Component identification - weird resistor
  • FrozenHaxor
    • Jun 2015
    • 260
    • Poland
    Is this really a 540 Ohm resistor? Why is there a completely different share of green printed on it? Like olive green of sort. Am I reading this wrong? Seems wrong for it's application. It is on power supply board input.
  • R_J
    • 9518
    Re: Component identification - weird resistor
    Looks like 150kΩ post a picture of the board, Is the location marked as R** or L**
    • FrozenHaxor
      • Jun 2015
      • 260
      • Poland
      It is R801 so clearly marked as a resistor.
      • R_J
        • 9518
        I think it is across the a/c line or to ground, I suspect it is 150k. Is it in a tv? Post a picture of the whole board
        • FrozenHaxor
          • Jun 2015
          • 260
          • Poland
          Yep, traced the mains input and it is across parallel to a MOV. How come if it's 150k it does not match the color bands whatsoever? 150k would be "brown green black orange brown" right? This one is clearly "black green(?) yellow brown green" Which adds up to 540 Ohm.
          • R_J
            • 9518
            What does it measure on your ohm meter? or it could be read the other way 51.4MΩ 1%
            • FrozenHaxor
              • Jun 2015
              • 260
              • Poland
              Here you go
              Yes this is a Toshiba TV.
              • FrozenHaxor
                • Jun 2015
                • 260
                • Poland
                510kOhm right now, the leg fell off. Before it was showing high megaohms so its a little burned.
                • R_J
                  • 9518
                  It is a 510k 1/2watt will not effect the power supply's operation.
                  • FrozenHaxor
                    • Jun 2015
                    • 260
                    • Poland
                    R809 is in series with that spark gap, this is R801 and it is in parallel with a MOV and, a big capacitor and the rest of circuit. Seems to be a part of input RC filter.
                    • R_J
                      • 9518
                      I edited my post, here is the diagram of that circuit
                      • FrozenHaxor
                        • Jun 2015
                        • 260
                        • Poland
                        510kOhm it is then. Why they marked that resistor completely wrong is beyond me. Thanks for the help.
                        • R_J
                          • 9518
                          If you read the resistor:
                          Green (5) 1st digit
                          Brown(1) 2nd digit
                          Yellow(5) multiplier
                          Green (±0.5%) tolerence
                          Brown (100ppm/°C) temperature coefficient
                          So what is wrong with the tv/power supply?
                            • 30941
                            watch your fingers, that resistor is to discharge the polyester caps!
                            • FrozenHaxor
                              • Jun 2015
                              • 260
                              • Poland
                              Green (5) 1st digit
                              Brown(1) 2nd digit
                              Yeah, decoding it like 4 band resistor works. The fact that it has 5 bands is not typical as it does not decode as a 5 band resistor properly.
                              Lightning damage, input protection was scorched. New MOV, two 6.3A fuses and this dreaded resistor and we're up and running again.
                              I thought it's primary function was to form some sort of parallel RC filter at the input, but yeah, it will dissipate charge from that capacitor nicely.
                              • R_J
                                • 9518
                                Glad to here it's working, Sometimes its hard to tell with these components, like when the first band on a resistor is black (0), I see this all the time
                                • jinu_j
                                  by jinu_j
                                  Hi
                                  05-03-2025, 10:51 PM
                                • GottaBeGrim
                                  PNY RTX 3060 12GB single fan resistor identification
                                  by GottaBeGrim
                                  hello, i have the gpu in the title and a resistor fell off that i need help finding the resistance of. does anyone have the schematic or the resistance value? see images below for the one missing....
                                  01-02-2025, 08:11 PM
                                • mikey5791
                                  Need help to replace burned resistor in 350w atx psu
                                  by mikey5791
                                  Hi to all forum members,
                                  Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                  The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                  Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                  Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                  12-26-2024, 04:55 AM
                                • jimjoe123
                                  LCD TV Green/Pink screen problem
                                  by jimjoe123
                                  I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                  Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                  Then each time...
                                  02-23-2020, 01:29 AM
                                • MidnightRoller
                                  Can a resistor lose resistance after hot air?
                                  by MidnightRoller
                                  I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                  I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                  02-02-2022, 11:46 PM
