mercury pc power supply only 5vsb supply.
  • R_J
    • 9518
    Re: mercury pc power supply only 5vsb supply.
    How many "beeps" give you a reading of .6xx in diode test?
    • playit
      • Feb 2020
      • 182
      • india
      #42
      hi RJ this is how it looks now.. i tried my best to put the resistor on R23 and to the jumper ,as no pads are there,they got lifted and teared.. i am sorry i am asking too much.. please do reply when you have time,thanks
      • playit
        • Feb 2020
        • 182
        • india
        #43
        oh you replied i dint see it, transmitter game me one continuous beep ,also there is another problem now..the circuit slided and fell 2 times ,then no power came to board,no 5vsb,then i tried to switch on from back,the switch clip was broken loose,now i will get it ,and try again for the voltages.. is there anything else i should try checking again before i list components to be bought ?
        also i found one of the 4148 zener diode(in pairs) was dead-no reading ,it was at place of R23. i replaced with ph4148
        • R_J
          • 9518
          A 1n4148 is not a zener diode, When checking a transistor or diode with diode test, a silicone junction usually reads about .6xx in diode test. (this number is the voltage drop across the junction) meters with continuity "BEEP" will beep betwen 0 and 150Ω.
          • playit
            • Feb 2020
            • 182
            • india
            #45
            in the mean time..i will test the diodes ,transistors again,i have an doubt are R23- R32- jumper are connected someway in the middle,i see a little copper head there,
            also i want to ask you about this pair 4148 zeners, the pair which is d25,d29. i get reading when i touch negative of d25 and positive of d29 ,as if they working in pairs, but i dont get the same reading for zeners pair near R23 like working in double,but ok when i measure single
            • playit
              • Feb 2020
              • 182
              • india
              #46
              oh ok ,thanks.. this psu got my nerves..i just dont want give it up until something very bad has happened to it ..like it just cant be fixed at all! its just we nearly repaired it well but then i spoiled it.. its so not acceptable
              • R_J
                • 9518
                The diodes D25-D29 are in a different circuit than the diodes near R23.
                • playit
                  • Feb 2020
                  • 182
                  • india
                  #48
                  yes they give readings when read together, but the d9-d10 doesnt give reading like that.. did i fix it wrong... d9 was the one dint give any reading,i removed it and replaced it with ph4148
                  also could you please compare the old and new R23 areas.. i doubt the jumper/R23/d9 was together soldered ???
                  • playit
                    • Feb 2020
                    • 182
                    • india
                    #49
                    this time i checked carefully ..the transistor-- the horizontal - black at base- 676- 699
                    reversed gave- red at base -1749 - 1852
                    the vertical at base- continuous beep - black at base- continuous beep-value decreases- o-1812
                    reversed gave - red at base- continuous beep value 0 - 362
                    • playit
                      • Feb 2020
                      • 182
                      • india
                      #50
                      back with 5vsb ,it was broke positive white wiring,fixed it and back with 5vsb .
                      • playit
                        • Feb 2020
                        • 182
                        • india
                        #51
                        d10 positive has continuity with the copper foil near the junction..i tested the continuity,so according to old pic in which i dint rip off .. are these junction/d10 4148 positive/resistor all soldered together?
                        • playit
                          • Feb 2020
                          • 182
                          • india
                          #52
                          should d9 and d10 to be soldered or shorted in someway..
                          what could be the reason for not getting 16 v or any voltage at other side of the resistor.. any idea how the circuit joins with 2 x 4148 and a resistor.. ? i tried to google it..not much help there..
                          • R_J
                            • 9518
                            This is how the trace should be. and this is how to connect that 1.5k resistor. You need to connect the RED diode anode to the grey jumper wire (yellow trace)
                            One end of the resistor can connect to the jumper wire and the otherend to the blue diode cathode.
                            Your R23 should be the same as R24 on the schematic
                            • playit
                              • Feb 2020
                              • 182
                              • india
                              #54
                              thank you for replying.. i will do it.. after doing it what voltage should i expect on the other side of resistor ? and i am confused whether i really saw 2 4148 diodes ? is that correct there would be 2 4148 there or i am mistaken for some other diodes ?
                              • playit
                                • Feb 2020
                                • 182
                                • india
                                #55
                                transistors readings in post #49 are ok?
                                • R_J
                                  • 9518
                                  There are lots of 1N4148 diodes in this power supply, Plese look at the schematic and you will see they are used everywhere. The two diodes (D9,D10) are likely the same as D10 and D15 on the schematic.
                                  On one side of R23 you should have 16v on the other side it could be around 10~12 volts?
                                  • playit
                                    • Feb 2020
                                    • 182
                                    • india
                                    #57
                                    hmm ok nods ..i dont have schematics ..i mean like a circuit diagram but yes.. i saw they are all over the board.. just wanted to be sure if i am messing up amymore.. today i will fix the tracings and see what i get
                                    • R_J
                                      • 9518
                                      Look at Post #8.... It is not the EXACT schematic but is very close.
                                      • playit
                                        • Feb 2020
                                        • 182
                                        • india
                                        #59
                                        oh ya cool.. now i see the point
                                        • playit
                                          • Feb 2020
                                          • 182
                                          • india
                                          #60
                                          if it helps.. i found the model number but couldnt get it from internet.. mercury model ckp-3400 gc14244 -- this was written on the box of this power supply lid
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • totto210
                                            ps4 supply no12v no 5vsb adp-160fr
                                            by totto210
                                            hi guys, I have a problem, the source recently had 4.8vsb but no acin_det
                                            CN121
                                            1_ acin_det 0v
                                            2_ acdc_stby 0,01v
                                            3_gnd
                                            4_5vsb 4.8v
                                            That was at first, I jumpered 2 and 4 and nothing happened.
                                            I tried to jumper 1 and 2 also, then I realized that I didn't have 4.8v anymore.
                                            1_ acin_det 0v
                                            2_ acdc_stby 0,01v
                                            3_gnd
                                            4_5vsb 1v
                                            a crazy thing
                                            on the main capacitors (c1 and c2) the big ones, I have 1v!
                                            and if I leave the gnd tester tip alone it measures an oscillating voltage between 0.03v and 0.05v !
                                            05-04-2023, 12:54 AM
                                          • tmhobadcap
                                            Gophert Power Supply and testing led problems
                                            by tmhobadcap
                                            Today, I found my led light bulb not working and so I replaced it with a new one. Out of curiosity, I opened the damaged one to see what was inside. I saw a series of 16 leds. I have experience in checking the leds strips for using as backlight in tv. Therefore, I would like to do the same to check which led in the bulb is not working. Initially, I set my bench power supply to 3V and 200mA, and test each led. I found that I needed to raise the voltage to 7V so as to make the led to light up dimly. I found one led did not light up, and I think that one has been damaged. When I went to test the...
                                            12-23-2019, 01:16 AM
