Hakko FX-888D toroidal transformer upgrade to 240V
  • nickBcap
    • Jan 2012
    • 114
    • New Zealand
    I was using a Singway 120-240V < > voltage convertor from Ebay but it was not good enough, it popped and the fuse in the Hakko blew also.
    I have been looking at replacing the Hakko 110V transformer (I can trade the transformer if anyone needs it) with a toroidal transformer.
    I have looked at projects and they seem to have been successful but also seem to have used single Voltage Out toroidal transformers. But, the only toroidal transformers I found all have dual 12V or dual 24V Voltage Out.
    It seems I should have to use a single Voltage Out toroidal transformer and not a Dual Voltage Out toroidal transformer.
    May I have some advice please.
    • 31197
    Re: Hakko FX-888D toroidal transformer upgrade to 240V
    you connect the 12v windings in series.
    • nickBcap
      • Jan 2012
      • 114
      • New Zealand
      Ok great!
      Thank you
        Please note that Toroid transformer has high in rush current thane E-core transformer so it may pop the fuse that you have right now.
        https://www.ametherm.com/blog/inrush...s-got-you-down
          • Jul 2011
          • 6065
          Thanks for this information ( I Did not know this about Toroid transformers )
          I have only seen this type of transformer a few times in a few devices I have seen them at some electronic surplus supply stores online I have been tempted a few times in the past to buy some but not have any experience using them I have not bought any of them
          I will read about this type of transformers from the website links that you provide
          Thanks again for information
          • ohren
            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
            by ohren
            Hello!
            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
            Measured voltages with no load:
            After rectifier diodes
            12V: 6.17 V
            5V: 5.67 V
            Secondary transformer pins AC measurement (really don't know if this says anything)
            12V: 2-2.5 V
            5V: 1.04 V
            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
            03-18-2023, 10:33 AM
          • mikey5791
            Is it possible for transformer substitution?
            by mikey5791
            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
            My questions are
            1. How do i test to see if the transformer is in good working condition?
            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
            Hope you guys understand what i was asking. My intention is...
            11-03-2022, 02:11 AM
          • dennis_elx33
            3PHASE STEP-DOWN Transformer in Check
            by dennis_elx33
            Hello All,
            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
            Problem statement: Power tripped Off
            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
            Action Done:
            1) Replaced the faulty parts with good spare.
            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
            12-02-2024, 06:52 AM
            ASUS Transformer T103HAF-GR032T Hybrid (2-in-1) Mini Specification for Upgrade or Repair
            This specification for the ASUS Transformer T103HAF-GR032T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T103HAF-GR032T boardview and T103HAF-GR032T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 11:44 AM
            ASUS Transformer T101HA-GR049R Hybrid (2-in-1) Book Specification for Upgrade or Repair
            This specification for the ASUS Transformer T101HA-GR049R Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA-GR049R boardview and T101HA-GR049R schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 11:17 AM
