Is this really a 540 Ohm resistor? Why is there a completely different share of green printed on it? Like olive green of sort. Am I reading this wrong? Seems wrong for it's application. It is on power supply board input.
Component identification - weird resistor
Tags: None
Re: Component identification - weird resistor
Yep, traced the mains input and it is across parallel to a MOV. How come if it's 150k it does not match the color bands whatsoever? 150k would be "brown green black orange brown" right? This one is clearly "black green(?) yellow brown green" Which adds up to 540 Ohm.Comment
R809 is in series with that spark gap, this is R801 and it is in parallel with a MOV and, a big capacitor and the rest of circuit. Seems to be a part of input RC filter.Last edited by FrozenHaxor; 09-06-2019, 01:08 PM.Comment
510kOhm it is then. Why they marked that resistor completely wrong is beyond me. Thanks for the help.Comment
Lightning damage, input protection was scorched. New MOV, two 6.3A fuses and this dreaded resistor and we're up and running again.
I thought it's primary function was to form some sort of parallel RC filter at the input, but yeah, it will dissipate charge from that capacitor nicely.Comment
by bumper1I have Razer Blade 15 RZ09-0328 MOBO: DA550-MB MP V4.0 20200227 with liquid damage.
I need to know value of resistor on photo. Thanks for help. ... -
by jinu_jHi
4. D930 - Shorted Schottkey Diode...-
by GottaBeGrimhello, i have the gpu in the title and a resistor fell off that i need help finding the resistance of. does anyone have the schematic or the resistance value? see images below for the one missing....2 Photos
Channel: Schematics and Boardviews
01-02-2025, 08:11 PM -
by mikey5791Hi to all forum members,
Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor... -
by jimjoe123I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
Then each time... - Loading...
