mercury pc power supply only 5vsb supply.
  • playit
    • Feb 2020
    • 182
    • india
    #61
    Re: mercury pc power supply only 5vsb supply.
    hi ,i connected the traces like in the pic,i get the same results .. 16v at one end and 0.76v at other end of resistor.. but now the 4148 diodes give reading when touched together both at one side,did i miss anything?
    • R_J
      • Jun 2012
      • 9607
      I dont understand? "but now the 4148 diodes give reading when touched together both at one side"
      What is the resistance measured to ground on the end of the resistor that has the low voltage?
      • playit
        • Feb 2020
        • 182
        • india
        #63
        when i kept opposite from the junction ,i.e the negative of D9 and positive of D 10 ,i am getting value in diode mode ,before i dint get that.
        how to measure the resistance to ground?
        • playit
          • Feb 2020
          • 182
          • india
          #64
          hmm.. i kept the black probe in ground ,but with no power, i kept the positive probe on end of low voltage point-- its 590 in diode mode and 645 ohms in ohms mode
          • playit
            • Feb 2020
            • 182
            • india
            #65
            in 2000k ohms mode, black probe in black wire , red probe at low voltage gives 775 ohms, at 16v point -777 ohms
            • playit
              • Feb 2020
              • 182
              • india
              #66
              here i guess i attached the links correct..
              • R_J
                • Jun 2012
                • 9607
                Yes that looks corect, the resistor supplies the 16 volts to the two transistors that drive the small transformer. It also supplies the voltage through one of the small diodes (D10?) then through R32 that connects to another part of the circuit, likely the wt7520 ic .
                • playit
                  • Feb 2020
                  • 182
                  • india
                  #68
                  so whats the problem.. what should be changed? am not getting 12 v at other side of the resistor..what point to be checked now?
                  • playit
                    • Feb 2020
                    • 182
                    • india
                    #69
                    should i check voltages in D9/D10 again to be sure?? hmm by keeping positive probe on positive points of this 2 diodes ?
                    • R_J
                      • Jun 2012
                      • 9607
                      Remove this jumper wire to isolate the circuit. This way the only components that are connected to the end of the resistor are within the yellow box. If the voltage is still less than 1 volt, there must be a bad transistor or diode in this area
                      • playit
                        • Feb 2020
                        • 182
                        • india
                        #71
                        i removed the jumper wire and checked the voltage ,it was still 0.76v . also checked the (c15)yellow color capacitor g104m (cant find what it is in internet) - value in diode mode- 576 stable , reversed - 1868(in some thousands) then disappears.
                        the diode (D11) 4148 is good.
                        i am using this multimeter- DT380D( just incase may be of somehelp)
                        the 2 transistors - Q5 is attached to jumper, Q6 attached to +ve of D13(ph4148) ,and there is a D12 at back of Q6.
                        these diodes are all short,giving continuity(long beep).
                        transistors giving beep too ,before it dint give beep.. saw some vids according to my multimeter.. it said its a sign of continuity and its short.
                        the transistors are H945P 8B3,if its not available what should i get instead? i was waiting for you reply,thanks a lot for showing up
                        • playit
                          • Feb 2020
                          • 182
                          • india
                          #72
                          some diodes at output section on heatsink = stth1002ct gkdsnvu chn816, and stps2045ct 7sacdvw phl 806(2 in numbers)
                          could you tell me what alternatives i can use if i dont get these?
                          • R_J
                            • Jun 2012
                            • 9607
                            What is the voltage drop of a BEEP? What is the resitance of a long BEEP vs a short BEEP?
                            If the diodes and transistors are checking shorted, replace them.
                            How long is a PIECE of string?
                            Check the internet for susbstitute diodes, I am not going to look for a replacements, Why are you replacing them? Are they shorted?
                            • playit
                              • Feb 2020
                              • 182
                              • india
                              #74
                              if i touch both of the multimeter leads i get long beep as its called shorting (source - youtube videos),so when i touch the legs of transistor ,i get the same beep as shorting..
                              the transistor-- the horizontal - black at base- 676- 699
                              reversed gave- red at base -1749 - 1852
                              the vertical at base- continuous beep - black at base- continuous beep-value decreases- o-1812
                              reversed gave - red at base- continuous beep value 0 - 362
                              • playit
                                • Feb 2020
                                • 182
                                • india
                                #75
                                i just saw a video in which the schotty diodes at output side gave continuity long beeps (meaning short) even when power supply is working good, they say it happens sometimes but have to remove it to test it to see if it really is good or bad,so i am thinking of just changing the transistors and 4148 diodes
                                • playit
                                  • Feb 2020
                                  • 182
                                  • india
                                  #76
                                  whats piece of string?
                                  • R_J
                                    • Jun 2012
                                    • 9607
                                    It is like a beep from a meter
                                    • playit
                                      • Feb 2020
                                      • 182
                                      • india
                                      #78
                                      hmm the beep is just long continuous never ending..
                                      also can i use high ampere transisitor ,h945-p is
                                      Type - NPN
                                      Collector-Emitter Voltage: 50 V
                                      Collector-Base Voltage: 60 V
                                      Emitter-Base Voltage: 5 V
                                      Collector Current: 0.15 A
                                      i might get 50v but different amperes like 2A
                                      is it ok to replace wtih it?
                                      • playit
                                        • Feb 2020
                                        • 182
                                        • india
                                        #79
                                        would need little clarity on choosing substitutes by the ratings on
                                        stth1002ct -this is Fast Recovery Rectifiers 200v, 8x2 16A,fv -1.25 V
                                        stps2045ct - this is Schottky Rectifier vrrm -45v, 10x2 20A ,vf- 0.84 V
                                        how nearest i can get a component less or high.. ,which parameters to choose ?
                                        • R_J
                                          • Jun 2012
                                          • 9607
                                          It is likely the diodes are ok, you are being fooled by the meter beeping. I keep telling you you can NOT go by that. YOU NEED TO READ THE FARWARD VOLTAGE DROP when using the meter in diode test. Schottky diodes have a lower voltage drop (0.2xx) not (0.6xx)
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            07-01-2024, 06:34 AM
                                          • repair-it
                                            Need advice testing a samsung power supply board with scope
                                            by repair-it
                                            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                            07-12-2025, 11:00 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
