSAF SOP-20L
                                    • R_J
                                      • Jun 2012
                                      • 9552
                                      Without the ic driving UG & LG the vcc current should be around 5~10ma @12v. Check that the mosfets are not shorted. As for a source, likely China
                                      • ShortCircuited
                                        • Jan 2020
                                        • 100
                                        In-circuit PH1 (8) is grounded (15 ohm) to daughter board ground.
                                        Pin PH1 (8) to PGND (10) is 15 ohm in-circuit
                                        Pin PH1 (8) to GND (4) 15 ohm in-circuit.
                                        I'm no EE...just an unhealthy obsession with fixing "stuff." This appear problematic? Maybe LG1 or UG1 shorted as you suggested?
                                        Pic shows PHL circuit. Sure seems the short is in this region.
                                        Looks like alibaba is only source. Emailed mouser and digikey for availability.
                                        Q 6, 7 and 8 are identical. Probing Q7 and Q8 in-circuit from D to S is 15 ohm. surrounding CCs are not showing short in-circuit.
                                        Pulled D2 short remains. Diode good.
                                        • ShortCircuited
                                          • Jan 2020
                                          • 100
                                          Pulled Q6, Q7 and Q8 15 ohm short remains. D/S diodes checked out OK out-of-circuit.
                                          Pulled U1 short remains. UGH
                                          red dot to green dot is 128ohm in image below. This is the same for the 3.3v, and 12v rail to ground, but 15ohm to the +5v rail and open circuit when power supply tester is removed.
                                          red dot to yellow dot is 15ohm in image below.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
