Evga 600w first repairing a PSU
  • dj_ricoh
    • 2073
    Like the title said.
    So I have no clue what to do.
    I know the green wire needs to ha e voltage.
    This one has 2.5v and the old ones 5v.
    I know how to change caps but I don't the quality ones.
    How to test a mosfet and that's it. If it's called mosfet. The one screw or glue to the radiator. Noob sry.
    so i short the green wire it , the fan spins a 1cm and it stops
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8716
    Re: Evga 600w first repairing a PSU
    it sounds like your 5VSB is working (purple wire is getting 5V). Unfortunately this is where it gets frustrating to debug .. capacitors bad, shorted semiconductors, something is telling the output is out of spec after it tried turning on...
    • dj_ricoh
      • 2073
      Thank you.
      I will and I will start desoldering stuff.
      So there is a short. Psu wants to start but it goes in protection.
      • petehall347
        • Jan 2015
        • 4451
        • United Kingdom
        there is some iffy looking solder joints .
          • 31304
          wait, your getting ahead of yourself.
          you need a load on it first.
          • dj_ricoh
            • 2073
            That's scary bad.
            I'll put a motherboard and a CPU to see
            That will be so silly.
            I bought it from EBay with £4 lulz
              • 31304
              most dont, but i'v been stung a few times trying to "fix" ones that did!
              now i have this - problem solved.
              https://www.aliexpress.com/item/32864168715.html
              it's sold out, but there are dozens of other sellers.
              • dj_ricoh
                • 2073
                Same thing.
                Just a little it moved when I trigger to power.
                Thought the green led on mobo it's on?
                  • 31304
                  green led will be the standby supply.
                  so first thing to check is the outputs,
                  that is the diodes and any ceramic caps for shorts.
                  if those are o.k. look at the switching transistors AND any snubber ceramic caps across them - been caught there too!
                  • Jane
                    How do you test MOSFET in laptops ?
                    by Jane
                    I tried to use this method:
                    Testing an N-channel MOSFET:
                    Step 1: Discharge the Gate (turn off the MOSFET)
                    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                    Step 2: Charge the Gate (turn on the MOSFET)
                    Now, place the red probe on the Gate (G) and the black probe on the
                    09-27-2024, 03:31 AM
                  • mikey5791
                    Tiny Tech ATX480W output power ticking
                    by mikey5791
                    Hi to all forum members,
                    ​​​​​​This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
                    Fyi, i desoldered the secondary side electrolytic cap those over 1000uf...
                    02-20-2025, 01:11 AM
                  • mattiaa
                    EVGA GTX 1060 3gb blown mosfet
                    by mattiaa
                    hi, i start saying i am a noob and maybe i am asking something really stupid
                    i have a blown mosfet (q521) that burned around him every pins.
                    I noticed , watching this boardview ( gtx 1060 evga 6gb)that these 4 pins followed a circuit on the left , may i ask you if i can fix everything using some pad strips and attach everything on the small copper line you can see on the photo ?
                    Also, may i know what does this mosfet do?
                    what is 12v_f/steer ?
                    P.S. Sorry if i am asking something really stupid but really , i don t even know where...
                    03-30-2023, 03:37 PM
                  • Nooy
                    VGA MOSfet permanently shorted and loss of MOSfet pad
                    by Nooy
                    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                    02-14-2024, 02:26 AM
                  • jimjoe123
                    LCD TV Green/Pink screen problem
                    by jimjoe123
                    I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                    Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                    Then each time...
                    02-23-2020, 01:29 AM
