A few years back, I performed a fix where I replaced blown fuses with resettable fuses. So I'm not ready to let this go. https://www.badcaps.net/forum/showthread.php?t=45797
Anyway, usb charger is dead, it won't charge anything. It seems to be something on the high side. Here is what I have done so far.
Removed main transformer to remove the low side from the equation.
Swapped rectifier with a known working one. The original seemed to test ok with diode mode on my meter.
Tested high side mosfet on my lcr-4. Checked ok.
Tested high side diodes on board with main transformer out. Checked ok.
Checked high side cap on lcr-4. Was 10% less than label.
Here's what I observe. With the main transformer, and high side mosfet out, I see 125v AC going into the toroidal transformer (I think that's what it is) that is right before the rectifier. Coming out, I get around 6.5v. On a known working model, it's around 160v-180v AC(can't remember exactly). On the bad model, with the rectifier out, it measures 160-180v. So the toroidal transformer is ok. With a known good rectifier on the bad board, it still measures 6.5v. I have left it plugged in for a while and checked for heat (unplugged), but nothing seems hot. I labeled in the picture where I am measuring.
Anyone have an idea?
(if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
