Hello everyone.
I'll try and keep it short and simple. One night, I came home after a nasty storm only to find my PC turned off. Everything else checked out ok. My monitor, and external speaker system had power. It was just my PC that wouldn't power up. All three were connected to the same surge strip.
After further inspection, I isolated the issue to my Zalman PSU (Model: ZM600-HP) not getting any power. At this point, I noticed that the fuse was blown as I wasn't getting any continuity through it with my volt meter. Secondly, 2 out of 3 CapXon 2200uf & 6.3v caps vented (on the DC side). After doing some research online, they're many reviews that frown on Zalman's selection of components. That, and the fact CapXon is on the craptastic list here...
So here is my question.
Do you think lightning knocked out the fuse and blew just two caps? Or, did the failing caps cause more current to be pulled from the AC side and thus caused it to fail?
All I have on hand is a simple volt meter and an iron. Nothing fancy. I'm a noob when it comes to replacing components. I've attached a picture of the parts in question. The side of the fuse reads T10AH250V.
