Samsung 55NU6900 - Heard a pop then tv is dead, burnt cap & dead fuse
  • Pwtzz
    • Nov 2021
    • 10
    • Usa
    Hi All,
    Before replacing what I know to be bad even with my novice experience. What I have checked at the moment is the fuse and the obvious burnt capacitor. I haven't bought any replacement parts yet.
    I still have no idea how this happened but could just be plain old turned bad. What other stuff should I consider buying as replacement? thanks in advance.
    Edit: I saw that a replacement board can be had for about $50. I would rather attempt to fix before just replacement the board.
  • R_J
    • Jun 2012
    • 9622
    Re: Samsung 55NU6900 - Heard a pop then tv is dead, burnt cap & dead fuse
    This looks like it is the PFC circuit. It might be that the cap shorted on its own, maybe the voltage rating was just border line, (1kv instead of 2kv), Remove the shorted cap, then check the two resistors next to the cap, they are in parallel and should read very low. Also check the mosfet under the heatsink to see if it is shorted or not, Then check the diodes in that circuit, if there are no obvious shorts, it might just be the cap.
    If there is other faults with this board, shopjimmy recommends changing the backlights as well as the board.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8351
      take that 450V cap out. Then measure on those pads for short or not. You definitely need a new cap and a fuse.
      • Pwtzz
        • Nov 2021
        • 10
        • Usa
        I took off the burnt cap, the pads are shorted and more caps are shorted --the blue caps and the square cap (maybe more).
        The mosfet is shorted also and plenty of diodes are bad (going both ways, could this be due to faulty mosfet?)
        Thanks for the tip. I'm going to remove the bad mosfet to see if it affects the shorted caps and bad diodes. I'll open up the screen too and check for visible damages on the backlight.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8351
          Remove the blue cap, that is blown. Check the 2 resistors for spec value (resistors go higher in value or open), remove the mosfet and check it and keep on going until you removed all the shorted or open part(s). Sometimes it can be easy as a new cap and a fuse. Other times you hang in there changing diodes, resistors, mosfets and capacitors.
            09-07-2024, 05:50 AM
          • jesterace
            Samsung UE46ES8000 Blown fuse but no other signs of short
            by jesterace
            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
            09-11-2024, 03:14 PM
            09-06-2024, 11:40 PM
            09-06-2024, 08:40 PM
