Corsair GS800 Power Supply Problem
  • CapLeaker
    Leaking Member
    • 8325
    Re: Corsair GS800 Power Supply Problem
    Originally posted by R_J
    where do you see voltages on the secondary?
    He is still getting like 0.1v or something, I don't think that would be there with an open gate drive resistor.
    • R_J
      • 9588
      R116 is the source resistor for Q11, I wanted to see if it was open or not, turns out it is good.
      • R_J
        • 9588
        I also see Q7 has an insulating kit and Q11 does not, has it been changed to an insulated mosfet? I hope it's drain is not connected to the heatsink. or is Q11 an original and Q7 been replaced with something else?
        • CapLeaker
          Leaking Member
          • 8325
          I just checked the pictures again and you are correct on the resistor, I also did notice that Q7 and Q11 are different, one is a full pack the other isn’t. There is insulating hardware on Q7, but either it is bad, or Q7 is bad. Do Q7 and Q11 have the same part number?
          • ShortCircuited
            • Jan 2020
            • 101
            If D13 cathode is 377v and D19 cathode is 377v then Q7 is either turned on or shorted.
            D13 cathode connects to Q7 Drain
            D19 cathode connects to Q7 Source
            Q11 original if I remember correctly. Q7 was sourced from another PS
            Removed Q7 and it is not shorted. Yes Q7 does have insulating mounting hardware. I will run an independent bench test on this and see if it is good.
            It does appear .19 volts is making it through the transformer to the secondary side for the 12v rail.
            Q7:
            Q11:
            • R_J
              • 9588
              I would also check the resistance of the primary of the transformer, If you have +377v on D19 cathode, you should also have that voltage on D13 anode, and you do not.
              • ShortCircuited
                • Jan 2020
                • 101
                Feedback winding continuity.
                Primary open.
                Neg side of primary winding to feedback is 11 megaohm.
                • R_J
                  • 9588
                  Primary open.
                  That would do it. open primary
                  • ShortCircuited
                    • Jan 2020
                    • 101
                    When the original Q7 shorted it took the primary winding with it? Unfortunately, I don't think these transformers can be sourced reasonably cheap.
                    Here is the suspect as oriented from the board bottom-view:
                    • R_J
                      • 9588
                      Have a close look at the wires that connect to the pins, sometimes it can break right where it connects to the pin.
                      • ShortCircuited
                        • Jan 2020
                        • 101
                        Solder joints look good. Primary winding is actually two wires whereas the feedback is only one wire.
                        Curious. If I am getting .19 on the secondary side that suggests the primary winding broke early in the wind?
                        Is it possible to fix this transformer? If i could find the opening a small bead of solder would be an acceptable fix? It appears the outside is glued together:
                        • R_J
                          • 9588
                          Check the primary winding to those pins that are cut off, I suspect there might be a thermal fuse in the primary. I marked where it might be, but it could also be between the other cutoff pin. check the resistance between those pins, the transformer might be fixable.
                          You posted a picture of the secondary side, But post a similar picture of the PRIMARY side. I might be able to tell if there is an imbeded fuse
                          • ShortCircuited
                            • Jan 2020
                            • 101
                            Feedback Yellow: .78
                            Primary Green: 1
                            Thermal Fuse Red: open
                            Might be here Blue: 1
                            Primary Side:
                            • CapLeaker
                              Leaking Member
                              • 8325
                              an open primary would do it alright. As RJ already said, check the thermal fuse in the primary, if it has one.
                              • ShortCircuited
                                • Jan 2020
                                • 101
                                BINGO! Pin 5 (per post 33) has two wires and one is cracked/split. Looks like QC issue. The wire was not long enough during the manufacturing process and came up short it appears...so just add a glob of solder? Friday Build. I never would have found that without you guys. OH CANADA...!
                                • R_J
                                  • 9588
                                  Good find, BUT is the power supply going to work? lets hope so.
                                  • ShortCircuited
                                    • Jan 2020
                                    • 101
                                    Stop now while we are ahead...? Will post results in a few hours....
                                    Fixed break and we now have continuity across the primary winding as originally predicted.
                                    • CapLeaker
                                      Leaking Member
                                      • 8325
                                      very good find! keep my fingers crossed that it works after you reassembled it.
                                      • ShortCircuited
                                        • Jan 2020
                                        • 101
                                        Preliminarily it works!!!!!!!
                                        Tremendous ty
                                        12.2v
                                        5.0v
                                        3.3
                                        • CapLeaker
                                          Leaking Member
                                          • 8325
                                          awesome!
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
