Anker 71an7105 Usb power adapter
  • clearchris
    • Dec 2013
    • 687
    A few years back, I performed a fix where I replaced blown fuses with resettable fuses. So I'm not ready to let this go. https://www.badcaps.net/forum/showthread.php?t=45797
    Anyway, usb charger is dead, it won't charge anything. It seems to be something on the high side. Here is what I have done so far.
    Removed main transformer to remove the low side from the equation.
    Swapped rectifier with a known working one. The original seemed to test ok with diode mode on my meter.
    Tested high side mosfet on my lcr-4. Checked ok.
    Tested high side diodes on board with main transformer out. Checked ok.
    Checked high side cap on lcr-4. Was 10% less than label.
    Here's what I observe. With the main transformer, and high side mosfet out, I see 125v AC going into the toroidal transformer (I think that's what it is) that is right before the rectifier. Coming out, I get around 6.5v. On a known working model, it's around 160v-180v AC(can't remember exactly). On the bad model, with the rectifier out, it measures 160-180v. So the toroidal transformer is ok. With a known good rectifier on the bad board, it still measures 6.5v. I have left it plugged in for a while and checked for heat (unplugged), but nothing seems hot. I labeled in the picture where I am measuring.
    Anyone have an idea?
    • Jul 2011
    • 6040
    Re: Anker 71an7105 Usb power adapter
    Dose this switching power supply have a ic chip that is a switching power regulator
    You will have to look up the ic chip numbers to figure out which it is now more than likely it is on the hot side of the board
    I can find it with the picture that you posted
    What is the voltage on the optic sensor ic chip on a good one and what is the voltage on the one that does not work correctly
    • clearchris
      • Dec 2013
      • 687
      Something just didn't smell right in my testing. Turns out one of my probes was going intermittent. Once I used a new set of probes, I was able to chase it down to this. I'm surprised I was even seeing 6-9v with one of the legs on the toroidal transformer broken off.
      I resoldered it, but haven't tested it yet. This looks pretty conclusive though unless I broke it during disassembly.
        • Jul 2011
        • 6040
        You could have but from this picture I kind-a doubt it looks to me either a bad soldering joint that broke loose or could broke when you took apart but if this is case why did it not tare the trace apart
        But I could be wrong
          It looks like poor solder works to me, probably that is all wrong with it, I would re-solder all 4 legs of that TOROID, I would also do the same on the other TOROID and the transformer legs as well, just use flux and new lead solder.
          • clearchris
            • Dec 2013
            • 687
            Well, the wire actually broke, the other end of the wire was sticking out the opposite side of the board. The toroid was glued in place, but it was probably dropped a few too many times, and the wire broke. This was my wife's travel charger, so I'm sure it was jostled a bit, one too many times apparently. Or it was nicked during installation, and just fully fractured over time. The bend in the wire is pretty strange, that's how I found it.
            I reassembled it and tested it, all is good now, so that also eliminates the possibility of my breaking it when I took it apart.
            Thanks everyone, the charger lives on!
            • ttbloke
              • Mar 2020
              • 4
              Nice one 👍.
              I have two of those units and they have been great workhorse family chargers. My units slightly predate Apple 2.4A charging so the smart ICs only give 2.1A max. I fixed this by cutting all the traces from the five smart ICs to the USB data pins, solder-bridging each pair of data pins, and jumpering all five pairs together with 30AWG enameled wire over to to a resistor voltage divider which i soldered in amongst the low side circuitry. (I used 43k Ω to +5v, 49.9k Ω to ground, yields approx 2.7 to 2.8 v). Now the units charges Apple devices such as iPads and newer phones at the full 2.4A / 12W maximum Apple spec for 5v. Android devices still charge too because of the shorted D+/D- pins. Some very old android devices that didn't conform to official USB charging standards would likely still have an issue as a result of the mod (or charge v slowly) eg orig samsung galaxy tabs that wanted +1.25v at each data pin. But we don't have any of those so that “smart” IC isn't needed at all. 👍
              I also added a silicon pad / white paste to ensure heat sink plate has direct thermal contact with inside of plastic housing.
                • Jul 2011
                • 6040
                Originally posted by ttbloke
                But we don’t have any of those so that “smart” IC isn’t needed at all.
                The nice thing about the “smart ic chip “ is that when it works RIGHT it selects the right charger CURRENT for your device but when it does not work correctly it a real pain in the ass
                The most reliable setup is the resistor network is still the better choice if the right resistors are chosen
                • ttbloke
                  • Mar 2020
                  • 4
                  Agreed. The choice of resistor network has gotten much simpler. If you use the single divider I describe and pipe that 2.8v into shorted D-/D+ pins, 100% of Apple devices will draw their maximum capability, and every Android device I have tested draws their own maximum. In fact, no USB device I’ve ever plugged in - of any type - has ever refused to charge using this scheme. This is all because two critical criteria are simultaneously satisfied:
                  1) +2.8v is present at both D- and D+ pins, which signals all Apple devices to draw their maximum capable current
                  2) D- / D+ are shorted together, thus conforming to official USB high current dedicated charging spec
                  Every USB charger I have purchased that can meet these current levels has been cracked open and modded this way. I’ve been doing this successfully for 7+ years now. Of course this is all going obsolete in the new world of fast charging / USB-C PD etc. And I should point out that the “maximums” I refer to above are all in the context of traditional USB 5v. The actual maximums are obviously higher for fast charging capable devices, which typically seem to employ a higher voltage level than 5v, and perhaps employ additional conductors etc.
                    • Jul 2011
                    • 6040
                    But it is not only the resistor network but also you need to have at least 5.00 volts at device input for this to work
                    So when you have a 10 foot cord you might have to have 5.25 coming out of charger to over come the voltage loss and on the cable
                    Here is the type of switching power supply that I use for all of my usb devices
                    https://www.badcaps.net/forum/showth...t+power+supply
                      KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                      by momaka
                      For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                      http://www.rmac.kingwin.com/products.../abt_650MM.asp
                      I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                      What mostly drew me into buying it is its 2x PCI-E power connectors...
                      03-29-2022, 11:34 PM
                    • nickBcap
                      Hakko FX-888D toroidal transformer upgrade to 240V
                      by nickBcap
                      I was using a Singway 120-240V < > voltage convertor from Ebay but it was not good enough, it popped and the fuse in the Hakko blew also.
                      I have been looking at replacing the Hakko 110V transformer (I can trade the transformer if anyone needs it) with a toroidal transformer.
                      I have looked at projects and they seem to have been successful but also seem to have used single Voltage Out toroidal transformers. But, the only toroidal transformers I found all have dual 12V or dual 24V Voltage Out.
                      It seems I should have to use a single Voltage Out toroidal transformer...
                      06-15-2020, 09:41 PM
                    • bauto601
                      KDM 480W PSU upgrade succes! (opinions?)
                      by bauto601
                      Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                      A "nice" YoungYear unit? - Badcaps
                      The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                      12-26-2023, 03:05 PM
                      Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                      by momaka
                      This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                      Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                      Macron Power Technology Co. LTD.
                      Let’s look at the PSU itself.
                      The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                      06-02-2021, 10:05 PM
                    • Briesmith
                      Can High Side damage on an SMPS get across the Transformer to the Low Side?
                      by Briesmith
                      I have a blown smps and I am looking for some reassurance as to the amount of diagnosis I have to do. It blew the instant I plugged it in not under any load.
                      As you can see from the attached pix, the damage is located around the main or bulk capacitor (since removed for testing) and the resistor array/network that drives it (the bunch of SMD components to the left of the YAMAHA YC775 AMPS logo). The burn mark on the frame clearly shows the pins of the capacitor. And, for the avoidance of doubt, there is no way the board could have contacted the frame, it was correctly mounted on...
                      05-06-2023, 09:36 AM
