mercury pc power supply only 5vsb supply.
  • R_J
    • 9535
    Re: mercury pc power supply only 5vsb supply.
    How many "beeps" give you a reading of .6xx in diode test?
    • playit
      • Feb 2020
      • 182
      • india
      #42
      hi RJ this is how it looks now.. i tried my best to put the resistor on R23 and to the jumper ,as no pads are there,they got lifted and teared.. i am sorry i am asking too much.. please do reply when you have time,thanks
      • playit
        • Feb 2020
        • 182
        • india
        #43
        oh you replied i dint see it, transmitter game me one continuous beep ,also there is another problem now..the circuit slided and fell 2 times ,then no power came to board,no 5vsb,then i tried to switch on from back,the switch clip was broken loose,now i will get it ,and try again for the voltages.. is there anything else i should try checking again before i list components to be bought ?
        also i found one of the 4148 zener diode(in pairs) was dead-no reading ,it was at place of R23. i replaced with ph4148
        • R_J
          • 9535
          A 1n4148 is not a zener diode, When checking a transistor or diode with diode test, a silicone junction usually reads about .6xx in diode test. (this number is the voltage drop across the junction) meters with continuity "BEEP" will beep betwen 0 and 150Ω.
          • playit
            • Feb 2020
            • 182
            • india
            #45
            in the mean time..i will test the diodes ,transistors again,i have an doubt are R23- R32- jumper are connected someway in the middle,i see a little copper head there,
            also i want to ask you about this pair 4148 zeners, the pair which is d25,d29. i get reading when i touch negative of d25 and positive of d29 ,as if they working in pairs, but i dont get the same reading for zeners pair near R23 like working in double,but ok when i measure single
            • playit
              • Feb 2020
              • 182
              • india
              #46
              oh ok ,thanks.. this psu got my nerves..i just dont want give it up until something very bad has happened to it ..like it just cant be fixed at all! its just we nearly repaired it well but then i spoiled it.. its so not acceptable
              • R_J
                • 9535
                The diodes D25-D29 are in a different circuit than the diodes near R23.
                • playit
                  • Feb 2020
                  • 182
                  • india
                  #48
                  yes they give readings when read together, but the d9-d10 doesnt give reading like that.. did i fix it wrong... d9 was the one dint give any reading,i removed it and replaced it with ph4148
                  also could you please compare the old and new R23 areas.. i doubt the jumper/R23/d9 was together soldered ???
                  • playit
                    • Feb 2020
                    • 182
                    • india
                    #49
                    this time i checked carefully ..the transistor-- the horizontal - black at base- 676- 699
                    reversed gave- red at base -1749 - 1852
                    the vertical at base- continuous beep - black at base- continuous beep-value decreases- o-1812
                    reversed gave - red at base- continuous beep value 0 - 362
                    • playit
                      • Feb 2020
                      • 182
                      • india
                      #50
                      back with 5vsb ,it was broke positive white wiring,fixed it and back with 5vsb .
                      • playit
                        • Feb 2020
                        • 182
                        • india
                        #51
                        d10 positive has continuity with the copper foil near the junction..i tested the continuity,so according to old pic in which i dint rip off .. are these junction/d10 4148 positive/resistor all soldered together?
                        • playit
                          • Feb 2020
                          • 182
                          • india
                          #52
                          should d9 and d10 to be soldered or shorted in someway..
                          what could be the reason for not getting 16 v or any voltage at other side of the resistor.. any idea how the circuit joins with 2 x 4148 and a resistor.. ? i tried to google it..not much help there..
                          • R_J
                            • 9535
                            This is how the trace should be. and this is how to connect that 1.5k resistor. You need to connect the RED diode anode to the grey jumper wire (yellow trace)
                            One end of the resistor can connect to the jumper wire and the otherend to the blue diode cathode.
                            Your R23 should be the same as R24 on the schematic
                            • playit
                              • Feb 2020
                              • 182
                              • india
                              #54
                              thank you for replying.. i will do it.. after doing it what voltage should i expect on the other side of resistor ? and i am confused whether i really saw 2 4148 diodes ? is that correct there would be 2 4148 there or i am mistaken for some other diodes ?
                              • playit
                                • Feb 2020
                                • 182
                                • india
                                #55
                                transistors readings in post #49 are ok?
                                • R_J
                                  • 9535
                                  There are lots of 1N4148 diodes in this power supply, Plese look at the schematic and you will see they are used everywhere. The two diodes (D9,D10) are likely the same as D10 and D15 on the schematic.
                                  On one side of R23 you should have 16v on the other side it could be around 10~12 volts?
                                  • playit
                                    • Feb 2020
                                    • 182
                                    • india
                                    #57
                                    hmm ok nods ..i dont have schematics ..i mean like a circuit diagram but yes.. i saw they are all over the board.. just wanted to be sure if i am messing up amymore.. today i will fix the tracings and see what i get
                                    • R_J
                                      • 9535
                                      Look at Post #8.... It is not the EXACT schematic but is very close.
                                      • playit
                                        • Feb 2020
                                        • 182
                                        • india
                                        #59
                                        oh ya cool.. now i see the point
                                        • playit
                                          • Feb 2020
                                          • 182
                                          • india
                                          #60
                                          if it helps.. i found the model number but couldnt get it from internet.. mercury model ckp-3400 gc14244 -- this was written on the box of this power supply lid
                                            by sam_sam_sam
                                            07-01-2024, 06:34 AM
                                          • repair-it
                                            Need advice testing a samsung power supply board with scope
                                            by repair-it
                                            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                            07-12-2025, 11:00 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • CMCM
                                            Russound CA4 Power Supply Repair
                                            by CMCM
                                            Hello Everybody,
                                            Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                            Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                            The outputs marked 12v and 20v are all measuring only 1v.
                                            The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                            The capacitors physically look clean (no bludgesor leaks) and...
                                            07-03-2025, 01:12 PM
